Old Mar 11, 2012, 08:24 PM
RCTyp is offline
Find More Posts by RCTyp
Smashes Things
RCTyp's Avatar
Montpelier, VA
Joined Feb 2005
Help!
Problem: 1420i-Net3 Charging at 33 amps when on 24 volts
I have the Hyperion 1420i-Net3 charger and have had no problems with it. But I recently got a 24 volt power supply, and when I charge my 5s battery on it, the charger immediately ramps to 33+ volts I was looking at the display, and thought I was not seeing something right, but when I unhooked the lead it was getting quite warm, so it was indeed pumping some amps.
When I go back to the input only being 12 volts it does fine, ramps the amps up to the 10 amps I have it set for,
Questions
1. Do you know what is wrong?
2. I got it from All E RC and sent a message, will they fix it? I have had it for barely over 30 days (ordered Jan 28).
I have not taken it apart or anything else so far. See picture in next post below....
RCTyp is offline Find More Posts by RCTyp
Last edited by RCTyp; Mar 11, 2012 at 09:12 PM. Reason: added reference to picture.
Old Mar 11, 2012, 09:11 PM
RCTyp is offline
Smashes Things
RCTyp's Avatar
Montpelier, VA
Joined Feb 2005
Picture too
In the attached picture you can see the charger data screen and a wattmeter between the charger and battery.
Charger
31.67 amps
21.449 volts
Meter
12.31 amps
21.22 volts
My bet is that the 12.31 amps is all the battery can take and that is why it is that low. I had the setup for 10 amps.
Help!
Old Mar 11, 2012, 09:14 PM
RCTyp is offline
Smashes Things
RCTyp's Avatar
Montpelier, VA
Joined Feb 2005
Overall Setup
Here is the overall setup, if that helps.
Old Mar 12, 2012, 03:34 AM
sts41 is offline
Find More Posts by sts41
Canada, ON, Stouffville
Joined Nov 2011
One thing I would test is the output of the power supplies...They look like Compaq server supplies, and I am not sure they were designed to be placed in series.
At the output of the series PS's...and with a load, use a good quality multimeter and mesure the DC voltage...Should be at the 24 volts.
Next, switch the meter to AC voltage scale and mesure the voltage...should be less than 1 volt.
If all is good, you can eliminate the PS as an issue.
The test above is to test for ripple voltage, or out of phase output that would normally only get picked up with an ocilloscope.
sts41
sts41 is offline Find More Posts by sts41
Old Mar 12, 2012, 10:50 AM
zeroback is offline
Find More Posts by zeroback
United States, FL, Pompano Beach
Joined Oct 2011
Just received and started using my 1420 works fine on 12.6V 180Ah deep cycle. I'm going to bring a second 12V deep cycle home and plan run it on 24V and charge an 8S pack I have. I'll let you know if it works. I have a 14V 100W MPI power supply that runs the charger for small packs but not much use for any of the big stuff.
zeroback is offline Find More Posts by zeroback
Reply With Quote  (Disabled)
Old Mar 12, 2012, 06:33 PM
RCTyp is offline
Smashes Things
RCTyp's Avatar
Montpelier, VA
Joined Feb 2005
Now I am really confused. I checked my DC voltages under load, and it looks fine.
But I checked AC voltage and the meter goes through a cycle about every 1 or 2 seconds where it reads less than a volt, then more then more up with about 15 and then goes to OL.
I check both of my server power supplies, they do the same thing. Checked my older 13.85 volt power supply (radio shack, 25 amp) and it does the exact some thing. So all of them are doing the same wave of AC voltage....
Old Mar 12, 2012, 06:35 PM
RCTyp is offline
Smashes Things
RCTyp's Avatar
Montpelier, VA
Joined Feb 2005
all e RC gave me an RMA, so I may never know what is wrong.
Old Mar 25, 2012, 10:26 AM
RCTyp is offline
Smashes Things
RCTyp's Avatar
Montpelier, VA
Joined Feb 2005
All e RC replaced my charger and I have the new one. Thanks much to them for standing behind their sales.
Discussion Hyperion 1420i Net3 - Will it do the job? pafalzon Electric Power Cars 9 Feb 22, 2012 07:21 AM
Discussion Hyperion 1420i net3 whytlotus Batteries and Chargers 0 Oct 01, 2010 09:17 AM
Help! Mastech turns on volts\amps stay at zero no output erh7771 Batteries and Chargers 2 Sep 18, 2010 09:39 PM
