Old Nov 03, 2012, 07:20 AM
racie34 is offline
Find More Posts by racie34
road wart
racie34's Avatar
United States, IN, Terre Haute
Joined Aug 2003
I'm sure they're not very tough....probably fun though while they last
racie34 is offline Find More Posts by racie34
Old Nov 03, 2012, 07:23 AM
IndyMatt is offline
Find More Posts by IndyMatt
Indianapolis, IN
Joined Oct 2010
Well I have everything for them as well, so that makes them even better. Although the Crack Yak from Twisted Hobbies is calling my name. I have the pitts and it is simply amazing. But that will be a little more dough.
IndyMatt is offline Find More Posts by IndyMatt
Old Nov 03, 2012, 08:30 AM
dr-squared is offline
Find More Posts by dr-squared
dr-squared's Avatar
United States, UT, Eagle Mountain
Joined May 2008
Originally Posted by Vince_TT View Post
Yes, and no pull to the canopy or push to the LG at KE...Also, you are supposed to do flat turns without dropping altitude in the same throttle range with mix on.
Thanks Vince, now I know where to go...
dr-squared is offline Find More Posts by dr-squared
Old Nov 04, 2012, 03:26 PM
newguy2012 is offline
Find More Posts by newguy2012
Using foam in moderation
newguy2012's Avatar
United States, IL, Aviston
Joined Sep 2012
got to run 2 batts through the P-51 today, took the whole family, I have to hand it to DR DAN- the 500 mah battery works great!! you can slow waaaaaaaaaaaaaay down, loved it!! and the kids liked it too!! oh yeah , Tried an 8X6 prop and I really liked how it handled, I could maintain altitude under 1/4 throttle.
newguy2012 is offline Find More Posts by newguy2012
Old Nov 04, 2012, 03:35 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Heres my Depron Duplicate Piaget and it's so! much more Precise and stiffer and it makes the fact it's delicate worth it (plus from flying the EPP Piaget i don't really crash any more)
and Plus because its lighter i get longer flight times on the same battery even when im practicing mare hardcore oriented 3D !
Im Probably not going to add a full paint-scheme as it looks Awesome in white (maybe some orientation Stripes)
Keenan smith is offline Find More Posts by Keenan smith
Old Nov 04, 2012, 07:50 PM
newguy2012's Avatar
Joined Sep 2012
I did notice the wings flex alot on my girl, scared me!!!
Old Nov 04, 2012, 11:49 PM
khooke is offline
Find More Posts by khooke
Joined Aug 2004
Originally Posted by dr-squared View Post
It probably ends up the same as the unresolvable expo or no expo personal preference thing.
Having played around with expo on my Venus, I've come to the conclusion that even the smallest amount of expo really doesn't work for me. I'm wondering since I've small hands/short fingers, any transmitter change that makes me need to move the sticks any more than necessary really doesn't work for my hands/fingers. The first time I dialed in about 20% expo just to try it out I initially panicked that the plane wasn't responding the way I expected... a couple of seconds later before I realized I had to move the sticks further to get the response I needed. Flew a couple more times then decided expo definitely not for me. Dual rates, sure. But expo, no, not for me, don't like it.
khooke is offline Find More Posts by khooke
Old Nov 05, 2012, 11:03 AM
Vince_TT is offline
Find More Posts by Vince_TT
United States, PA, Philadelphia
Joined Dec 2011
I use no D/R or Expo on my wirdbirds and sport plane..but with 3D planes, I need at least 50% in Expo to smooth out the flight, especially for harrier, hover and rolling harrier. Expo setting is kind of personal preference, I found it doesn't really matter for small/slow foamie planes since you have tons of time to react. but for larger 3D plane like the 43" Yak, Swift, Tempo or balsa planes (minimum 300W+ output with large control surfaces), my fingers are too heavy for most of the time. What is the AUW on your Venus? I am think about indoor flying for the winter.
Vince_TT is offline Find More Posts by Vince_TT
Old Nov 06, 2012, 11:35 AM
dr-squared's Avatar
Joined May 2008
You must have been pushing her, that'll happen when you're having fun! I prefer the lighter feel of a lighter plane sometimes, but without higher mAh the flight times go down, no big deal for me. Stalled mine again and repairing it...found out the carbon reinforcement is very small (1.5mm x .75mm) making the front weak. I gutted it out and am replacing it with the size used in the Bf109 (1mm x 4mm) and adding a piece under the battery. Adds maybe 6-10 g with adhesive, didn't like that but it's going to help because I fly very low and sometimes, too slow, and, apparently, don't worry as much about the ground as I should!
On the 3D side of things, even though I'd often used expo in the past, I'm finding it hampers my ability to hover, at least with my throws the way they are...a precise feel is my friend. It's taking me a little while to find the sweet spot trade-off between amount of throw and too much sensitivity, but I suspect that is part of the art of setup on these things.
Still too much fun, whatever you're flying...chow ya'll!
Old Nov 06, 2012, 04:34 PM
newguy2012's Avatar
Joined Sep 2012
yes I was pushing it a bit! I did add some reinforcment under the batt I got tired of the whole front end snapping off even in a minor "crash"/landing and that seems to be working well,
not sure if you remember my roll question a few posts back, I think I know whats going on, I have the ailerons dialed waaaaay down, when I ge tth enerve I will put them at 100% and pray!!!
J
Old Nov 06, 2012, 07:21 PM
Vince_TT is offline
Joined Dec 2011
J
I have the same problem of front end snapping off with my Yak, my best solution is to glass that section up. I bought the lightest fiberglass cloth from eBay, cut some straps with a very sharp knife and then used thin CA to glass them over the broken area. I wore a medical glove and used my fingers to spray the glue. This way you would only add a few grams and the result is almost invisible. I also use water base PU to glass my EPO planes and cowls, but WBPU would be too heavy for EPP.
Old Nov 06, 2012, 07:40 PM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
sbach foamy fun in the dome
Tech-one Sbach pilot Joe Smith (5 min 39 sec)
jsmith285 is offline Find More Posts by jsmith285
Old Nov 06, 2012, 07:51 PM
Vince_TT is offline
Joined Dec 2011
http://youtu.be/9ykWDiRd130
For some reason I thought of dragonfly while watching Joe flying. Great as usual, thanks for sharing!
Old Nov 06, 2012, 07:52 PM
dr-squared's Avatar
Joined May 2008
Yup, that's my only complaint about my plane is the weak front...it fixes easily but I get tired of it. Sounds like all of us with the thick fuses suffer from it to one extent or the other. If my thicker carbon strip mod doesn't do it I'm going with Vince's CA glass method. However, good to hear you've entered the flogging zone with your plane Jason...any of this EPP repairs beats balsa and covering fixes, that's all we had a while back...way back...farther...okay stop...
Old Nov 06, 2012, 08:14 PM
dr-squared's Avatar
Joined May 2008
Wow, that flyin's what I'm talkin' 'bout...
Cool Twisted Hobbys Owners Thread! hercdriver7777 3D Foamies 12701 Today 02:31 PM
Discussion Dynam Warbird Owners Thread Merlin Power Electric Warbirds 1529 May 23, 2016 06:38 PM
Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* Z06 Tony Multirotor Talk 1792 May 22, 2016 03:04 PM
Discussion Classic Parkzone Radian Owners thread wingymaster Electric Sailplanes 9 Jun 16, 2015 02:52 PM
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
