Old Mar 12, 2012, 06:37 AM
sledge21 is offline
Find More Posts by sledge21
True Modder.
Joined Jun 2011
Help!
D.I.Y BL Baja
Hi all!
I have a HPI Baja and the motor just got some water on the head when it was hot as hell and it cracked beyond repair.
All my other cars is brushless and I have some years behind my name with brushless setups but only on 1/10 and 1/8 scale.
I have a TurnigyPro Comp bl motor with the following specs:
56mm dia and 92mm long. 780kv. Max amp draw is 200A . Can take up to 37v and is rated at 6000w max. It has a 8mm shaft.
I want to run it on 6s lipo with a Mamba Monster esc and that will give me the following:
2664Watt on 6s and 120A continious and max of 17316rpm free running.
Do you guys think this will be a good combo? It doesnt have to be faster than the 23cc gasser but I just dont want to burn any thing. I will gear it down for 30mph.
sledge21 is offline Find More Posts by sledge21
Old Mar 12, 2012, 09:43 AM
Y2kGTP is offline
Find More Posts by Y2kGTP
Car Junkie trying to fly
Y2kGTP's Avatar
United States, FL, Deltona
Joined Oct 2005
It looks to be the same Kv that Castle provides for their 1/5th setup, so looks spot on to me.
http://www.castlecreations.com/products/2028_motor.html
Looks like they make a nice fan shroud as well for it.
http://www.castlecreations.com/produ...ower-2028.html
Y2kGTP is offline Find More Posts by Y2kGTP
Old Mar 12, 2012, 11:05 AM
sledge21 is offline
True Modder.
Joined Jun 2011
I have been looking at that motor, the only thing that worries me is the Mamba Monster esc. Will it handle 120A continious on 6s. That will give me 2.6kw and will this be enough? Say the motor wants more amps? Maybe I will install a 120A fuse to protect my esc?! What will be a reasonable size pinion to install for about 30mph?
Sold TowerPro BL Outrunner TP2410-12T(Y) (Bob Parisot bought ALL) heli_ebook Aircraft - Electric - Power Systems (FS/W) 0 Jun 10, 2009 04:31 PM
Discussion se vende avion de ala alta y de ala baja Jose .L Faz Mexico 4 May 13, 2008 08:09 PM
Discussion QUISIERA SABER DIFERENCIA ENTRE RECEPTOR ALTA FRECUENCIA Y BAJA pcm roberto_bok Mexico 4 Oct 24, 2006 12:43 PM
The D-I-Y tapestreamer motor conversion thread. Looooeeee! Power Systems 48 Apr 30, 2004 04:46 PM
