Old Mar 11, 2012, 03:06 PM
EpoXi is offline
Find More Posts by EpoXi
Joined Feb 2007
Need help setuping first glider - Hybrid-DL 1.5M
Hi guys,
I live by the Mediterranean sea, and we have quite high cliff near the beach
that provides great lift most of the year.
I'm flying RC plane for some years, and I want to try fly a glider.
Can you help me start?
What type of glider do I need?
Thanks.
EpoXi is offline Find More Posts by EpoXi
Old Mar 11, 2012, 11:06 PM
slopemeno is offline
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
I'd look at a Zagi, Bee, Wing Warrior Raider, or any of the 48" EPP combat wings. Built true and set-up right they can fly in light lift or 50 mph wind.
Does you transmitter have a delta mix?
slopemeno is offline Find More Posts by slopemeno
Old Mar 12, 2012, 06:06 AM
EpoXi is offline
Joined Feb 2007
Yes, I got DX7.
Can you be more specific about a model that I should get or build?
Should it have a motor?
Old Mar 12, 2012, 09:09 AM
this space for rent
slopemeno's Avatar
Joined Jan 2003
I like the simplicity of pure slope planes. If you come over to the Slope forum you'll see a lot more examples.
I like the Zagi 5C myself. Keep the throws small. These planes are a great all-arounder for the slope.
Old Mar 12, 2012, 12:34 PM
theghosttanker is offline
Find More Posts by theghosttanker
United States, NY, Lewiston
Joined Apr 2011
get the cheapest glider you can find and throw it off the cliff. Enjoy! After you have flown it for a few hours, you will start to know what kind of more expensive plane you might want.
theghosttanker is offline Find More Posts by theghosttanker
Old Mar 12, 2012, 01:56 PM
davidjensen is offline
Find More Posts by davidjensen
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
No No you need the latest F3F ship outfitted with Lipo batteries and the best new high voltage servo's and it will only cost you about $2,000 to $3000.
Really you will need to do some research and I'm sure that there is someone near who has sloped these cliffs before. With Cliffs your plane options are a question of cubic $$$$. A mistake or a equipment malfunction may cost you the entire investment if it is not retrevable. This is where the flying wings are great. Minimal investment and they can hit the ground at 50 mph without damage. I prefer the Wing Warrior Ridge Runner combat wing.
davidjensen is offline Find More Posts by davidjensen
Old Mar 12, 2012, 02:20 PM
EpoXi is offline
Joined Feb 2007
I have seen some people flying gliders at these cliffs, and acctually I did it my self too.
I made Zagi from corrugated plastic sheet with some plan I found on the web and it flew quite well utill I made a mistake and got out from the lifting air zone.
I managed to find it (after some climbing) and it was ok, but never had the guts to try again after that.
The thing is that my Zagi was motor free, if I had a motor I could use is to get out from the mistake that I made.
That is the reason I need you to help me choose somthing that will be right for me =]
Old Mar 13, 2012, 02:38 AM
this space for rent
slopemeno's Avatar
Joined Jan 2003
Have you been to the Trick R/C website? They make the Zagi. They make powered versions as well, so feel free to get a powered one.
Old Mar 13, 2012, 05:24 AM
Circlip is offline
Find More Posts by Circlip
Bradford West Yorkshire, UK
Joined Apr 2010
If you're wanting a motor fitted to it, why bother with the cliff site?? Until you can retrieve it from below eye level without having to go rock climbing, use what you've got and practice some more.
Regards Ian.
Circlip is offline Find More Posts by Circlip
Old Mar 13, 2012, 05:03 PM
EpoXi is offline
Joined Feb 2007
The cliffs are very high - maybe 80 meters and at some point its almost 90 degrees, Its not possible to retreive the aircraft every time.
If you make a mistake its a big problem.
Any other suggestions?
BTW how much its cost the simplest reciever for the DX7 for something like Zagi wing?
Old Mar 13, 2012, 06:05 PM
Crash Prone is offline
Find More Posts by Crash Prone
Crash Prone's Avatar
United States, WA, Port Orchard
Joined Feb 2011
Hobby king orange reciever, spektrum compatible, less than $15 I think.
Other suggestions? Well, if it's light lift you are worried about, you could look at a balsa floater, like a Gently Lady ARF, but you would be sacrificing speed and maneuverability.
The suggestion of a good foam wing is a great place to start. There are plenty to choose from, with the ones above being some of the most popular. Another to consider would be the Ritewing TL50, which has a more symmetrical airfoil and will perform better inverted or on outside loops, etc. It also likes to go really fast.
Another great option for a first glider is the Radian. Dead simple, easy to fly, and it has a motor so you can fly from a flat field or save the plane if the slope lift dissapears on you suddenly. Radian comes equipped with a Spektrum reciever.
Crash Prone is offline Find More Posts by Crash Prone
Old Mar 15, 2012, 01:13 PM
EpoXi is offline
Joined Feb 2007
Thanks you guys for all the comments.
I have been thinking, and decided to try the Thermal section of glider.
we have large open farming area north to my city that I can acces
so I found this model at HK:
http://www.hobbyking.com/hobbyking/s...00mm_ARF_.html
It seems really nice and the reviews are good.
Can you help me with the setup?
ESC, motor, servos etc...?
I dont mind buying the electronics somwhere else then HK if you think there is better stores.
Old Mar 15, 2012, 02:44 PM
Joined Feb 2011
Who melted the boom?
Old Mar 15, 2012, 02:56 PM
EpoXi is offline
Joined Feb 2007
What?
Discussion First LiPo plane, need some help connecting R0yalty Batteries and Chargers 1 Mar 04, 2012 07:11 PM
Discussion my first glider need help with tips on how to set it up newtohelis Electric Sailplanes 2 Dec 15, 2007 02:06 AM
Need help with first glider : Mini-Ellipse QuestMGD Electric Sailplanes 13 Nov 22, 2002 08:13 AM
Need help building my first foam cut glider Steven9026 Electric Sailplanes 8 Nov 21, 2001 08:17 PM
First Electric Glider/Need Help rdghmk Electric Sailplanes 4 Sep 25, 2001 08:24 AM
