Old Mar 10, 2012, 04:58 PM
RPTheLefty is offline
Find More Posts by RPTheLefty
Joined Nov 2011
9x battery mod?
I want to be able to get more time on my transmitter before the battery runs out.
Has anyone done the battery mod for the 9x? Which batteries do you use?
RPTheLefty is offline Find More Posts by RPTheLefty
Old Mar 10, 2012, 10:14 PM
ttabbal is online now
Find More Posts by ttabbal
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
I'm using this battery.
http://www.hobbyking.com/hobbyking/s...dProduct=17825
It's been working very well. I replaced the connector with the one from the stock AA holder. The black servo looking connector works, but I liked the fit better this way.
Here's a buddy code for it if you want one.
http://www.hobbyking.com/buddy.asp?c...4-3F63184AA96B
This one is also very popular...
http://www.hobbyking.com/hobbyking/s...5Fpack%5F.html
ttabbal is online now Find More Posts by ttabbal
Old Mar 10, 2012, 11:40 PM
KC10 CC is offline
Find More Posts by KC10 CC
KC10 CC's Avatar
United States, NJ
Joined Nov 2011
I also have been using the 3s Turnigy 2650mah transmitter pack with the black connector. I think I've charged it twice in the 3 months I've had it!
KC10 CC is offline Find More Posts by KC10 CC
Old Mar 11, 2012, 12:12 AM
Boomerang1 is offline
Find More Posts by Boomerang1
You made that out of trees?
Boomerang1's Avatar
Sydney Australia
Joined Mar 2005
I run the Sanyo Eneloop ni-mh cells in my TX's now including my 9X.
http://www.master-instruments.com.au...TG_SQ-SNP.html
4 times the capacity of the stock battery. I'm sure something is available in the US, this
is the Oz distributor. John.
Boomerang1 is offline Find More Posts by Boomerang1
Old Mar 11, 2012, 01:17 AM
Joined Nov 2011
Thank you for the suggestions. If i used the lipo battery pack, how do I connect it to my 9x? Will it fit inside the compartment?
Is there a guide on how to do the install?
Old Mar 11, 2012, 01:47 AM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
I use over counter Grundig 2300mAh NiMh cells in the standard slots ... in theory I have about 9hrs use from these. In practice I've flown all-day 3 models and still had charge left for next day.
I use a Futaba Me series charger at 50mA which is left plugged in to make sure I have a fully charged Tx. If I need to top-up charge the Tx I can either use the Prolux RC Peak Charger which delivers at 1A with delta peak detection, or my B6 charger set to 0.7A.
My NiMH are less than a dollar each, I have a spare set charged up in my flight box, (that's saved anothers flying when his Tx batts were flat !), and I can swap out any bad cell easily by over-counter replacement. I unplug the charger when I go abroad on assignment, when I return Tx is still charged up and good to fly.
20 - 30yrs ago when I was flying then - Tx's were supplied with 500mAh Tx packs as standard. We flew all day with those ....
solentlife is offline Find More Posts by solentlife
Old Mar 11, 2012, 07:52 AM
KC10 CC is offline
KC10 CC's Avatar
United States, NJ
Joined Nov 2011
Here's a pic of the turnigy 2650. It fits fine with no modifications. The black connector also fits into the connector of the tx.
Old Mar 11, 2012, 01:52 PM
Joined Nov 2011
Hey KC,
The lipo battery has connectors that work with the 9x or did you have to change connectors? Please let me know what you did. Thanks!
Old Mar 11, 2012, 02:33 PM
KC10 CC is offline
KC10 CC's Avatar
United States, NJ
Joined Nov 2011
Yes, the black connector on the battery will fit the radio.
Old Mar 11, 2012, 06:09 PM
Joined Nov 2011
So no need to modify anything? Just plug the battery and you're good to go?
Old Mar 11, 2012, 06:57 PM
KC10 CC is offline
KC10 CC's Avatar
United States, NJ
Joined Nov 2011
For the fourth time, yes.
Old Mar 11, 2012, 11:48 PM
Joined Nov 2011
It's actually for the third time.
Old Mar 11, 2012, 11:49 PM
Joined Nov 2011
The first time you didn't answer the question.
Old Mar 12, 2012, 12:21 AM
KC10 CC is offline
KC10 CC's Avatar
United States, NJ
Joined Nov 2011
Ok buddy, I guess posts 7 and 9 were not clear enough for you.
So, the battery will fit and connect with no modification to battery or radio.
Old Mar 12, 2012, 12:33 AM
Joined Nov 2011
Thank you. I didn't understand what "black" connector meant. African American connector is more proper.
Sold FlySky 9x TH9X radio w/ FrSky Telemetry Module and 2s 1300 battery. NEW! JIMinKENTUCKY Aircraft - General - Radio Equipment (FS/W) 1 Feb 25, 2012 06:08 PM
Sold Turnigy 9X with ER9X and battery. NEW! JIMinKENTUCKY Aircraft - General - Radio Equipment (FS/W) 5 Feb 23, 2012 04:30 PM
Sold Turnigy 9X Version 2 board with ER9X and battery. NEW! JIMinKENTUCKY Aircraft - General - Radio Equipment (FS/W) 6 Feb 22, 2012 11:03 PM
Discussion Turnigy 9x NiMH Battery Mod - Charging? Thx1326 Batteries and Chargers 0 Jun 07, 2010 10:36 PM
