Old Mar 11, 2012, 03:22 PM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Build Log
A-1H Skyraider Build at 1/8th scale
Decided I wanted to replace my A-1H( that DCobra has now) and do it in a larger scale too. This one will be 1/8th scale, 75" ws and ~ 58" long. Against my better judgement it will have retracts, flaps, 4 bladed prop, and maybe even the capacity for dropping bombs. Would like to keep it around 8-9 lbs but it won't matter if I go over that, at this size it will handle a lot of weight.
I've learned from the previous two that I built that it is essential to keep the tail as light as possible. The short nosed Sandy can require a bunch of weight to balance.
Power plant TBD, I have several motors in the shop that would work I think.
We all know that foam airplanes don't like the sun. I have yet to find an easy way to protect them and using dark paints only compounds the problem. Only thing I have come up with so far is building the airframe in foam and then skinning it with balsa and glassing. I will use 3/4 oz glass/epoxy for finishing.
Let's get started:
I used a good 3 view and my overhead projector to make top, side, and front views of the Skyraider. It only had 4 cross sections so I will be relying on a 1/48th scale plastic kit for more information.
With all the foam fuses that I have carved and hollowed, I have yet to find the "best" way to hollow. A Dremel wire brush works and creates a heck of a mess, a soldering gun with copper wire works but stinks and is slow. Plus I've burnt up a couple of nice soldering irons using them that way. So I wanted to use foam blocks to create the front portion of the fuse so that hollowing would be a minimum. Used the hot wire to square them up and then the fuse templates on each end to help with visualizing the carving of it.
Just got it sort of close and then hot wired it in half and hollowed out the middle.
Pics show how I started, I'm further along and will post some more progress shortly.
BTW, I don't expect this to be too quick a build as SEFF is coming up and I have some things to get ready for it so that will slow me down. Plus we will be at SEFF for 8 days.
J
J Morgan is offline Find More Posts by J Morgan
Old Mar 11, 2012, 03:36 PM
Wilfor is offline
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Cant wait to see this
Wilfor is offline Find More Posts by Wilfor
Old Mar 11, 2012, 03:47 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
I'm here! Glad you got back home safe! w.
Waltjg is offline Find More Posts by Waltjg
Old Mar 11, 2012, 04:28 PM
peter24 is offline
Find More Posts by peter24
kings lynn, norfolk uk
Joined Sep 2007
I feel another awesome build coming on, ill have to keep an eye on this thread, as no doubt it will be full of good info and ideas as usual. Keep up the good work j.
peter24 is offline Find More Posts by peter24
Old Mar 11, 2012, 04:32 PM
matthew73 is offline
Find More Posts by matthew73
matthew73's Avatar
Melbourne, Australia
Joined Oct 2008
Way to go J. Another great build to enjoy. I love the way you do your builds. Always giving me inspiration to try new things. Cheers.
matthew73 is offline Find More Posts by matthew73
Old Mar 11, 2012, 06:43 PM
Willsonman is offline
Find More Posts by Willsonman
No Hangar Queens!
Maryland
Joined May 2009
Subbed.
Willsonman is offline Find More Posts by Willsonman
Old Mar 11, 2012, 08:05 PM
docrob is offline
Find More Posts by docrob
I've half a mind...
docrob's Avatar
New Delhi, India
Joined Jul 2005
This one's going to be a beast.....watching closely.
Best of luck with the build, J, and have an awesome time at SEFF.
Doc
docrob is offline Find More Posts by docrob
Old Mar 11, 2012, 09:50 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Thanks guys. I'll try to keep it progressing until SEFF interrupts the build for a bit.
Hey Doc!
You have been much too quiet. Thanks, we will have a great time at SEFF. All you have to do is tell them that you have a seminar in Atlanta and hop on a plane. Sound plausible?
Moving on:
I used the hot wire to cut 1" thick pieces for the rear fuse section. Then using the side and top view, glued it up. Strengthened that section with a top horizontal bulkhead and left the bottom open for now.
Decided to make a FG cowl for it and I think I will make a mold for it. So I cut out two 3" thick foam cylinders, glued them together and used the drill press ( to make sure that it is perpendicular)to glue in a dowel. Spun the drill press and sanded the cylinder "nose". Made a foam sanding block the shape of the side view, it formed the cowl nose quickly. Used Dremel tools to cut out the cowl opening. Spackled, sanded it and checked for fit on the fuse. Now it is ready for glass to start the mold process.
