Old Mar 11, 2012, 04:42 PM
imdone is offline
Find More Posts by imdone
imdone's Avatar
United States, WA, Seattle
Joined May 2011
what weight to thrust ratio should I be aiming for?
Im building a quad from from parts that my brother gave me and dont know what size batterys to get. what weight to thrust ratio should I be aiming for on my qaud? im interested in the longest flight times of smooth flying, no flips acrobatics etc. im running nx4008's on 4s with either 10x4.5/4.7 props or 11x4.7 props.
imdone is offline Find More Posts by imdone
Old Mar 11, 2012, 04:56 PM
jpsabo is offline
Find More Posts by jpsabo
jpsabo's Avatar
Joined Feb 2011
I think thrust is 2x total weight. But, check http://www.flybrushless.com for the thrust measurements vs. RPM. If your motor is listed there you can get some insight into the power requirements as well. Basically you want to hover at about 1/2 throttle.
If your frame size permits, you could even try 12x3.8 slow-flyers. In some static testing I did, they gave a bit more thrust than the 11's.
Regards,
John
jpsabo is offline Find More Posts by jpsabo
Old Mar 11, 2012, 05:00 PM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
Regards,
John
he wants to run 4s though? 12/38 might be a bit much for 4s
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old Mar 11, 2012, 05:14 PM
milo12 is offline
Find More Posts by milo12
Joined Feb 2011
You want to hover at 50% throttle. 50% throttle= 1/3 total thrust. So for the props you mention your AUW should be around 1200-1400 grams.
milo12 is offline Find More Posts by milo12
Old Mar 11, 2012, 05:50 PM
imdone is offline
imdone's Avatar
Joined May 2011
i got a naza board if that makes a differnce
Old Mar 11, 2012, 06:13 PM
Mortimer is offline
Find More Posts by Mortimer
Mortimer's Avatar
Joined Apr 2010
It does not make any difference.
Thrust at mid throttle must equal AUW.
Mortimer is offline Find More Posts by Mortimer
Discussion Best Weight to Capacity Ratio Batteries for Multicopter use Adidas4275 Multirotor Talk 22 Feb 28, 2015 09:58 PM
Discussion Weight to thrust ratio. danford1 Foamies (Scratchbuilt) 13 Jan 06, 2013 06:03 PM
Discussion Increasing the thrust to weight ratio .. please help khaled_abobakr Power Systems 22 Aug 29, 2012 06:20 AM
At what weight to thrust ratio does a plane fly good? Nik-rc Power Systems 14 Jun 21, 2003 03:51 PM
what weight to thrust ratio for rog? varnellb Power Systems 5 Mar 26, 2002 10:13 AM
