Old Sep 28, 2012, 05:11 AM
newguy2012 is offline
Find More Posts by newguy2012
Using foam in moderation
newguy2012's Avatar
United States, IL, Aviston
Joined Sep 2012
Originally Posted by dr-squared View Post
Newguy, I'm using Turnigy 3s 500mAh 20C at 50g weight with supplied 8040 prop. I found that with the 1000mA's some have used it was a bit nose heavy. While it was very stable in that configuration, it flys much slower and almost floaty at the lighter weight. You may prefer the speed and power of the bigger ones, many do. I am pleased with the sport aerobatic qualities and the lower speeds with the lighter however. It is still a warbird and at too slow a speed doing aerobatics it can still stall. Nosed it in twice this past weekend "exploring" itls limits (ok, I was flying like crap) and broke the nose into three pieces. Fixed with Welder's (you really should get some), let dry overnight and good as new and invisible next day. In fact, after repeated stupidity, glued joints held with same crash! So, it can break at the nose due to all the holes up there, but, it repairs nicely without affecting flight qualities. Is this your first 4ch aileron bird? Be advised that thet are "pointy" and do not self correct. You will like that after awhile, I assure you. I launch underhand at 3/4 throttle. Let me know of your experiences and I'll share mine! Thanks, Dan
Sir Dan, thank you for all the input, yes this is my first 4 ch aileron bird- I fully expect to crash - and I am grateful for your help! what would you recommend for assembly of this gal, epoxy or welders? I am waiting impatiently for Nitroplanes to send my order- long story short they have screwed up my order, grrrrrrrr- I will have to order the batts you speak of and go from there, I got out of this hobby for a while and and I am diving back in, very impressed with the prices of things lately, thanks you for all your help Dan!!
Jason
newguy2012 is offline Find More Posts by newguy2012
Old Sep 28, 2012, 09:08 AM
newguy2012's Avatar
Joined Sep 2012
another question sir,
where did you order yours from? I am curious what all comes in the kit form, the photos show a "prop saver" and i am hoping this one does too, I am not really happy with nitroplanes at the moment and if there is one thing messed up on my order I am not going to be a happy camper! just wondered if you or anyone else on here had had any experience with them, positive or negative and what/how I should follow up?
thanks again
J
Old Sep 28, 2012, 11:42 AM
markl22 is offline
Find More Posts by markl22
Joined Jul 2012
Just finished and maidened my Techone energy. Very happy with it, harriers nice, and is easy to hover with even though I don't know how to do it yet. lol.. It makes for a nice slow flyer in the back yard as well. I like this even better than my Crack Pitts. Next up, test fly my new Spirit.
markl22 is offline Find More Posts by markl22
Old Sep 30, 2012, 10:06 PM
dr-squared is offline
Find More Posts by dr-squared
dr-squared's Avatar
United States, UT, Eagle Mountain
Joined May 2008
Hi jason, haven't checked in lately, sorry about delays with NP. Sometimes they're great, other times not so much with keeping stuff in stock. I did in fact get mine from them but their stock can seemingly vanish overnight, one of the pitfalls of not dealing with a LHS. I used Welder's, best for epp because of flexibility. Loctite stick 'n seal works well too. Prop saver is part of the motor, no need to get a separate one. Keep your throws on the lower side until you get familiar with non-self correcting handling. If this is your first aileron plane, you will be challenged (this is not an aileron trainer really)...it will not be what you think but keep at it and learn to repair! If you can put up with my erratic schedule PM works for me.
dr-squared is offline Find More Posts by dr-squared
Old Oct 01, 2012, 08:50 AM
newguy2012's Avatar
Joined Sep 2012
thanks Dan! I sent you a msg,
anyone else care to chime in?
anyone else have the 33'' P 51 from Techone? I have a couple other questions as to what comes in the "kit"- the RX ready one as the nearest LHS is 75 mi away!!
1- I see as to what appears to be a servo extension on the right side? is it included?
2- some photos show a plywood "boss" for the servos and some photos not so much.
3- what kind of batt connectors come with it.
4- what is the hinge material? tape? does it need any attention, I have read they need "exercised" they are to tight?
5- how is the stock prop? I have a few oddball props running around, wondered if anyone found a suitable sub?
6- would protecting the underside of this bird be a good idea? (tape or polyurethane, etc?) I am sure I will put this on my roof at least once .
thanks for any and all input!
BTW Nitroplanes had delayed shipping my order by 4 days for whatever reason, I called and waited for over 30 minutes on hold to talk to a human with no results but an "I am sorry sir".
