United States, MD, Lusby
Joined Nov 2003
Altimeter Accuracy
People, myself included, tend to put a high level of faith in the altimeter readings we get with our model airplanes. This is the altimeter I use, and feel it is a good representation of the existing altimeters: http://www.wingedshadow.com/howhigh.html
Today I was out launching and flying with some friends. I was flying the Aurora wing on an Akcent-2 fuselage. Due to some structural issues with this particular wing, testing yesterday indicated a max height of 147'. I suspect 160' might be possible with the aileron linkage changes I made yesterday, but that's about it as the wing is simply too twisty (not a problem with a carbon d-box )I have previously recorded 184' with the same altimeter in the same fuselage with the Akcent-2 wing. I launch Validol an easy 10' higher (190-200') than that, and am still 20' shy of some top launchers (~220'?). All this adds up to me thinking the altimeter is working great and accurate to within a few feet. Then today I record a 227' launch with the Aurora wing. Side-by-side with some Tabooish's that I doubt were going over 175' (probably closer to 150-160'). Yes, the Aurora design in d-box form on a great fuselage with great tails should be more than capable of that altitude. Right now though, I just can't trust that reading. And no, I did not climb in altitude at all during the flight, it was a very challenging day and getting over 1:30 was hard. Perhaps the altimeter just didn't reset? My thinking however is with a tight canopy seal, the flow on launch will generate suction out the tail boom, hence lowering the pressure inside the fuselage and giving a false reading to the altimeter. Thoughts? -Sam |
I have the same unit and so far its been consistant for me. My first readings were in the 120's and since then I have worked it to the 140's to low 150's. It has shown me that at altitudes of over 4000' I can get an additional 25' from my launches. The best I've thrown was 169' in a blustry 5+mph wind and I'm certain there was some updraft in it. I've wondered about the pressure inside the fuse and how it may affect the sensor. Apon launch there must be a low pressure area at the back of the boom sucking out the air from within, however at the apex of the launch that should not be a factor.
Latest blog entry: Scale and Aerotowing
| Thread Tools | |
| Question Thick lay up + vacuum bagging + leading edge accuracy | Berrie | Composites Fabrication | 16 | Jan 24, 2012 03:14 PM |
| Discussion A simple way of measuring Kv of unloaded motor with acceptable accuracy | modisc | Electric Motor Design and Construction | 7 | Jan 19, 2012 02:20 PM |
| Question ESC with GOOD cutoff accuracy ? | cyclops2 | Batteries and Chargers | 4 | Dec 03, 2011 03:02 PM |
| Discussion Accuracy of the ICE Logger? | eJets | Castle Creations | 19 | Oct 18, 2011 07:34 AM |
| Discussion Altimeter V3 accuracy | golfietis | Eagle Tree Systems | 1 | Jul 30, 2009 04:45 PM |
