Old Nov 21, 2012, 05:07 PM
newguy2012 is offline
Find More Posts by newguy2012
Using foam in moderation
newguy2012's Avatar
United States, IL, Aviston
Joined Sep 2012
Originally Posted by dr-squared View Post
@newguy2012
Jason, what brand/type of 8x6 prop are you using? I want to try, thanks!
http://www.valuehobby.com/accessorie...rive-prop.html
.50 upgrade!!
I broke mine today oops- foolish manuever but was having a ball!
newguy2012 is offline Find More Posts by newguy2012
Old Nov 21, 2012, 08:51 PM
Vince_TT is offline
Find More Posts by Vince_TT
United States, PA, Philadelphia
Joined Dec 2011
This is actually a GWS 8060 HD. Very good prop for warbirds, sporty at 36" wing span and below. I used to have big bucket full of them, but now I mostly use APC style props.
.50 upgrade!!
Vince_TT is offline Find More Posts by Vince_TT
Old Nov 22, 2012, 07:30 AM
newguy2012's Avatar
Joined Sep 2012
whats the main difference between the 2 Vince?
Happy gobble gobble guys!!
Old Nov 22, 2012, 08:01 AM
Vince_TT is offline
Joined Dec 2011
The APC "E" series prop is thicker, heavier and with prop adaptors to fit almost every type of motor shaft, no drilling needed. But it's too big to mount on a prop saver for small motor. I use APC E prop for 200 plus watts motors, ranging from 8x6 to 14x7.
APC also has "SP" series props, I use 10x4.7 and 11x4.7 for my bigger foamie 3d plane. I do not find much difference than a GWS SP except for the prop adaptor, which is the reason I choose APC over GWS in this size range.
But for smaller prop/motor application, you cannot beat the efficiency of a GWS DD or HD props up to 9050. I had tried the 1060 before, but it is too flexible than I like.
Happy Thanksgiving!
Old Nov 24, 2012, 06:29 PM
newguy2012's Avatar
Joined Sep 2012
http://www.nitroplanes.com/unblfrdebyte.html
for my fellow T1 junkies
Old Nov 24, 2012, 07:25 PM
xmech2k is offline
Find More Posts by xmech2k
xmech2k's Avatar
United States, CA, San Diego
Joined Jun 2007
A question for those with a couple of TechOne planes under their belt.
Someone at the field today highly recommended the T1 Swift for me to begin my stunt/3d journey. I went on Nitroplanes, and see the Swift is $129, but they have their Yak54 on sale for $99. I see they are very slightly different in size, but other than that, is there much difference? Would a 3d newb even notice?
Thanks in advance!
xmech2k is offline Find More Posts by xmech2k
Old Nov 24, 2012, 08:50 PM
Vince_TT is offline
Joined Dec 2011
Thanks in advance!
If budget is not an issue, get the swift because the stock motor and ESC come with Yak is marginal. Both planes need metal gear servo at least for elevator and rudder. Solar d654 is a good choice. I stripped two MG servos in my Yak in three months. I flew my Yak today in 20mph wind and have lots of fun.
Old Nov 24, 2012, 11:13 PM
xmech2k is offline
xmech2k's Avatar
Joined Jun 2007
Thanks Vince. I was close to getting one of the 48" Extreme Flight planes, but I had a bad feeling about a $500 (All together) wood plane to learn 3D on! This should be great! Now I have to read 25 pages of forum...
Old Nov 24, 2012, 11:21 PM
Get Real is offline
Find More Posts by Get Real
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
Thanks in advance!
There is a big size difference,the techone swift is 46.5 wingspan.. both yak 54s are considerably smaller in size and lipo and power set up requirements 47''-48'' size stuff flys really well and is a very popular set up size. Had i not recently purchased a plane i would of been all over that nitroplanes black friday sale. Also if you already have gear you can purchase the swift for 59 bucks.
Get Real is offline Find More Posts by Get Real
Latest blog entry: Simplecopter Mini T Copter Fun
Old Nov 25, 2012, 08:46 AM
dr-squared is offline
Find More Posts by dr-squared
dr-squared's Avatar
United States, UT, Eagle Mountain
Joined May 2008
The Swift kit at $59 (think that's what I saw) is a fine deal. Bet it flies good in weather. Has a kinda pattern look to it.
dr-squared is offline Find More Posts by dr-squared
Old Nov 25, 2012, 11:49 AM
xmech2k is offline
xmech2k's Avatar
Joined Jun 2007
I'll dive right in and get the ARF setup of the Swift. As those servos die, I'll go to metal gear ones. The guys at the field say these planes are indestructable! Thanks for the advice, guys!
Old Nov 26, 2012, 10:12 PM
Captainlarsen is offline
Find More Posts by Captainlarsen
Stop sniffin the glue kid!
United States, CA, Pleasanton
Joined Nov 2012
Quick question for you guys with the Swift. Mine flies great, until I try to pull any ammount of g's in a turn. The wings flex like crazy. At first, it was just the left wing, but after reinforcing it, both wings flex at the center point. The stock carbon is through them as well. Thoughts?
Captainlarsen is offline Find More Posts by Captainlarsen
Old Nov 27, 2012, 08:19 PM
dr-squared's Avatar
Joined May 2008
I should think a generous serving of extra carbon fiber in your diet should do the trick! Seriously, I don't fly the Swift, but my two other T1's required modification/adjustment to the stock reinforcement to solve stiffness issues here and there. With epp, it's as easy as slitting the foam, inserting strip/rod and gluing it in...not sure if that's for you but just sayin'...
Old Nov 28, 2012, 11:00 AM
Joined Nov 2012
Thanks for the advice! I think that's what I may end up doing. I'm going to go to my LHS this weekend and look for some carbon strips, and if they don't have it, i may substitute with plywood in the center section of the wing. Weather is crap lately, so that gives my some time to work
Old Nov 28, 2012, 01:54 PM
Pilot Fatigue is offline
Find More Posts by Pilot Fatigue
Joined Jan 2012
Swift motor
Eflite park 480 1020kv be enough power on the swift? I like the 59 dollar price but already have that motor and some mg servos. Thanks in advance!
Pilot Fatigue is offline Find More Posts by Pilot Fatigue
Cool Twisted Hobbys Owners Thread! hercdriver7777 3D Foamies 13230 Sep 22, 2016 11:15 AM
Discussion Dynam Warbird Owners Thread Merlin Power Electric Warbirds 1567 Aug 21, 2016 01:57 AM
Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* Z06 Tony Multirotor Talk 1792 May 22, 2016 03:04 PM
Discussion Classic Parkzone Radian Owners thread wingymaster Electric Sailplanes 9 Jun 16, 2015 02:52 PM
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
