Old Mar 12, 2012, 08:27 AM
candane is offline
Find More Posts by candane
Turkey
Joined Oct 2008
Boeing 727
Model boeing 727
length 215 cm aprox. 85 inch
wing span 200 cm --79 inch
weight 4 kg.
fan-motor; 2 HET 70 mm fan and 2200 kv inrunner
6s 5000 mah 40 c lipo.
I built this plane from depron and 3 mm depron like material. Then I coated with epoxy and 50 gr/m2 fiber.
candane is offline Find More Posts by candane
Old Mar 12, 2012, 08:40 AM
candane is offline
Turkey
Joined Oct 2008
continue,
I have used electronic servoless retrack.
Now plane weight is 2500 gr without lipo. Last weight isnot more than I expected.
Old Mar 12, 2012, 09:08 AM
czirh is offline
Find More Posts by czirh
Use your imagination....
czirh's Avatar
Greece, Dafni
Joined Oct 2007
Nice project,
kolay gelsin.
Cem
czirh is offline Find More Posts by czirh
Old Mar 12, 2012, 11:01 AM
candane is offline
Turkey
Joined Oct 2008
Teşekkürler.
This is a quick built. I want to fly it as soon as possible.
Old Mar 12, 2012, 07:37 PM
Flexserve is offline
Find More Posts by Flexserve
Avoid The Ground!
Flexserve's Avatar
United States, FL, Tampa
Joined Sep 2008
I must say. I like how fast you build! Looks like a card model based build. Good Luck Have Fun with it! Subbed!
Flexserve is offline Find More Posts by Flexserve
Old Mar 12, 2012, 09:38 PM
PittSpecial is offline
Find More Posts by PittSpecial
Right Rudder
PittSpecial's Avatar
USA, FL, Orlando
Joined Nov 2010
Wow! This thread took my breath away as my father used to fly this Jet during late 70's, 80's and early 90's. He flew for AVIANCA (Colombian Airlines) and did so on 727.
True work horse of the Airline industry back then!
Can't wait to see additional progress!
PittSpecial is offline Find More Posts by PittSpecial
Old Mar 12, 2012, 09:43 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Just one question,
4,000grams ~ 8.9lbs.
Do you feel that the 70mm will be enough thrust?
I see you like to keep it scale but, I was wondering if 90mm EDF's would not be more in mind for good thrust?
I am no EDF expert, just wondering out loud.
Thanks!
Carlos
Old Mar 13, 2012, 03:11 AM
carrerars is offline
Find More Posts by carrerars
carrerars's Avatar
Joined Aug 2008
Well in my opinion the 70mm fans should be ok.
There are different planes of that size and weight using 70mm fans even with a 4s setup and it works well. (e.g. Windrider 737-700)
Have a similar issue right now. I'm building an A319 with 2m wingspan.
Even if 90mm fans would look better and fit in the nancelles I'll try 70mms because of weight and amps.
Markus
carrerars is offline Find More Posts by carrerars
Old Mar 13, 2012, 04:22 AM
candane is offline
Turkey
Joined Oct 2008
Thank you.
I think two HET fans would be sufficient. Total power aproximately 1600 watt. These fans are very well balanced. I measured total thrust 2800-3000kg.
In fact, estimated ( most pessimistic) maximum weight is 4 kg.
This plane is our previous airliner. She is 3.5 kg. She flew with only 1000 watts.
Video
RC A320 EDF Home-made (2 min 56 sec)
Old Mar 22, 2012, 05:29 PM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Originally Posted by PittSpecial View Post
Just one question,
Thanks!
Carlos
My windrider 737, is 4,3kg - somewhat on the heavy side... The Changesun 70mm fans delivers about 1,2 kg thrust at approx 600W per motor and it flies fine, no problem
Boeing 737 from Windrider.wmv (4 min 27 sec)
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Mar 22, 2012, 06:16 PM
Right Rudder
USA, FL, Orlando
Joined Nov 2010
Understood, Got It, by George....etc...
No need for more examples.
Thanks!
Old Apr 26, 2012, 12:38 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Wow! Subbed up
Welcome to the club
BTW could you guys Chime in on This Rcgroups airliner forum Request thread
http://www.rcgroups.com/forums/showt...1604714&page=4
Keenan smith is offline Find More Posts by Keenan smith
Old Apr 26, 2012, 04:56 PM
Concordefan is offline
Find More Posts by Concordefan
Scale Modeler
Concordefan's Avatar
Canada, ON, Mississauga
Joined Feb 2006
Very nice and fast build here. It looks more like in between Yak 40, Bac 111 and HS Trident to me then a B727!, either way beautiful model it's going to be once done.
Concordefan is offline Find More Posts by Concordefan
Old Apr 26, 2012, 07:06 PM
NAKIAM949 is offline
Find More Posts by NAKIAM949
NAKIAM949's Avatar
United States, MD, Waldorf
Joined Dec 2007
Subbed can't wait to see the finished product.
NAKIAM949 is offline Find More Posts by NAKIAM949
Old May 02, 2012, 08:56 AM
candane is offline
Turkey
Joined Oct 2008
Thank you, I can not see details of the plane as good as you. I dont have much information about airliner. This is my second airliner but I have alot of EDF plane.
She flew in this weekend. The plane took off and landed very well. I will upload the maiden flight video.
Build Log 3/4" scale Boeing 727-100 astroboy Scale Kit/Scratch Built 108 Nov 25, 2013 11:21 PM
Boeing 727 Engines 1 & 2 Question David A Ramsey Scale Kit/Scratch Built 25 Dec 15, 2007 05:53 PM
Boeing 727 airfoil/wing design question David A Ramsey Electric Ducted Fan Jet Talk 12 Dec 12, 2007 04:34 PM
Boeing 727 Engine No. 2 Question David A Ramsey Scale Kit/Scratch Built 25 Apr 19, 2004 03:26 PM
