Old Mar 12, 2012, 01:48 PM
Sculptor is offline
Find More Posts by Sculptor
AKA, Cheap Chiseler
Sculptor's Avatar
United States, FL, North Fort Myers
Joined Mar 2012
Whoops!
My apologies to the entire board
My apologies to the entire board. I'm letting my frustration and my ignorance get the best of me.
All of you are trying to help and you all have helped very much.
Now I think I've got it set up. With one exception, the throttle doesn't engage until almost half way up then at about half throttle it slows down for 3 or 4 clicks then is speeds after that and is smooth all the way to top speed. When I back it back down it hits that 'slow down' spot on the throttle stick and down a little more it speeds up and goes smoothly all the way to stop.
Can this be tuned out? or is the controller defective
and again my apologies to the board and especially Ribble
DJ
Sculptor is offline Find More Posts by Sculptor
Old Mar 12, 2012, 02:13 PM
Xrayted is offline
Find More Posts by Xrayted
Closed Account
Joined Dec 2007
For those who are confused. http://www.rcgroups.com/forums/showthread.php?t=1612296
Xrayted is offline Find More Posts by Xrayted
Old Mar 12, 2012, 02:16 PM
arbilab is offline
Find More Posts by arbilab
Fly Runaway Fans
United States, TX, Fort Worth
Joined Jan 2009
Does the transmitter have programming for throttle curve? These are typically expressed as percent (%) of full and there are typically 5 steps corresponding to stick position: zero, 1/4, 1/2, 3/4, and max.
If your transmitter has this setting and the values are other than 0, 25%, 50%, 75%, 100%, could cause what you are seeing.
Some soften the first step from 25% to 20% if the model tends to lurch upon startup.
Also, THR TRIM must always be all the way down. Not in the middle like the others. If you bound it with THR TRIM in the middle, move it all the way down and rebind.
arbilab is offline Find More Posts by arbilab
Old Mar 12, 2012, 03:32 PM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
There are no settings for that, as I recall. It's hard to tell if it's PCB, motor or transmitter. I would suggest playing with throttle trim. It might provide some clues.
Balr14 is offline Find More Posts by Balr14
Old Mar 12, 2012, 03:52 PM
Sculptor is offline
AKA, Cheap Chiseler
Sculptor's Avatar
Joined Mar 2012
Thank you, It does have the 0 25% 50% 75% 100% throttle curve. I'll try setting it on 20%
BTW I have two 9116's and this TX acts the same with either
DJ
Old Mar 12, 2012, 04:54 PM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
It sounds like the tx is not setting up properly thus the board is not recognizing low throttle. Sorry, I'm not familair with this heli/tx.
chopper62 is offline Find More Posts by chopper62
Old Mar 12, 2012, 05:08 PM
arbilab is offline
Fly Runaway Fans
Joined Jan 2009
Confirm THR TRIM is as low as it can go. If it is centered, lower it as far as it goes then rebind.
I also do not own this model. I own Spektrum gear. But the same things can apply.
Old Mar 12, 2012, 05:33 PM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
DJ
Do you have 2 9116s and 2 transmitters?
My Apologies to Australia. mrebman Life, The Universe, and Politics 4 Oct 27, 2003 03:23 AM
My apologies Mr Goldberg aircargo Electric Sailplanes 6 Oct 29, 2002 10:46 PM
