Old Mar 11, 2012, 03:11 PM
genrlst is offline
Find More Posts by genrlst
Joined Dec 2011
Can the Turnigy 9x with FrSky DIY kit be used with simulator
Can someone please tell me if the Turnigy 9x with FrSky DIY kit can be used with a simulator?
genrlst is offline Find More Posts by genrlst
Old Mar 11, 2012, 10:15 PM
caseih is offline
Find More Posts by caseih
Joined May 2005
I don't think the DIY kit has much to do with it.
Any trainer system that uses an audio cable should work with the trainer port on the 9x. It's also possible that any JR-compatible Trainer-to-USB cord should work with it. The signal levels are different in the 9x, but it probably would work.
That is unless you hooked your DIY kit directly to the trainer port, which would mean you'd have to disconnect it to use it with a computer.
caseih is offline Find More Posts by caseih
Old May 23, 2012, 01:19 PM
genrlst is offline
Joined Dec 2011
Thanks. I upgraded to the ER9x software and supposedly they have a fix for this. we'll see if it works
Found Frsky V8HT DIY & or Receiver for Turnigy 9x Medicineman76 Aircraft - General - Radio Equipment (FS/W) 4 Feb 11, 2012 12:24 PM
Sold Used Turnigy 9x with Frsky telemetry ($120 shipped) Whoaty55 Aircraft - General - Radio Equipment (FS/W) 1 Dec 09, 2011 07:44 AM
Discussion Simulator problems with turnigy9x (frsky DIY soldered) ER9x bhavikshah Radios 2 Nov 13, 2011 06:35 AM
