Old Feb 01, 2013, 07:54 PM
Saqueeb is offline
Find More Posts by Saqueeb
Saqueeb's Avatar
United States, MN, South St Paul
Joined Dec 2011
What kind of servos do you guys use on your Swift? I have been tearing up hxt900's with just normal 3d nothing super aggressive. I'd like something better without spending $20+ per servo.
Dave
Saqueeb is offline Find More Posts by Saqueeb
Old Feb 01, 2013, 08:22 PM
rpstar is offline
Find More Posts by rpstar
rpstar's Avatar
Dacula, GA
Joined Feb 2008
Dave
Well, hxt900's just plain suck. Get something with metal gears and torque equivalent to a HS-65BB. HXT900's are for crap foamies under 40" wingspan (unless it's some cheap, cheap glider or something). Supposedly the Powerhd servos are good but have not used them (check valuehobby.com for them). Could also try the E-flite or Parkzone digital metal gear servos. They are ok and sell for about $13 each.
rpstar is offline Find More Posts by rpstar
Old Feb 01, 2013, 08:35 PM
Pilot Fatigue is offline
Find More Posts by Pilot Fatigue
Joined Jan 2012
Hs-65mg or 5065mg. Was fortunate to buy a bunch at dealer cost but I know there are good ones out there for a lot less. ....just dont have the hitech name(and price).
Pilot Fatigue is offline Find More Posts by Pilot Fatigue
Old Feb 01, 2013, 08:40 PM
wolfewinde is offline
Find More Posts by wolfewinde
My Co-Pilots Rock!!
wolfewinde's Avatar
United States, FL, Clearwater
Joined May 2011
I have been using the HS 65's. But I have also had good luck with Emax metal gear servos on other planes - a lot less expensive
Wolfe
wolfewinde is offline Find More Posts by wolfewinde
ahicks is offline
Find More Posts by ahicks
United States, MI, Waterford Charter Township
Joined Aug 2008
Dave,
I'd go metal gears on the tail at minimum? HK has a few different ones (5.00 -8.00) in stock at the US warehouse, so no long delay in getting those? Turnigy/TGY, Corona, Hextronic, hard to go wrong at these prices? -Al
ahicks is offline Find More Posts by ahicks
Old Feb 02, 2013, 03:26 AM
foamyflyerr is offline
Find More Posts by foamyflyerr
Joined Jun 2012
Originally Posted by ahicks View Post
Dave,
I inherited a Techone SU-31 from a friend that sold it to me bare bones without any electronics on it. I went with HS 65MG servos all the way around. An investment I know but I have been flying this thing like crazy five or so days a week now for about a month now and it is silky smooth in the air. No regrets on my part on putting good servos on a plane that I am going to fly that much. Ya get what you pay for.
foamyflyerr is offline Find More Posts by foamyflyerr
Old Feb 02, 2013, 06:09 AM
ahicks is offline
Joined Aug 2008
Regarding "you get what you pay for"? I wouldn't knock these Chinese servos much until you try them? I get how you might use more expensive servos for contest flying or in more valuable planes, but the cheap mg servos actually work pretty good given a chance, especially in a foamie you plan on beating the tar out of? On the plus side as well, you could wear them out and replace them at least 4 times for what you'd pay for a Hitec? Dunno, they just make more sense to me. Everyone's different!
Old Feb 02, 2013, 07:52 AM
rpstar is offline
rpstar's Avatar
Dacula, GA
Joined Feb 2008
That's what they were saying above. Check out the Emax or PowerHD servos. I can't speak to their centering/jitter but I've heard other flyers who I trust saying good things at least about the Powerhd ones. Hitec servos are precise and don't jitter like cheap servos such as the HXT900s. Hopefully the same is true of PowerHD or others but I admit i'm skeptical given the cost. In any case, they are so cheap it does not hurt to try them.
Maybe try these:
http://www.valuehobby.com/radio-syst...ini-servo.html
Just ordered two of them myself from heads up rc. Cheaper shipping if you are just buying servos. I'll report how they work on the tail later.
Old Feb 02, 2013, 06:35 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Got in a half a dozen flights on the SU-31 this afternoon.. A bit windy, but she flew well enough. I am mostly still working on flat rudder turns. I really have trouble keeping the throttle constant while I work the rudder
Wolfe
Old Feb 02, 2013, 07:47 PM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
Been using cheap tower pro 9g for years without and issues, centring has always been good, just built a second souka with cheap HK white 9g servos, had about 10 flights so far with no issues.
scousethief is offline Find More Posts by scousethief
Reply With Quote  (Disabled)
Old Feb 03, 2013, 03:36 PM
finguz is offline
Find More Posts by finguz
finguz's Avatar
United States, CA, San Diego
Joined Mar 2012
Hey guys, I'm setting up the travel on all the surfaces of my 35.4" Techone Extra 330 EPP but had a question. Maybe a stupid question, but I need help.
My ailerons are beveled, so when I measure the recommended throws am I supposed to measure from the part closest to the fuselage, or the part furthest away? It's obvious the two would be pretty different.
finguz is offline Find More Posts by finguz
Old Feb 03, 2013, 05:08 PM
ahicks is offline
Joined Aug 2008
Farthest usually....
Old Feb 03, 2013, 07:42 PM
finguz is offline
finguz's Avatar
Joined Mar 2012
Thanks ahicks. It's not as bad as I thought, because if you look at the picture the aileron "hinge" joint isn't straight (perpendicular to the fuselage), but instead it follows the aileron trailing edge... however it is still at least 1 cm wider on the side closer to the fuselage, than the wing tip side. I will try furthest out (wing tip) like you say, thanks.
Also, the foam on some of my hinges looks a little thin, like something could happen to it one day.. is this normal and is there anything I can add like tape (even though it doesn't stick very well) to ensure the aileron won't tear off the wing? Maybe it's not as bad as I think. I haven't flown it because I'm still waiting on batteries.
Old Feb 03, 2013, 08:01 PM
Vince_TT is offline
Find More Posts by Vince_TT
United States, PA, Philadelphia
Joined Dec 2011
Actually the live hinges on my TechOne planes (three of them) are too stiff than my liking, which reduces the throw and puts extra load to the servos. I cut two third of the live hinge open and add welder hinge for the whole length on the ailerons. You can google "welder hinge" or "hot glue hinge) and watch the instruction on YouTube.
Vince_TT is offline Find More Posts by Vince_TT
Old Feb 03, 2013, 08:49 PM
ahicks is offline
Joined Aug 2008
Geez, there's a disconnect on where to measure I think? Travel is usually measured at the widest part of the control surface! So ailerons and elevator are measured closest to fuse, rudder near the bottom?
Regarding the thin hinges, I would fix them when/if you manage to tear them up? I got into the mindset of reinforcing the ones on my first plane, wishing I hadn't now. Not only are you adding weight, they're getting stiffer, harder for the servo to move. Lesson learned a long time ago - you don't build a plane to crash!
Cool Twisted Hobbys Owners Thread! hercdriver7777 3D Foamies 13230 Sep 22, 2016 11:15 AM
Discussion Dynam Warbird Owners Thread Merlin Power Electric Warbirds 1567 Aug 21, 2016 01:57 AM
Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* Z06 Tony Multirotor Talk 1792 May 22, 2016 03:04 PM
Discussion Classic Parkzone Radian Owners thread wingymaster Electric Sailplanes 9 Jun 16, 2015 02:52 PM
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
