Old Mar 11, 2012, 03:49 PM
Tarro is offline
Find More Posts by Tarro
Long Island, New York
Joined Jun 2008
Anyone using EZCAP?
Is anyone using EZCap to record there FPV flights? I just started using it and was wondering if there was a trick to getting a smoother video from it. Right now it kind of studders a bit when you play it back.
Tarro is offline Find More Posts by Tarro
Reply With Quote  (Disabled)
Old Mar 11, 2012, 06:43 PM
Tarro is offline
Joined Jun 2008
No one is using EZCap?
Old Mar 11, 2012, 07:25 PM
malcr001 is offline
Find More Posts by malcr001
malcr001's Avatar
United Kingdom, England, Gt Lon
Joined Nov 2007
I used it a couple of times when I first got into FPV although I soon realised that it wasent worth carrying a heavy laptop around just to use it to record video. On top of that on many occasions the ezcap software crashed half way through probably because of the large avi files it exports. A dedicated DVR is lighter, smaller, quicker to setup and pain free so I ditched the ezcap and got a DVR.
I personally havent had that problem. It could be because of the heavy file type but it also could of happened when you were actually recording. There is virtualdub which you can aparently use to record too although I only used that for video monitoring.
malcr001 is offline Find More Posts by malcr001
Old Mar 11, 2012, 07:34 PM
Tarro is offline
Joined Jun 2008
Thanks for the info, what DVR are you using?
Here is a short clip from today, it is very choppy.
Quadcopter Test video (0 min 39 sec)
Old Mar 11, 2012, 07:46 PM
CheckSum is offline
Find More Posts by CheckSum
CheckSum's Avatar
Joined Jan 2011
I used EZCap as I am sure many others have. When I have time (which I don't see happening) I would like to get the Raspberry Pi to record vid in.
CheckSum is offline Find More Posts by CheckSum
Old Mar 11, 2012, 07:58 PM
Toysrme is offline
Find More Posts by Toysrme
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
quality does not go with ezcrap
Toysrme is offline Find More Posts by Toysrme
Old Mar 11, 2012, 08:25 PM
metalfred is offline
Find More Posts by metalfred
Falling with style
metalfred's Avatar
Canada, QC
Joined Apr 2010
ezcap + virtualdub + uncompressed AVIs = lots of hdd space required and good recording quality.
metalfred is offline Find More Posts by metalfred
Old Mar 11, 2012, 08:52 PM
malcr001 is offline
malcr001's Avatar
Joined Nov 2007
I'm using the archos AV500, I wouldent recommend it though considering the DVRs out these days. I currently have twitchy fingers over the FPV japan DVR. Its the best out there other than the ridiculously priced lawmate PV1000.
Old Mar 11, 2012, 09:05 PM
rotaryboots is offline
Find More Posts by rotaryboots
United States, MT, Columbia Falls
Joined Jun 2011
I sorta use ez-cap. I bought that cheap china usb a/v adapter and tie that into the video out from my Aiptek video camera that I use as my DVR. I don't have another LCD monitor for my ground station yet, so the laptop suffices as a second monitor for other people to watch via the usb capture.
rotaryboots is offline Find More Posts by rotaryboots
Old Mar 12, 2012, 02:49 AM
patricklupo is offline
Find More Posts by patricklupo
Joined Jul 2009
I tried easycap with my netbook with every freeware vid capture app out there and all were terrible. The problem wasn't really the dongle but s/w. All of them are designed for transferring video from vcr to digital and don't support smooth full screen realtime video & audio along with low cpu usage compression.
Finally I tried the startech svid2usb2 and the free grabbee software that came with it is great. My netbook has only a 1.6ghz atrom cpu and it plays full screen video with audio, and captures with compression realtime. The dongle also works with virtualdub (easycap didn't) but the app needs a lot more processing power to compress and display the same live feed while grabbee makes light work of it. BTW, grabbee is free for d/l but only works with startech dongles; not easycap.
patricklupo is offline Find More Posts by patricklupo
Old Mar 12, 2012, 03:02 AM
Joined Jun 2011
...Adobe Premier has a capture feature that I use.
Old Mar 14, 2012, 07:51 AM
sfakias is offline
Find More Posts by sfakias
ScratchCrasher
sfakias's Avatar
Greece, Makedonia Thraki, Thessaloniki
Joined Jun 2008
Hello!
I use EasyCap and VirtualDub to record and view at the same time. By trying different settings, you can come up with a combination that allows you to view with very little latency, and record a compressed, acceptably smooth video at the same time. The recording quality is not great, but the main problem that I find is the reliability of the system. Once windows crashed on me while I was 1.5km away, over fields, and I had no backup screen back then. Luckily I knew the area well, and found my plane at no time. If you do not use the laptop screen as your main viewing device, diabling the video preview while recording in VirtualDub saves some recources. Ofcourse, you must setup your PC to avoid disc or virus scans while FPVing...It takes several tries, but it can be made to work acceptably.
sfakias is offline Find More Posts by sfakias
Old Mar 14, 2012, 09:01 AM
Exyator is offline
Find More Posts by Exyator
Joined Mar 2011
I use an EZCAP and an Asus netbook running VLC all the time. This is the quality I get:
Dodging obstacles flown w/ Dragon Link (1 min 33 sec)
The only complaint I have is that it's interlaced but that can be fixed....
Exyator is offline Find More Posts by Exyator
Old Mar 14, 2012, 02:29 PM
dpackham is offline
Find More Posts by dpackham
RC haX0r
American Fork, Utah
Joined Nov 2010
do you have to use some custom settings on the EZcap to lower latency to be able to FPV fly watching this screen too?
dpackham is offline Find More Posts by dpackham
Old Mar 15, 2012, 01:10 AM
sfakias is offline
ScratchCrasher
sfakias's Avatar
Joined Jun 2008
I was referring to setting in VirtualDub. I use only the EasyCap hardware, not the software..
Discussion anyone using the HK Dlux 160 amp esc ? OzparkPilot Giant Electric Planes 5 Mar 13, 2012 05:51 PM
Sold Genuine EZcap USB video recording interface. $15 shipped Blucross FPV Equipment (FS/W) 3 Mar 07, 2012 05:16 PM
Discussion Anyone using Turnigy 80 amp on heli ? Axefly Electric Heli Talk 1 Sep 28, 2011 04:19 PM
Discussion Dx6i with an OSD. Anyone using it? razorseal FPV Talk 15 Sep 20, 2011 11:15 AM
Discussion Anyone Using LiFePo4 Pack to Power Sailplane?? Gemini2 Electric Sailplanes 5 Sep 18, 2011 09:59 PM