More progress tomorrow.
J
Old Mar 11, 2012, 10:16 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Looking forward to watching this one take shape J!
My uncle served our great country in Vietnam by working on Skyraiders, so I've always had a liking for these birds.
Sammy70 is offline Find More Posts by Sammy70
Old Mar 12, 2012, 12:19 AM
gmwahl is offline
Find More Posts by gmwahl
United States, UT, Garden City
Joined Aug 2011
Wow J, too cool! I have a skyraider also that I'm building right now. Mine has a 60" span to start and if it is a success, then I want to build a 1/5 scale one. It would have a 10' span and easily be the largest foamy warbird I can think of. I currently have the fuselage, wings and tail built, and was about to start the cowl. After seeing how you did the cowl plug, I think I will do the same thing, except I will use a giant plastic PET pickle jar and heat shrink a cowl for mine instead of fiberglass. I am excited to see another skyraider being done, and will be following this one closely!
Best of luck!
gmwahl is offline Find More Posts by gmwahl
Old Mar 12, 2012, 01:35 AM
FlyDave is offline
Find More Posts by FlyDave
Crash proof pilot
FlyDave's Avatar
Svizzera, TI, Bellinzona
Joined Oct 2005
Yahooooo , a new thread by John !
I can't start my day in office without a cup of coffee and the new posts on J threads :-)
FlyDave is offline Find More Posts by FlyDave
Old Mar 12, 2012, 06:25 AM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Our thanks to your uncle for his service Sammy.
Those poor old Able Dogs looked like they were rode hard and put up wet, don't they.
Good luck with yours too Mike. Feel free to post some pics of it if you desire.
Just be careful Dave, make sure it's on break times.
J
Old Mar 12, 2012, 08:37 AM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
The rear blocks forming the top of the fuse are tack glued on. Once the shape is finished I will pull them off and hollow. Got to keep it light back there.
J
Old Mar 12, 2012, 08:52 AM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Decided it was time to go to the wing center section so I could cut out the wing saddle. I hand draw all my airfoils. This one is a thick one just like the A-1 had and is semi-symmetrical. Hopefully that will help with a reduced need for down thrust on the motor. I love the Clark Y but with it's flat bottom increased climb with added power is a nuisance.
Drew the airfoils and made templates for root and tip ribs from 1/8" ply capped by copper tape.
Cut the blanks from two pieces of 2" white foam glued together with spray adhesive. I normally use 4" thick white foam but am running short of it. There is actually a plus to this way because the seam between the two gives you a clearly visible line around the blank. Saves having to measure and mark a 4" thick piece for the middle reference lines.
Cut the core and then sheeted with 1/16" soft balsa using Gorilla glue spread VERY thin.
Plenty of weight to compress the wing beds.
Once the center section was trimmed I used it to cut out the wing saddle in the fuse. The wing will be set at 1 degree positive.
I also have two layers of 3/4 oz glass on the engine cowl and will give it an add'l two coats of epoxy to protect it from the hot glue I will use to glue on the parting planes for the mold.
So this is where we are now.
J
Old Mar 12, 2012, 09:50 AM
docrob is offline
I've half a mind...
docrob's Avatar
New Delhi, India
Joined Jul 2005
Originally Posted by J Morgan View Post
Hey Doc!
J
Heh , I'll give it a shot. Problem is, there's no "them". As the boss man, I have to lead by example
Doc
Build Log TF 1/8th Scale P-47 Build; Going For Detail LuftM40 Fuel Warbirds 453 Jan 03, 2016 02:10 PM
Build Log Me-329 Build............ 1/8th scale J Morgan Pusher Prop Jet Models 1022 Oct 21, 2015 09:53 PM
Sold TMRC 1-26B NIB Kit - 1:8th Scale - $125 shipped CONUS John Walter Aircraft - Sailplanes (FS/W) 1 Jun 25, 2012 08:36 AM
A-1H Skyraider 60" by LEG - Build jcarstan Slope 64 Jul 22, 2005 12:43 AM
