Old Mar 16, 2012, 11:43 PM
i812 is offline
Find More Posts by i812
i812's Avatar
Joined Aug 2009
Originally Posted by Chap1012 View Post
Well, ... Use ... whatever..."
When discharged, the inside of a firearm's muzzel is exposed to high internal temperatures and very reactive "internal" chemicals, and if not properly cared for could result in the muzzle exploding, or possibly worse cause a "security" breach resulting in even more loss of life/property. I think this "security" risk, is the main reason gun enthusiasts almost immediately clean their firearms each and every time they have a "discharge" session.
How many heli enthusiasts want to tear down their heli, each and every time their heli takes a "dive" for the "team"? Not me, not if I can find a better lower maintenance way of preventing unwanted stuff from entering into a bearing. I believe grease will do the low maintenance job for a heli bearing, because I believe with a bearing the problem isn't about internal stuff getting bad by itself like happens with a gun, but with external stuff getting inside.
Lets use our eyes as an example. If eyes are dry, they will probably cause the owner unwanted grief. Now, lets try to find solutions for the dryness. Water, or any other non-irritating "lubricant". Problem fixed.
Now let's take up a notch, and consider dry eyes in a sand storm, and for whatever "Godly" reason we weren't allowed to "seal" the eyes with goggles, and were only allowed to use lubricants. Which do you think you'd grab to protect your eyes: Water or some kind of non-irritating grease? I've had a pie thrown in my face. No big deal, just close eyes before pie hits eyes, then reopen eyelids, and now I have a sand-proof protective thick "grease" coating protecting my eyes. If afterwords someone throws sand at the grease, the sand will stick to the grease, but not go through it into my eyes. I think Bob was essentially doing the same thing with his grease, and then running the bearings for a little while on a drill to make a hole in the grease for the balls to "race" in. I imagined, afterwards, when all the "junk" was being thrown at the outside of his greased bearing, the junk would adhere to the grease, but not be able to work its way through the grease into the "ball" area.
No?
Do you really believe the CLP stuff you adamantly want others to use on their heli bearings will do a better job of preventing "junk" from getting into the bearing internal "races"?
i812 is offline Find More Posts by i812
Old Mar 17, 2012, 11:12 AM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Yup,,,...Absolutely! Many do use it on their helis and other RC toys!!! Break Free CLP PUSHES DIRT OUT and keeps it out !!!! Again, you didn't read my post.
For many of us living in a cold climate (especially near the ocean) Break Free CLP is no stranger to the workshop.
Speaking of cold climate. For those of you who can remember the days before automatic car door locks. Ever come out on a very cold morning only to find your car door locks are frozen solid? How about that padlock on the shed that sat all winter long? I "never" had a problem! EVER!
Grease does serve it's purpose in the world of mechanics but, sometimes it's best left on the shelf.
BTW, I'm not pushing Break Free CLP down anyone's throat. Triflow is suppose to be another excellent lube but, I have never tried it.
So, again, Mr i812, You stay with your grease and I'll stay with my Break Free CLP.
Warning to all: Some grease is not plastic friendly. Choose wisely.
Now, as Forest Gump says...."That's all I have to say about that."
Happy Flying All,
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Apr 26, 2012, 05:28 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
CLP Break Free is fantastic. I use it on all of my firearms, RC model bearings, computer power supply fans, RC P/S fans, household furnace / AC blower etc. Been using it for many years and have never found anything nearly as good.
3 in one oil gets gummy, most special model oils get gummy.
Charles
Old May 02, 2012, 10:00 PM
ShaneXman is offline
Find More Posts by ShaneXman
Coaxial to CP? *shrugs*
ShaneXman's Avatar
United States, CA, Laguna Niguel
Joined Nov 2011
Charles
Oddly enough, I didn't even put 2 and 2 together...I actually use CLP on my guns as well. DUH! LOL
Good call everydayflyer & Chap1012.
-Shane
ShaneXman is offline Find More Posts by ShaneXman
Discussion Help please, servos etc etc etc Pete1232 Micro Helis 3 Feb 19, 2012 11:38 AM
For Sale New 500 full spare head up more TT boom tube & bearing set up screws lipotray etc 28! blueindian Aircraft - Electric - Helis (FS/W) 0 Jan 30, 2012 06:12 PM
For Sale slow stick parts , motor mounts,bearing,pinions, spur gears, etc... ED3 Aircraft - General - Miscellaneous (FS/W) 0 Dec 04, 2011 02:32 PM
Autorotation bearing maintenance? bsumpter Electric Heli Talk 5 Feb 24, 2003 09:17 AM
