Old Mar 13, 2012, 09:12 AM
Taiping is offline
Find More Posts by Taiping
Canada, BC, Vancouver
Joined Sep 2009
Originally Posted by Blueshy View Post
Just start with the absolute basic 1 battery setup and then add components
one by one until the problem reappears. So start with a 1 battery setup with
just a cam, VTx, and Rx and see if the problem persists. Then add OSD. Then
add current sensor. Ect. Make it as basic as possible and then add things in a
piecewise manner. When the problem reappears you know which component is
causing the problem and will have a better time figuring out what is wired
wrong, rather than trying to solve a single problem within the entire system as
a whole.
-Blues
Thats what i did, when i bypass the osd, its fine, when i keep the osd, current sensor, its fine, when i add the servos and motor, its not
Taiping is offline Find More Posts by Taiping
Old Mar 13, 2012, 07:20 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Is it possible, Filter is backwards.
It looks like it has a directional diode, so I don't know if it would even work backwards.
m_beeson is offline Find More Posts by m_beeson
Old Mar 13, 2012, 07:33 PM
Taiping is offline
Joined Sep 2009
don't think the filter is backwards, just tried swapping the servos, same thing . I also tried to get direct video out of the osd (no vtx) and it still does it.........
Old Mar 13, 2012, 11:22 PM
Taiping is offline
Joined Sep 2009
Im giving up on single bat setups............. Can someone check this wiring diagram for dual bats? Any ground loops? Should i still use the SEPIC regulator between the 3S Lipo and the Camera/VTX? Thanks
Old Mar 14, 2012, 02:03 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Maybe it'll fix the problem, maybe not. You're still using shared grounds across all components, both
filtered and unfiltered.
My advice at this point would be to drop in on the EagleTree threads and see if anyone
else has had the same problem and fixed it, because it seems to be the only
component that links your noise together. Folks with single battery RVOSD, and single battery
DOSD+ and single battery ezOSD setups don't seem to have this problem.
ian
Daemon is online now Find More Posts by Daemon
Old Mar 14, 2012, 08:23 AM
Hugeone is offline
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
I have single batt with eagletree and picture is noiseless. I use a dedicated ground for all video devices: cam, OSD, Tx, video switch.
Check the connections between the logger out and taps going to your sepic and filter.
Resistance on this point, will create a voltage change between OSD grd. and CAM/Vtx grd. as soon as current pass (either servos or motor)
-Hugo
Hugeone is offline Find More Posts by Hugeone
Old Mar 14, 2012, 10:36 AM
Taiping is offline
Joined Sep 2009
-Hugo
what do you mean by resistance on the point?
Old Mar 14, 2012, 11:05 AM
Hugeone is offline
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Example, a cold joint in the plug going from the logger to the esc.
If current has difficulties to pass it create "ripples".
-Hugo
Old Mar 14, 2012, 11:20 AM
billyd60 is offline
Find More Posts by billyd60
Gravity is patient............
Joined Mar 2006
Is it possible the servos are causing enough of a voltage drop to create an issue with your Tx?
Other obvious suggestions:
Ferrite rings, twisted cabling, equipment location, defective equipment.
billyd60 is offline Find More Posts by billyd60
Old Mar 14, 2012, 11:43 AM
Taiping is offline
Joined Sep 2009
Don't think that theirs a voltage drop because it uses a separate UBEC, the TX is using its own regulated 12V from the regulator
The servo wires between the osd and rx are all twisted, the wires to the cam and TX are all shielded and grounded closest to the battery.
Doont think theirs defective equipment other then the Lawmate 1W TX that i just burned cuz I forgot to attach the antenna
Old Mar 14, 2012, 11:56 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
What he's suggesting above is that you measure the resistance between every ground
point in the harness. Camera ground, Tx ground, OSD ground, ESC ground, battery
connector ground, Rx ground.. etc. If it doesn't read exactly 0 ohms between every point,
you've got an issue.
ian
Old Mar 14, 2012, 12:11 PM
Taiping is offline
Joined Sep 2009
Oh okay, I'll try that when I get home tonight
Old Mar 14, 2012, 08:56 PM
Taiping is offline
Joined Sep 2009
It's all 0 ohms, I'm going to try the dual bat setup tomorrow......
Discussion ar6200 rudder moves when plug in curtqn Radios 20 Feb 04, 2011 10:38 PM
Help! Static noise from the microphone + video noise when motor is working gpsnow FPV Talk 13 Nov 18, 2010 06:06 PM
Discussion My 480 Brushless Moves in and out when throttle applied.... ffokazak Power Systems 4 Feb 21, 2010 12:58 PM
Throttle servo moves when elevator servo is moved chris8105 Fuel Plane Talk 22 Jan 10, 2007 02:53 PM
