Old Mar 11, 2012, 02:39 PM
g_kandylakis is offline
Find More Posts by g_kandylakis
free flight or micro RC ???
g_kandylakis's Avatar
Greece, Central Macedonia, Thessalonika
Joined May 2006
Build Log
1/20 scale SPAD XIII
Hi everybody,
It has been a while since my last model here, time has come to start a new one...
Inspired by spikkkkkkkk's great build thread of his static 1/16 scale SPAD, I decided to finally start work on my own.
I know for sure I won't reach the same standards, but I 'll try to make a good job with it. It will be built for flying, so I have a good excuse during comparisons
My model will be built at 1/20th scale, which makes it rather small at 404 mm (16") wing span.
It is going to be 4-channel RC, if and when I finally figure out the ailerons operation. Have yet to study it... The RX system will be a Spektrum AR6400.
Projected weight is a very optimistic 40 grams.
This will be a slow build, plenty of other projects are running along, but I wanted to start it, so that I can switch between them, when I get fed up with one. So, please have patience I only hope it won't take the years it took my d.H.9.
George
g_kandylakis is offline Find More Posts by g_kandylakis
Old Mar 11, 2012, 02:51 PM
Joined May 2006
I started work on the wings, since I also wanted to try something I had dismissed as a work method earlier - laser cut parts...
Having occasional access to a laser cutter, I drew up and cut the wing ribs and was quite amazed at the result, especially if you consider the small model size.
Accurate to the 0,1mm, even the alignment pin holes of 0,6mm diameter came out that... I was tempted to draw lightening holes, which would be quite time consuming with my traditional ply-template / sanding /file method.
All ribs are cut and stacked together for some light sanding and the first wing panel is on the building board.
Scale rib number makes this a rather slow job...
George
Old Mar 12, 2012, 07:40 AM
Joined May 2006
Bottom left wing almost finished. Needs planking and trailing edge completion, before going into details...
Old Mar 12, 2012, 09:57 AM
Joined May 2006
a couple of hours later...
main wing structure finished.
Turned out quite light too
Now to the other side...
George
Old Mar 12, 2012, 10:18 AM
Stone1295 is offline
Find More Posts by Stone1295
AMA 937634
Stone1295's Avatar
United States, AK, Anchorage
Joined Jan 2010
Nice work on the ribs!
-Mike
Stone1295 is offline Find More Posts by Stone1295
Old Mar 12, 2012, 10:34 AM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
As semi relevant info:-)
Scalloped trailing edges as found on 'some' WW1 designs were due to the covering fabric shrinking and pulling in the ...wire... used as the trailing edge.
Some modellers have tried a prebent very thin ali wire or tube as facsimile of it.
Bare is offline Find More Posts by Bare
Old Mar 17, 2012, 01:33 PM
Joined May 2006
some progress done with the top wing...
The two panels were built separately but with the ailerons attached.
They will be separated later between the two sub-spars, after final shaping and sanding.
Plenty of minor rework needed for various fittings slots etc...
Old Mar 17, 2012, 01:35 PM
Joined May 2006
sanded the lengths of the spars and leading edge, so that they meet at the proper distance...
added a center rib and fixed the laminated curved trailing edge at the center section.
slowly sanded the ribs so they mate accurately to the circular trailing edge...
everything glued together...
added small lengths of carbon fibre strip at each spar, for local strengthening at the center.
Old Mar 17, 2012, 01:38 PM
Joined May 2006
"Finished", one piece wing...
Weight as is, 2,6 grams. I hope that plenty of that will be sanded away at the leading and trailing edges, I aim for 2,5 grams after planking.
Bottom wing panels pictured above were 0,9 grams each...
Yes, probably the total weight of these components is about the same or less than that of the dust on the wings of the usual models posted in this sub-forum
That is it for now...
George
Old Mar 22, 2012, 05:25 AM
Joined May 2006
Top wing sheeting added...
Ailerons were separated and the extra spars added.
Work has started on the various details, like the aileron horn cut-outs.
Old Mar 22, 2012, 01:05 PM
Led Zepplin is offline
Find More Posts by Led Zepplin
Fly, dangit!!!
Led Zepplin's Avatar
Little Rock, AR USA
Joined Jan 2007
George - Phenomenal start, those wing panels look amazing for a 16" span! If this one turns out anything like your DH-9, it will be an award winner for sure!
J. B.
Led Zepplin is offline Find More Posts by Led Zepplin
Old Mar 22, 2012, 03:27 PM
Pat Lynch is online now
Find More Posts by Pat Lynch
a.k.a Maltone
Pat Lynch's Avatar
Australia, NSW, Goulburn
Joined Jan 2005
A great start George It's hard to believe the size is so small - I imagine you COULD handcut all those ribs but modern methods are hard to ignore.....
Pat
Pat Lynch is online now Find More Posts by Pat Lynch
Old Mar 22, 2012, 03:37 PM
Joined May 2006
Thanks J.B., Pat...
I do not know how it will turn out... I will try my best, but I do not want it to be a very long project. I aim for the same level as the d.H.9 but time will show if I find the patience.
Pat, you are right, this is how I used to do it...
I admit I was not that sold to laser cutting at first.
Now I can safely say that it is faster, of course, including the CAD time. But it is also (annoyingly) much more accurate. A 0.6mm pin locating hole was indeed 0,6mm
Anyway, there is still so much more to do, that a little laser cutting does not change the nature of scratch building.
George
Old Apr 12, 2012, 05:54 AM
Joined May 2006
Back to more "traditional" ways...
Fuselage sides done, added some rigging for extra stability. Next is to make the fuselage box and then formers, stringers, etc...
Slow progress indeed
George
Old Apr 15, 2012, 01:10 AM
brkyno is offline
Find More Posts by brkyno
Joined May 2011
Hi George
I am new to this hobby have been looking at
the forums for while getting inspired. Looking
forward to watching this build especially if anything
like the DH9.
brkyno is offline Find More Posts by brkyno
Build Log Pat Builds a 1/4 scale SPAD XIII Pat Lynch Scale Kit/Scratch Built 513 Aug 08, 2015 08:04 AM
Build Log GAAM 1:1 scale Spad XIII us185damiani Scale Fuel Planes 38 Mar 05, 2014 09:26 PM
Sold Rake/Manzano 54" Spad XIII trident58 Aircraft - Electric - Airplanes (FS/W) 0 Mar 04, 2012 07:01 PM
Sold Electrifly SPAD XIII LPU or delivered to WRAM Show CarreraGTSCS Aircraft - Electric - Airplanes (FS/W) 1 Mar 03, 2012 09:25 PM
