Old Mar 12, 2012, 12:43 AM
Taiping is offline
Find More Posts by Taiping
Canada, BC, Vancouver
Joined Sep 2009
Static in video when servo moves?
Hey, I'm having some issues with my first single battery setup, as my previous planes all had a separate video battery
heres my setup
1.2ghz 1000mw Lawmate tx
IBCRAZY Cloverleaf
TBS 69 Camera
Eagletree OSD, Elogger, Guardian
DPCAV SEPIC Voltage regulator 1-35V
DPCAV LC Filter
Hobbyking UBEC
these are all mounted on a rite wing zep2 with 2x 4s 3000mah Zippy Lipos
The problem is that when i move any of the servos (hs-645mg) or start up the motor lines of static will appear in the video, when i throttle up the osd text will "jump" up, heres the video of it
fpv issue (0 min 22 sec)
Any ideas? Thanks
Taiping is offline Find More Posts by Taiping
Old Mar 12, 2012, 01:18 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
What's powering the RC Rx? ESC's BEC, or the HK UBEC?
If the latter, where in the circuit is the UBEC? Before (close to the battery) or after the LC filter?
ET OSD directly links the receiver and the video system so any noise at the Rx (servo noise, or
ESC noise) bypasses your LC filter. With the connections between Rx and OSD, you
may have also created a ground loop.
ian
Daemon is online now Find More Posts by Daemon
Old Mar 12, 2012, 01:28 AM
Taiping is offline
Joined Sep 2009
the RX is powered by the UBEC, the video Signal wire is only connected into the OSD, the power to the vtx and cam comes from the ubec. The ubec is at the ESC end of the elogger, where power is spilt to UBEC, Voltage REG and ESC
Old Mar 12, 2012, 01:31 AM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Filter the video equipment from all other components.
**EDIT: Oh, I see you did...
m_beeson is offline Find More Posts by m_beeson
Old Mar 12, 2012, 01:35 AM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
torroid on the video line just before the Vtx?
Are you using audio? is the audio wire hanging free? it might be overdriven, or if it's not connected to anything, might want to ground it.
Edit: ninja
gundamnitpete is offline Find More Posts by gundamnitpete
Old Mar 12, 2012, 01:36 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I don't see any issues in your circuit. No ground loops, and the one LC filter you have, should
be sufficient (I've never had to add a 2nd closer to the video Tx). What are you doing with the
audio line? Is audio signal clamped to ground, or free floating? Might have noise coming in
there, and that can interfere with video. [edit]pete beat me to it.
ian
Old Mar 12, 2012, 01:42 AM
Taiping is offline
Joined Sep 2009
ian
The audio from the vtx is just free floating, should i try grounding it? thanks
Old Mar 12, 2012, 02:01 AM
Team White Llama!
definitely try grounding it.
Old Mar 12, 2012, 10:52 AM
Taiping is offline
Joined Sep 2009
just tried it, it isn't working, any ideas?
Old Mar 12, 2012, 11:07 AM
BCSaltchucker is offline
Find More Posts by BCSaltchucker
fly by night
BCSaltchucker's Avatar
Joined Sep 2011
just go to a separate video battery. Yeah I know you know to do that and wanted to avoid the hassle , but it just make sense now.
BCSaltchucker is offline Find More Posts by BCSaltchucker
Old Mar 12, 2012, 11:08 AM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Can only suggest bypassing OSD with the video line just to see if the noise is coming in there.
ian
Old Mar 12, 2012, 11:55 AM
Hugeone is online now
Find More Posts by Hugeone
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
Signal come out of the cam and into the OSD and down the OSD's grd. trough the Rx and trough the BEC to finally reach the batts. Problem is your OSD's ground is long and also carry the servo's current. The ground level (0V) of your OSD is not exactly 0V, but change slightly as current from the servos pass. Solution: Feed your servos directly from the Rx, only the signal reaching the OSD.
Good read
-Hugo
Hugeone is online now Find More Posts by Hugeone
Old Mar 12, 2012, 12:05 PM
Taiping is offline
Joined Sep 2009
Hugo,
according to this img #4, only + passes through the LC filter, but on my LC filter both + and - passes through. I'm not sure how i should fix this? can you recommend something?
Taiping
Old Mar 12, 2012, 12:13 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
I highlighted the solution above.
Old Mar 12, 2012, 12:17 PM
Taiping is offline
Joined Sep 2009
But how would the servos then get power? since power is not passed through the osd?
Discussion ar6200 rudder moves when plug in curtqn Radios 20 Feb 04, 2011 10:38 PM
Help! Static noise from the microphone + video noise when motor is working gpsnow FPV Talk 13 Nov 18, 2010 06:06 PM
Discussion My 480 Brushless Moves in and out when throttle applied.... ffokazak Power Systems 4 Feb 21, 2010 12:58 PM
Throttle servo moves when elevator servo is moved chris8105 Fuel Plane Talk 22 Jan 10, 2007 02:53 PM
