Old Mar 27, 2012, 04:04 PM
Jack the R is offline
Find More Posts by Jack the R
Jack the R's Avatar
Joined Aug 2009
It's fun to see the difference lightening a plane makes. They get much more flyable. I couldn't knife edge the Sukhoi with the heavy power system, but with the light power system I can.
Jack the R is offline Find More Posts by Jack the R
Old Mar 27, 2012, 05:58 PM
wolfewinde is offline
Find More Posts by wolfewinde
My Co-Pilots Rock!!
wolfewinde's Avatar
United States, FL, Clearwater
Joined May 2011
I am running the SU on the stock power system with an 1800 3s. I really like the way she flies. I am mostly still working on rudder turns - can't knife edge worth a crap yet.
Wolfe
wolfewinde is offline Find More Posts by wolfewinde
Old Mar 27, 2012, 09:02 PM
Jack the R's Avatar
Joined Aug 2009
Wolfewinde - My Sukhoi is a different model than yours - Link
You wouldn't get anywhere flying your Sukhoi on my power system
I'm not good at knife edge with my Sukhoi either. I've got an F3P plane that will knife edge all day though. It doesn't care whether it's right side up or on its side. When I fly the Sukhoi I use the rudder input for the F3P plane and the Sukhoi falls out of the sky.
I'm working on flying inverted with it, but I don't think it is trimmed and balanced well enough.
Old Mar 27, 2012, 09:28 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Heya Jack,
Yeah - that is an entirely different airplane. I have been flying a lot of inverted lately - trying to make my reflexes instinctive. I think I am making progress, but not there yet. Am also really working on "flat" rudder turns and circles that are half upright and half inverted.
Should get the motor and servos for the Swift tomorrow according to Hobby Zones tracking info. Hope to finish that one up by the weekend.
Wolfe
Old Mar 28, 2012, 12:52 AM
Jack the R's Avatar
Joined Aug 2009
Originally Posted by wolfewinde View Post
Heya Jack,
Wolfe
What's the prob with the flat rudder turns? Learning to leave out the aileron? Or are you trying to do it with a competitive level of perfection?
I believe my problem with inverted may come down to having the plane tail heavy for hovering, and general manueverability. I've got to fly with a bit of down trim, which becomes up trim when inverted, and makes the tail want to drop more. Instinctively I'm putting in more down elevator at the same time, so the plane climbs out. I need to pull up instead of pushing down - that's messed up.
BTW you need to send me some planes. You've got too many
Old Mar 28, 2012, 09:27 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Heya jack,
No real problem with the flat rudder turns except that I have not really ever done them. The SU-31 does them fairly easily - I just need to get more instinctive on up elevator and opposite aileron. I still have to think about that some.
Had a mid air collision tonight with a Gemini - not too much damage I don't think - more on the Gemini. Bummer.
I did try a 1000 mah 3s on the Extra 330 tonight - flew better I think - still getting 4 to 5 minute flight times, so that is OK
Got all the electronics installed in the Swift tonight. Just need to add one control horn and push rods now. Getting close to flyable
Wolfe
Old Mar 28, 2012, 11:15 PM
Jack the R's Avatar
Joined Aug 2009
I've watched videos of the Swift and Su-31. I was impressed with how slow the Swift flies. I'm pretty sure I can fly it here. How big are the stock wheels? It'd be fun to have a plane I can land in a proper manner again.
I'm getting used to knife-edging my Sukhoi - the big trick is having enough speed to make the little fuselage work. And of course being light - you can't go wrong with it.
Old Mar 29, 2012, 12:17 AM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
The stock wheels on the Swift and SU-31 are both about 1 1/2" to 2" wheels. They are decent wheels and I like the way they mount them on the fuse. The SU-31 slows down nicely, I am expecting the Swift to do that too. Will let you know
Wolfe
Old Mar 29, 2012, 01:39 AM
Jack the R's Avatar
Joined Aug 2009
Hmm, I was hoping the Swift wheels would be over 2". I can take off from grass and gravel with a 3" wheel, but not a 1 1/2" wheel.
Old Mar 29, 2012, 08:50 AM
MaddSkillz is offline
Find More Posts by MaddSkillz
Intergalctic Coffee Enthusiast
MaddSkillz's Avatar
United States, OK, Tulsa
Joined Jun 2011
I'm a Venus owner and love the plane despite the very, very fragile landing gear and clevises. The way it flies redeems it and then some. Highly recommend it!
MaddSkillz is offline Find More Posts by MaddSkillz
Old Mar 29, 2012, 11:35 AM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Well it isn't too hard just to get some bigger wheels. I am going to need to do that too - the grass at our field is starting to grow again.
SU-31 is repaired and the Swift is finished - should be able to get them both out tonight - winds look decent
Wolfe
Old Mar 29, 2012, 03:41 PM
Jack the R's Avatar
Joined Aug 2009
I made a metal wire landing gear for my Depron F3P plane that has worked flawlessly.
wolfewinde - It's not always as easy as "put bigger wheels on." I want to put wider wheels on my Slow Stick, but they don't fit the axle diameter and the hub of the wheels is wider than the space on the axle for the wheel. How big a wheel can you put on the Swift before you run out of room for the wheel collar? I haven't had a good enough look at one to say.
Old Mar 29, 2012, 07:48 PM
My Co-Pilots Rock!!
wolfewinde's Avatar
Joined May 2011
Maiden +3 on the Swift tonight, What a delight she is to fly - she is the best of the bunch that I, have, but I still really like the Extra and the SU-31 too.
Swift is running an E-Flite Power 10, APC 11x5.5 E prop, 2200 mah 3s, and cheap 50 amp HK ESC, and Hitec HS-65 HB servos. Was getting 5 minute flight times and coming down with about 3.8 left per cell. Had unlimited vertical, almost neutral CG while inverted, and a very wide speed envelop. She just floats in to land. Great airplane. Extremely smooth in the air.
The LG on the Swift and SU-31 will have no trouble taking bigger wheels - lots of room for them and the wheels that come with them are already pretty wide.
Wolfe
Old Mar 29, 2012, 08:21 PM
Jack the R's Avatar
Joined Aug 2009
I may put the Swift on my wish list then - I'm going to get all the learning I can out of my Sukhoi first though. I moved the ESC forward a bit and fixed a couple problems with the ailerons and she does much better inverted now. I had so much fun practicing I flew into the ground and broke the motor mount. Nothing a few drops of CA won't fix.
Old Mar 30, 2012, 10:10 PM
intotheblu is offline
Find More Posts by intotheblu
Joined Nov 2011
would love to try the swift or the yak by techone, where the heck can you possibly buy one .....
intotheblu is offline Find More Posts by intotheblu
Cool Twisted Hobbys Owners Thread! hercdriver7777 3D Foamies 12959 Yesterday 08:28 PM
Discussion Dynam Warbird Owners Thread Merlin Power Electric Warbirds 1550 Jun 26, 2016 04:40 PM
Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* Z06 Tony Multirotor Talk 1792 May 22, 2016 03:04 PM
Discussion Classic Parkzone Radian Owners thread wingymaster Electric Sailplanes 9 Jun 16, 2015 02:52 PM
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
