Old Mar 11, 2012, 01:16 PM
420TEE is online now
Find More Posts by 420TEE
North Central TN USA
Joined May 2006
Clear coat.
I haven't done much with clear coat. I have a pretty good black finish on a fiberglass boat painted with Rustoleum gloss but a couple of spots are not as good. I want to clear coat it. Should I do a fine wet sand before using the clear? I'll let the black dry at least a week first.
420TEE is online now Find More Posts by 420TEE
Old Mar 11, 2012, 01:48 PM
catchthis is offline
Find More Posts by catchthis
catchthis's Avatar
USA, NY, Laurel
Joined Aug 2010
please post pics including materials and clear used as I too use rustoleum and would like to know for future builds.
catchthis is offline Find More Posts by catchthis
Old Mar 11, 2012, 02:40 PM
glgirvin is online now
Find More Posts by glgirvin
Milford Mi.
Joined Jan 2011
clear coat
Hi guys, Just remember when sprying clear coat to do it with thin coats.Spray a fog coat on and let it dry for about 20-30 minutes and repeat.On the third or fourth coat , you can spray a little heavier. When done , let it dry for 48 to 72 hrs.
If you read some the cans, it says to recoat within 1 hour or wait 72 hrs. This is
because of the retarder they put into rattle cans to lengthen shelf life. When I am not in a hurry, I use Klass Kote urathane clear and only have to wait over night to sand or recoat.It is a two part mix and relies on chemical reaction to cure.It does have a strong odor so needs to be done outside or in well ventilated spray booth. Thank you,Gary
glgirvin is online now Find More Posts by glgirvin
Discussion Clear coat houseboat 3D Foamies 4 Jan 23, 2012 03:18 PM
Discussion Clear fill for a scrape in clear coat? wingbeat Painting and Finishing Tips 4 Oct 28, 2007 11:01 AM
Clear Gloss coat? Paul Willenborg Scale Kit/Scratch Built 8 Feb 24, 2003 08:33 PM
Safe clear coat over poly orectolobus Electric Plane Talk 3 Jan 08, 2002 01:58 PM