I then used the online chat function, got to chat with a coulple of helpful fellers and got 10% taken off my order! - much happier now!!
lesson learned- USE THE ONLINE CHAT FUNCTION!!!
Jason
Old Oct 01, 2012, 06:24 PM
gromit38 is offline
Find More Posts by gromit38
Joined Jul 2012
Newguy, I don't have the Mustang, but in other Techone kits, the servo extensions aren't included. The hinges are live EPP, but will break away eventually, so you should put in real hinges right away. Since I buy kit versions, I can't help with your other questions. Good luck.
gromit38 is offline Find More Posts by gromit38
Old Oct 02, 2012, 12:30 AM
dr-squared's Avatar
Joined May 2008
Jason, the battery connector that comes with it will likely have to changed, not one I'm familiar with, possibly it fits Techone's preferred battery or something. Sooner or later you'll likely, out of convenience, have to develop soldering skills and acquire tools and supplies for this. Plywood servo mounts not needed but can be used, I hot glued my servos in without them, a little dab'll do ya. Stock prop works just fine, doubt you'll see much performance change with others within reason. Once you get the kit in your hands you'll probably have more of your questions answered, some adapting always seems to be required and skill with this will come in time. Excercise the hinges for now, see how you like the plane before re-hinging, they'll last for a while and you'll see them coming apart, mine have lasted 30 flights so far. My servos that came with kit didn't require extensions, slits cut in foam will hide them. That should be enough for now, whew!
Old Oct 02, 2012, 05:59 AM
newguy2012's Avatar
Joined Sep 2012
thanks to all!
sorry if I overloaded you Dan!! I have had too long to think of questions!!
if anyone else has any input I am grateful
2 more days if all goes well and I should have it!
Old Oct 02, 2012, 08:50 AM
markl22 is offline
Joined Jul 2012
Finally maidened the Spirit. Blue Wonder motor and 12A esc from HeadsupRC, 8 x 4.3 prop, 3s 450 batteries. Really nice at fast or slow speeds. Feels like a really light plane in the control sticks, which it is of course, so it doesn't like much wind unless you fly at fast speed. It will harrier and hover with ease. It makes me look better than I am. lol. Was a fun build as well. Bargain at less than $40 for the kit. Got it right away from Nitroplanes, no problems.
Old Oct 02, 2012, 11:01 AM
newguy2012's Avatar
Joined Sep 2012
where did it ship to? I am having nothing but bad luck w/NP?
glad you are having good luck with them and the Spirit!
Old Oct 02, 2012, 12:18 PM
markl22 is offline
Joined Jul 2012
Shipped to Buffalo, NY area
Old Oct 02, 2012, 06:36 PM
newguy2012's Avatar
Joined Sep 2012
please define real hinges? for EPP whats that going to entail? what I bought is the motor ESC servo combo basically a Rx ready I guess we will see on thursday if all goes well
Old Oct 03, 2012, 07:34 AM
gromit38 is offline
Joined Jul 2012
Well, 'real hinges' could mean tape, plastic hinges, CA hinges, or other things. The hinge on these EPP planes is just a place where the material has been milled out and is therefore thinner and more flexible. It works great for a while, but eventually will (probably) eventually fail. Mine did. It's an easy fix, but only if you don't loose the plane when a hinge lets go midair. Mine did.
Old Oct 03, 2012, 10:51 AM
newguy2012's Avatar
Joined Sep 2012
thanks for clearing that up! I am trying to get as educated as I can.
any other tips? keep em coming!!!!
thanks again
Jason
Old Oct 03, 2012, 01:04 PM
newguy2012's Avatar
Joined Sep 2012
Dr Dan
I saw you said something about the batt conections on the ARF you said they weren't something you were familliar with? what did you end up using?
I can solder, I have been a mechanic for the last 10 yrs / plumber/pestmanager, long story
and my wife thinks I am a carpenter lol.
I have the tools- well you can never have enough tools but.....
Cool Twisted Hobbys Owners Thread! hercdriver7777 3D Foamies 12692 Yesterday 01:08 PM
Discussion Dynam Warbird Owners Thread Merlin Power Electric Warbirds 1529 May 23, 2016 06:38 PM
Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* Z06 Tony Multirotor Talk 1792 May 22, 2016 03:04 PM
Discussion Classic Parkzone Radian Owners thread wingymaster Electric Sailplanes 9 Jun 16, 2015 02:52 PM
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
