Old Mar 12, 2012, 11:24 AM
Joined Apr 2011
Using 3 cell lipo to run RX directly (Nitro plane)
Hi,
After speaking to a friend at my MC he told me that it was possible to use lipo to run the receiver. He advised a small 3 cell 800maH. Having realised that a lipo is generally much better all-round i started to read up on RCG's and found that people had regulated batteries.
My question- What is meant by regulating a lipo and how do you go about doing so?
P.s. Excuse my lack of knowledge
Regards
TOM
maverick64 is offline Find More Posts by maverick64
Old Mar 12, 2012, 11:38 AM
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
a voltage regulator regulates the voltage it output.
R/C radio equipment is almost universally made to work with 4s nickle (3.2-5.8v) or 5s nickle (4-7.25v) supply voltages. (with some more expensive "high voltage" equipment out now for premium price)
a 2s lipo fully charged is 8.4v
a 3s lipo fully charged is 12.6v
if you didn't use a voltage regulator, you are highly likely to fry every servo as soon as a load is placed on it and possibly fry the receiver (receivers have always been some what more tolerant of over voltage)
Toysrme is offline Find More Posts by Toysrme
Old Mar 12, 2012, 12:03 PM
Jacksonville Fla.
Joined Mar 2007
A 3 cell is too much voltage....you'll let the magic smoke out if you don't run a voltage regulator ..whats the magic smoke? It's what makes everything work...if you see the magic smoke well whatever it came from no longer works
jetmech05 is offline Find More Posts by jetmech05
Old Mar 12, 2012, 01:17 PM
"Unnecessary Necessity"
coriolan's Avatar
Canada, BC, Vancouver
Joined Sep 2006
Originally Posted by maverick64 View Post
Hi,
Regards
TOM
Your friend should try it on its own receiver and learn something
coriolan is offline Find More Posts by coriolan
Old Mar 12, 2012, 02:06 PM
Joined Aug 2011
Use a 2s LiFe unregulated for any servos rated for 6v.
http://www.hobbico.com/radioaccys/hcam6415.html
600Bob is offline Find More Posts by 600Bob
Old Mar 12, 2012, 05:42 PM
Marietta GA.
Joined Jan 2011
I was going to go the Li-po way on one of my planes that was a little too heavy..I use a 5cell 2500 Ni-MH..After I weighed the Li-po and the regulator I was going to save about 25 grams..I stayed with the Ni-mh as I don`t have to worry about the regulator going out..
mazjag is offline Find More Posts by mazjag
Old Mar 12, 2012, 06:41 PM
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
Yes this regulator reduces the voltage to something the servos and receiver can survive.
I use lipos and Castle BEC's on most of my fuel planes.
A simple 4 ch. trainer can use a 2S 750Mah Lipo. This will be enough battery for several flights (5 or so)
1320fastback is offline Find More Posts by 1320fastback
Old Mar 12, 2012, 07:03 PM
Marietta GA.
Joined Jan 2011
This is were I disagree with some..I don`t want to charge my rx battery..no matter how fast the re-charge is..I want to fly all day and not worry about it or go up with a dead one.everyone has different deal..J
Old Mar 12, 2012, 08:40 PM
USA, CA, Oceanside
Joined Jul 2008
It's just a different way of doing it. Mah is all that matters and is adjusted acording to servo draw and servo quantity.
Like before I use a very small 2S and small regulator in my Strega Mustang. This plane weight matters as weight is lost speed. Flying it at most you are using the ailerons and rudder at once so it is probably drawing less than 1 Amp on a regulator rated for 10A.
My Avistar and Bobcat both have 8 servos so I use a 3S 2200 in them. Both can fly ALL day without a recharge.
The other good thing about Lipos is they retain their voltage better than a Nixx battery. Even though they do get lower it is not as drastic especially at such low levels of discharge.
I got into this hobby when Lipos and brushless was common place.
I don't even know how to charge a Nixx?????
I do NOT use cheap Hk electronics though.... Have yet to have 1 issue with any of them.
