Old Mar 10, 2012, 07:10 PM
new1200 is offline
Find More Posts by new1200
Trader Rating: 23
United States, MO, Cape Girardeau
Joined May 2008
Trader Rating: 23
Could this be possible, 2 dsm2 receivers bound on 1 transmitter at same time
I have a friend who has a Dx6i which is bound to two receivers on two different airplanes and both will link with transmitter at same time and all functions operate on both planes at same time. Should this be possible
new1200 is offline Find More Posts by new1200
Old Mar 10, 2012, 07:20 PM
D W is offline
D W
Find More Posts by D W
Trader Rating: 6
D W
I love you man.
D W's Avatar
United States, NY, Pelham
Joined Sep 2002
Trader Rating: 6
http://www.rcgroups.com/forums/showthread.php?t=1105208
D W is offline Find More Posts by D W
Old Mar 10, 2012, 07:28 PM
D W is offline
D W
Trader Rating: 6
D W
I love you man.
D W's Avatar
Joined Sep 2002
Trader Rating: 6
Dx6i has model match feature. You need to bind Rxs to separate model memories to utilize this. Nothing prevents you from binding multiple planes to a single memory slot but unless the planes have identical servo set ups, trims, etc, this will lead to a catastrophe.
-David-
Old Mar 10, 2012, 07:34 PM
pmackenzie is offline
Find More Posts by pmackenzie
Trader Rating: 39
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Trader Rating: 39
Either a catastrophe, or some intentional fun
http://www.rcgroups.com/forums/showt...6#post11755653
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Mar 10, 2012, 08:06 PM
flyinjrc74 is offline
Find More Posts by flyinjrc74
Trader Rating: 448
Fabrication Extraordinaire!
flyinjrc74's Avatar
United States, MI, Niles
Joined Mar 2008
Trader Rating: 448
It is possible and could be used to avoid a wiring nightmare on a twin or multi engine. You could run a battery on each to power them individually.
As far as binding two separate planes on the same model in your tx memory and then flying them. Please use two video cameras(one aimed at each plane) and post the outcome on youtube, I gotta see it!
flyinjrc74 is offline Find More Posts by flyinjrc74
Latest blog entry: Phantom 3 Professional
Old Mar 10, 2012, 08:15 PM
Trader Rating: 39
pmackenzie's Avatar
Joined Dec 2002
Trader Rating: 39
Follow my link in the post above yours.
Old Mar 10, 2012, 08:22 PM
Trader Rating: 448
flyinjrc74's Avatar
Joined Mar 2008
Trader Rating: 448
Yeah, that is cool but a couple of nitro trainers would be better in an outdoor environment!
Old Mar 10, 2012, 10:19 PM
Trader Rating: 39
pmackenzie's Avatar
Joined Dec 2002
Trader Rating: 39
Unless they can basically fly themselves (like the Vapor can) it won't end well
Old Mar 11, 2012, 10:13 AM
Garrett1234567 is offline
Find More Posts by Garrett1234567
Trader Rating: 72
USA, WV, Parkersburg
Joined Jun 2007
Trader Rating: 72
If you search YouTube, there is a guy that flys 5 mcx heli's off of 1 tx. You can see the differences in motor power. 1 is almost to the ceiling and1 is just a foot or so off the ground.
Garrett
Garrett1234567 is offline Find More Posts by Garrett1234567
Question Calibrating Throttle on ESCs--One by One or All at the Same Time on a Quad? Dave8888 Multirotor Talk 2 Jan 29, 2012 08:16 PM
Question Foxtech/Bevrc 2.4Ghz combo on 2 planes at same time bakchos FPV Aircraft 5 Dec 06, 2011 02:42 AM
Question Same Plane bound to 2 different TX - Possible? ZackJones Radios 3 Mar 26, 2011 11:11 PM
Discussion Can multiple lipo chargers be used at the same time on a 12v battery? 22niner8juliet Batteries and Chargers 10 Aug 07, 2010 11:20 PM
