Old Mar 10, 2012, 08:24 PM
67,000rpm
Malta, Balzan
Joined Oct 2009
Hypothetical question - what happens if you run an EDF with the duct removed?
Does it still produce any thrust?
Does it produce more or less thrust than it did with the duct?
Will the motor revs change? If so will it under- or over-rev?
Will the noise change in volume or sound? How so?
LMF5000 is offline Find More Posts by LMF5000
Old Mar 10, 2012, 08:35 PM
USA, GA, Marietta
Joined Oct 2000
Hi,
1 Yes.
2 less
3 under
4 yes, less
Ric
RicVaughn is offline Find More Posts by RicVaughn
Old Mar 10, 2012, 08:53 PM
Belfast / Dublin
Joined May 2004
without the duct it will be significantly less effective
big bird is offline Find More Posts by big bird
Old Mar 10, 2012, 09:00 PM
67,000rpm
Malta, Balzan
Joined Oct 2009
Thanks for the replies so far. Interesting that you say it will under-rev. I take it that implies that removing the duct puts the motor under more strain even though it spins the same fan. I'll take your word for it, but I'd really appreciate if you could explain why that happens?
Old Mar 10, 2012, 09:18 PM
Endlesslag's Avatar
USA, VA, Spotsylvania
Joined Jan 2011
Then it's just an electric fan?
Endlesslag is offline Find More Posts by Endlesslag
Old Mar 11, 2012, 08:56 AM
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
Depends on the particular fan and ducting. Generally, using a restricted tailpipe reduces thrust and fan loading. Good inlet ducting increases static thrust and fan loading. Poor ducting may do the opposite.
But just saying 'increases' or 'reduces' is not very useful without knowing how much it changes. Here are some real-world numbers (Haoye 7 blade 64mm fan, 3400Kv outrunner, 2S Lipo):-
Bare fan (no ducting): 134W, 22650rpm, 267g
With tailpipe 95% fsa: 132W, 22753rpm, 250g
Inlet ring and tailpipe: 151W, 22130rpm, 390g
In GWS ME262 nacelle: 153W, 22105rpm, 329g
Note that these are all static tests. Though using an inlet ring boosts static thrust significantly, it has little effect on in-flight thrust. A restricted tailpipe increases exhaust velocity, increasing thrust at high airspeed.
If the fan is for a slow model (eg. glider, airliner) then use a fat inlet ring and a short tailpipe opened up to 100% fsa (fan swept area). For a fast jet you can have long ducting, but keep the mouth thin (for lower drag), maintain inlet ducting at 100% fsa throughout its length, and restrict the outlet to 85% fsa.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Question What actually happens if you mess up by unplugging usb during firmware update? whosthebaddest Eagle Tree Systems 6 May 04, 2012 05:21 AM
Discussion what happens if you under-prop a brushless motor flying_rhyno 3D Flying 7 Oct 31, 2011 08:26 AM
Alert Free speech in the USA and what happens if you try it outside a free speech zone treehog Life, The Universe, and Politics 32 Oct 03, 2011 10:24 AM
What happens to discharge rate if you run in parallel? xray328 Electric Plane Talk 7 Sep 27, 2005 04:52 PM
What happens if you run a LiPoly to zero? (Alternate title: Up a tree without a clue) TJJ Batteries and Chargers 2 Oct 08, 2003 03:20 AM
