Old Apr 13, 2012, 09:10 PM
J Morgan is offline
Find More Posts by J Morgan
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Congrats Daryl! You're taking up where Nut left off. He had a history there for awhile of missing fly ins with new little ones showing up.
Tell the Mrs congrats too, she did all the work. Now you have a little wingman, wonderful.
Guess I owe you a margarita!
J
J Morgan is offline Find More Posts by J Morgan
Latest blog entry: AJ-2 Savage
Old Apr 13, 2012, 09:28 PM
skyracer068 is online now
Find More Posts by skyracer068
skyracer068's Avatar
United States, CA, Sacramento
Joined Jan 2006
I've got the margarita's!!!
skyracer068 is online now Find More Posts by skyracer068
Old Apr 14, 2012, 08:28 AM
stacker is offline
Find More Posts by stacker
stacker's Avatar
Salt Lake City Utah
Joined Mar 2004
John,
Retract install looks real nice.
Take care -- D
stacker is offline Find More Posts by stacker
Old Apr 14, 2012, 09:27 AM
J Morgan is offline
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Thanks Dave,
Actually went easier than I expected.
Working on the cowl flaps. I didn't have the foresight to mold them on the cowl, would have been easier and better. But that's water under the bridge now. I used 1/64 ply and glued them to the fuse body because I couldn't attach them to the cowl with the way I have it mounted.
J
Old Apr 14, 2012, 01:08 PM
Eddie P is offline
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Wow John as much as I love your jet builds I have to say I really have enjoyed catching up on your Spad build here. Solid craftsmanship all the way around. I have to say the foam scratch building going on today is some of the most impressive art work and engineering I've ever seen in model aviation. Thank you John for all the inspiration to so many of us.
Also, I really liked the mold work you did for the cowl. I have some EDF nacelles I've been laboring with in terms of the design - wire cut foam and wet layup or molded glass like your cowl. I think you may have finally convinced me to try a molded design. Thank you for the pictures and build log, it tipped me over the edge into doing it the way I wanted to but wasn't ready for on my own.
Eddie P is offline Find More Posts by Eddie P
Old Apr 14, 2012, 02:36 PM
peter24 is offline
Find More Posts by peter24
kings lynn, norfolk uk
Joined Sep 2007
looks like you have made excellent progress since I last checked in, been busy beavering away on my lastest build, getting plans printed for my next one, and trying to learn aboutedfs as Im currently modelling an f16 on the computer for a future build. ANYway keep up the good work, your builds are always good to follow.
peter24 is offline Find More Posts by peter24
Old Apr 14, 2012, 04:33 PM
J Morgan is offline
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Thanks Eddie Appreciate the nice comments and glad you are enjoying the build.
If you find something that you might use, then all the better.
Thanks Peter
Have the flaps hooked up and working. Did them as I usually do with odds & ends from the shop. Used brass tubing. One to fit the wire, the bigger one to slip over and flattened on top. Then I drill them for the pushrods. JB Weld locks the two tubes together and holds them on the torque tubes. Using a HS-81 servo.
The middle section was severely weakened when I cut the torque tubes in so I used two sections of carbon tube to reinforce it.
J
Old Apr 14, 2012, 07:44 PM
JerryHall is offline
Find More Posts by JerryHall
Ravenna,Nbraska
Joined Sep 2003
John
That really looks good...I love the lines on the A-1
Jerry
JerryHall is offline Find More Posts by JerryHall
Old Apr 14, 2012, 09:27 PM
J Morgan is offline
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Thanks Jerry! As you know, I've always been a big fan of the Able Dog too.
J
Old Apr 15, 2012, 03:58 PM
J Morgan is offline
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
OK, starting to get in the SEFF mode now. I leave next Saturday morning and have a few items to address. The T-33 has been plagued by rudder flutter at high speeds so I took it down from the ceiling to check it out.
But I have done some more work on the A-1. Finally got around to the aileron servo installation. All they need now are surface horns and pushrods.
Had to route the connector wire through the wheel wheel. After painting maybe it will look like hydraulic plumbing.
A week from now I'll be sitting around the tent with my buddies sipping on a cold one.
J
Old Apr 15, 2012, 04:42 PM
J Morgan is offline
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Here she is all together and on the scale. 5.5 lbs. I have to add pilot, cockpit, rudder and elev servos. I'm thinking a 6.5 lb airframe is doable. Checked the balance on it and it looks like the balance needs to be moved up about 6". A 14 oz motor plus it's extended mount and 6s-8s batts should be able to achieve my suggested CG. That would give an AUW of about 9.5 lbs. Still pretty light for this size plane but I hope the gear is up to it.
J
Old Apr 15, 2012, 06:35 PM
Lmeano_from_MO is offline
Find More Posts by Lmeano_from_MO
Fast Jets for Fast times
Lmeano_from_MO's Avatar
St. Peters MO.
Joined Nov 2007
Love the shot looking up from the tail. Are you going to use a 4 blade prop on her? You have an incredibly low weight for the size. Im not sure a foamy kit would be that lite. I just look at my builds and they gain a few ounces.
Lmeano_from_MO is offline Find More Posts by Lmeano_from_MO
Old Apr 15, 2012, 08:26 PM
Willsonman is offline
Find More Posts by Willsonman
No Hangar Queens!
Maryland
Joined May 2009
Beautiful build... I still say she's an ugly bird but the build part is stunning.
Willsonman is offline Find More Posts by Willsonman
Old Apr 15, 2012, 09:54 PM
J Morgan is offline
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Jeff,
I have a 4 blader that I bought, it's from the FMS model. Think it's 16". I'm not sure it will handle the watts of the motor I have for it. Probably maiden with a 2 blader and start hunting for a 4 blade that will work.
Hang in there Willsonman, we'll bring you around on the A-1.
J
Old Apr 16, 2012, 06:58 AM
W. X. Davis is offline
Find More Posts by W. X. Davis
W. X. Davis's Avatar
United States, OH, Reynoldsburg
Joined May 2004
Aaaahhhhhhh.............." COLD ONE "
Time is drawing near.
Lookin' good there Sensei. Think it'll be ready ??
Woody
W. X. Davis is offline Find More Posts by W. X. Davis
Build Log TF 1/8th Scale P-47 Build; Going For Detail LuftM40 Fuel Warbirds 455 Sep 17, 2016 03:18 PM
Build Log Me-329 Build............ 1/8th scale J Morgan Pusher Prop Jet Models 1022 Oct 21, 2015 09:53 PM
Sold TMRC 1-26B NIB Kit - 1:8th Scale - $125 shipped CONUS John Walter Aircraft - Sailplanes (FS/W) 1 Jun 25, 2012 08:36 AM
A-1H Skyraider 60" by LEG - Build jcarstan Slope 64 Jul 22, 2005 12:43 AM