Use what your comfortable with.
Old Mar 12, 2012, 09:56 PM
Mtn Home, Idaho
Joined Feb 2010
ive got castle cc bec pro 20amp i use sometimes this will regulate to what ever voltage you want.
battery pictured is 4cell lipo voltage regulator is set at 6 volts
i ran the 4cell because its what i had on hand, im curious why you run the 3cell isnt that just uneeded weight. a 2 cell 2200 is tiny compared to 4cell.
heres my 2cell 2200
sorry im heli guy butting in, i now fly the 600 with 7100r reciever that is voltage reglator insetself so i have the 2 cell lipo plugged directly into it.
i was planning to run a similar sized 2 cell lipo on plane build with my cc bec pro. i also have 3 cell 2200 batteries, just curious why 3 cell is better
Evan03 is offline Find More Posts by Evan03
Old Mar 12, 2012, 10:10 PM
USA, CA, Oceanside
Joined Jul 2008
I was using it for CG purposes, it was shoved up into the nose to help offset the .75 hanging off the back.
A 1/2x5" carriage bolt took care of the rest
Old Mar 14, 2012, 09:24 PM
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
I use 3 cell l1000 mah ipos with a regulator instead of 2 cell b/c if a cell goes out during flight your still ok. With a 2 cell lipo, if you lose one, the voltage will be to low for the receiver and you just re-kitted your plane.
Thermalin is offline Find More Posts by Thermalin
Old Mar 14, 2012, 11:10 PM
Fueled by Arabica Beans
ChillPhatCat's Avatar
United States, NY, Syracuse
Joined Oct 2008
The same goes for any battery. Why risk it with only 3 cells? What if two go out?
Have you ever had a cell die on you mid flight?
ChillPhatCat is offline Find More Posts by ChillPhatCat
Old Mar 15, 2012, 07:40 AM
Branford, Florida
Joined Jun 2010
This is the route I took. Unregulated straight to the Rx, simple, light weight and effective. 1300 mah on my 40 size glow plane and I can fly at least 6-8 times with no worries. I cant remember ever having to charge back more than 50% of the batteries capacity.
ACKopter is offline Find More Posts by ACKopter
Old Mar 15, 2012, 08:07 AM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
You really need to look up the specifications for your brand and model of receiver. There are some receivers now out on the market that can handle higher input voltages. But this is mostly for two Lipo cells in series. I haven't looked to see if anyone makes a high voltage receiver that can run off of a three cell Lipo pack yet, but there may be some.
The next problem is your servos and anything else you have plugged in, as to whether it can handle the higher voltage or not. The high voltage rated servos are quite expensive so far.
You can use a voltage regulator unit to lower the Lipo battery pack voltage down to a safe level for your receiver and servos. Plus for other things like sensors, gyros, etc too.
As mentioned many folks opt for the LiFe two cell packs as it is easier to find receivers and servos rated to handle the voltage for a LiFe pack.
earlwb is offline Find More Posts by earlwb
Latest blog entry: My Low Wing plane
For Sale HPI nitro RS4 evo 3+ ready to run 48chebbie Cars - Cars and Parts (FS/W) 0 Mar 11, 2012 05:12 PM
Sold ParkZone 2-3 cell lipo balancing charger HeartBreak Aircraft - Electric - Batteries & Chargers (FS/W) 2 Mar 09, 2012 08:37 AM
Sold 2X 1300 mah 40C 3 cell sky lipo ($18 shipped for both) 100mph Aircraft - Electric - Batteries & Chargers (FS/W) 6 Mar 09, 2012 07:48 AM
Sold 3 Blue LiPo 4-Cell 2200mAh 4S1P 14.8v 20C LiPo's yz426f0 Aircraft - Electric - Batteries & Chargers (FS/W) 7 Mar 05, 2012 10:18 PM
Discussion Question , can you run Nicad/Nimh battery setting using Lipo 3 cell batteries? DCT1 Castle Creations 1 Mar 05, 2009 10:29 AM
