Old Apr 01, 2012, 02:39 PM
Jack the R is offline
Find More Posts by Jack the R
Jack the R's Avatar
Joined Aug 2009
2dogrc has them, but not at the Nitroplanes price. Might as well get a Telink.
Jack the R is offline Find More Posts by Jack the R
Old Apr 03, 2012, 09:54 AM
Westwood is offline
Find More Posts by Westwood
Canada, BC, Burnaby
Joined Oct 2010
Tech One RC 4 Channel Aeolus Depron Kit (5 min 8 sec)
westwood's channel ---- http://www.youtube.com/user/9westwood9
Westwood is offline Find More Posts by Westwood
Old Apr 03, 2012, 10:49 AM
wolfewinde is offline
Find More Posts by wolfewinde
My Co-Pilots Rock!!
wolfewinde's Avatar
United States, FL, Clearwater
Joined May 2011
Looks like she flew well in some wind, Westwood. Thanks for posting that one
Wolfe
wolfewinde is offline Find More Posts by wolfewinde
Old Apr 03, 2012, 12:41 PM
am534615 is offline
Find More Posts by am534615
Joined Nov 2011
Originally Posted by intotheblu View Post
would love to try the swift or the yak by techone, where the heck can you possibly buy one .....
I bought mine from Epphobby, nothing but great service and free shipping for any orders over $100
am534615 is offline Find More Posts by am534615
Old Apr 04, 2012, 09:31 AM
skittum is offline
Find More Posts by skittum
Joined Mar 2012
I lost the tail wheel off of my Extra 330.What is a good replacement wheel? Also if you tighten the piece down on the servo arm with the set screw that pins the control rod ( sorry I don't know the name of this piece, is it clevice?) it causes binding. Do I need to upgrade my control arms or am I missing something. And I want to use hinges for my control surfaces, I already tore my rudder loose. What is a good product for this and why does everyone talk about blenderm instead of hinges? Wouldn't hinges be better?
skittum is offline Find More Posts by skittum
Old Apr 04, 2012, 02:53 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
The push rod connector should spin freely on the control horn that glues into the wing. The bolt nut that holds it on cannot be too tight, however, you MUST put a dab of CA or hot glue on the back of that nut/bolt so it does not fall off in flight. With that done, the servo should still move freely when you tighten the screw that secures the push rod itself.
I had one of those come loose on the Swift - even though I thought I had CA'd the bolt in place. Caused the elevator push rod to fall off - and then a crash. Repaired now, but lesson learned to make sure those push rod connectors are secure.
Just about any tail wheel will work, or you could just make a slit in the bottom of the fuse and glue in a short piece of popsickle stick or carbon fiber rod to make a tail skid.
Wolfe
Old Apr 04, 2012, 03:30 PM
skittum is offline
Joined Mar 2012
Oh, I put the z-bend on the control horn and put the little set screw deal on the servo arm. I am having problems with my rudder and elevator not wanting to re- center. I think I am going to try to find some ball and rod end stuff like is on my cheap heli. I can see the push rods flexing without any load.
I really liked that little foam wheel that was on there. Any idea on the diameter of it. I'm guessing 1/2". Not that I land too often anyway, but still...
Old Apr 04, 2012, 03:40 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
I would think anything from 1/2 to 1 inch would work.
Wolfe
Old Apr 04, 2012, 07:22 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Got in a few more flights on the Swift tonight in about 10 mph winds. She handled it very well. I really do like this airplane.
Wolfe
Old Apr 05, 2012, 12:48 AM
epphobby is offline
Find More Posts by epphobby
epphobby's Avatar
United States, PA
Joined Aug 2011
Wolfe
Instead of CA, i use blue thread locker and IMO, it works better as its intended for metal to metal application
epphobby is offline Find More Posts by epphobby
Site Sponsor
Old Apr 05, 2012, 09:21 AM
skittum is offline
Joined Mar 2012
I like my Extra 330 but it is too big for backyard flying at my skill level. I am going to build a smaller model> are any of techone's smaller models as durable? I like the Malibu 2 for it's clean lines but I understand it is not EPP
Old Apr 05, 2012, 09:33 AM
skittum is offline
Joined Mar 2012
Also I have been wondering about boring some holes through the fuse to lose some weight. If I didn't go overboard and I put a skin of clear packing tape over it wouldn't this give the same result as milling? The fuselage seems a little bulky. I am also wanting to round off the underside of the fuse like the top is.
Old Apr 05, 2012, 10:35 AM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
I doubt that boring holes would make it enough lighter to make a significant difference. Best just to go with a smaller plane, even if it isn't EPP foam
Wolfe
Old Apr 06, 2012, 04:00 AM
Jack the R's Avatar
Joined Aug 2009
Skittum, Depron planes are for people who don't crash. Depron breaks all over the place. Take a look at the EPP Mini-Breeze Pro. It won't fly in wind but it should do what you want on calm days.
Old Apr 07, 2012, 11:36 AM
gr8taz nitro is offline
Find More Posts by gr8taz nitro
lawndart aerobatic ace!
gr8taz nitro's Avatar
Joplin, Misery
Joined Mar 2007
Has anyone else got the 47" yak? I just finished building mine and so far I'm pretty impressed. I was looking for something inexpensive to fly that was big enough for me to see.
I set it up with an e-flite 480 1020kv, 45amp esc, and turnigy mg90s servos. I got a couple of 1300 3s 25c packs to fly it with, but with the heavier servos in the tail it won't balance without adding weight, or switching to my heavier TP 2250 packs.
Has anyone else got this one or flown it? What setup did you use?
gr8taz nitro is offline Find More Posts by gr8taz nitro
Cool Twisted Hobbys Owners Thread! hercdriver7777 3D Foamies 12953 Today 12:13 AM
Discussion Dynam Warbird Owners Thread Merlin Power Electric Warbirds 1550 Jun 26, 2016 04:40 PM
Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* Z06 Tony Multirotor Talk 1792 May 22, 2016 03:04 PM
Discussion Classic Parkzone Radian Owners thread wingymaster Electric Sailplanes 9 Jun 16, 2015 02:52 PM
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
