Old Mar 11, 2012, 03:57 PM
sammy is offline
Find More Posts by sammy
senior member
sammy's Avatar
United States, SC, Okatie
Joined Jan 2002
New on 2.4Ghz; strange problems...help?
I'm new to 2.4; my radio system is called Top-fire, came with arf plane.
Sometimes I turn it on, and it works fine all day. Other days, will not work at all. Batteries, connections, switch, all check out OK. Can it be that sometimes the receiver binds, sometimes not? Can it have a weak binding that can be strengthened? I have no instructions, no binding plug. Any suggestions?
Maybe it is just a cheap radio.
Also, can other makes receivers be used with different transmitters? I have a receiver of a different make, and would like to bind it to my TX, but don't know how.
Thanks...
Sammy
sammy is offline Find More Posts by sammy
Old Mar 11, 2012, 04:52 PM
phoenixheli is offline
Find More Posts by phoenixheli
Committed heli addict...
phoenixheli's Avatar
Joined Jan 2010
Click on some of the links in this forum below:
http://www.wattflyer.com/forums/showthread.php?t=65781
phoenixheli is offline Find More Posts by phoenixheli
Old Mar 11, 2012, 05:45 PM
sammy is offline
senior member
sammy's Avatar
Joined Jan 2002
thanks for the help, but links do not answer my problem. Well, "they say" you get what you pay for. Guess its time to pitch this thing and look for a better radio.
Sammy
Old Mar 11, 2012, 10:11 PM
caseih is offline
Find More Posts by caseih
Joined May 2005
Most every brand of 2.4 GHz radio implements their own system. You cannot just bind off-brand receivers to a radio. Sometimes there are clone receivers that do work (for Spektrum and Futaba).
So if you change brands you'll need to get all new receivers.
caseih is offline Find More Posts by caseih
Question HELP - Assan 2.4ghz module causing problems. Glider-man Radios 3 Apr 24, 2015 03:11 AM
Question on screen interference between 2.4Ghz 1W amplifier and 1.2Ghz video receiver Dicecreator FPV Talk 17 Mar 03, 2013 08:30 AM
Sold [Sold] - Like new Hobby King 2.4Ghz 4Ch Tx & Rx V2 (Mode 2) HK major.monogram Aircraft - General - Radio Equipment (FS/W) 14 Feb 29, 2012 01:09 PM
Help! Corona 2.4Ghz DIY strange rang behavior seedo Radios 8 Dec 08, 2011 10:47 PM
Discussion 2.4Ghz Cypress System on Chip (SOC) Swap - Logitech 2.4Ghz Module Swap on the PicooZ EQMOD Micro Helis 20 Mar 04, 2009 12:48 AM
