Old Mar 10, 2012, 04:35 PM
brolley is online now
Find More Posts by brolley
brolley's Avatar
United States, PA, Center Valley
Joined Dec 2008
Flea Market Gremlin
Need some help with this one. I just bought a used combat Gremlin at a rc flea market. It is complete with GWS mini standard servos on elevons and a Hobbico CS-35 for throttle. Engine is a MVVS 4.2. Can someone give me starting carb settings and fuel type. I fly electric wings , planes and also have electric and nitro helis. This thing is cool but I need some help to get her going. Thanks , Brad
brolley is online now Find More Posts by brolley
Old Mar 17, 2012, 06:33 PM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
Well since no one else is saying anything, start the settings for the main needle valve at 3 & 1/2 turns out and lean it out after it starts running until it is at the maximum rpm, you may go over a bit which is bad, just richen it quickly again. When it is at the max revs, richen it a bit til it slows a little and then raise the nose up to about 45 degrees. If it leans out and dies, richen it some more. Then set the idle mixture to get a good idle and acceleration without flooding or starving. On the european motors 5% nitro and 20% oil is good. Some castor oil is always good, at least 5% of the 20. If it is an older steel piston cyl, more castor is needed. ABC is usually ok with more synthetic. Or join a club or at least hang around one for a bit and ask lots of questions.
aspeed is offline Find More Posts by aspeed
Old Mar 18, 2012, 08:35 PM
brolley's Avatar
Joined Dec 2008
Thanks aspeed. I got it running but it wasn't easy. After getting it started I got it tuned to run pretty good from idle to full throttle. When I shut it down and try again 15-20 min later it's really hard to start. If I shut it down and start it again immediately , it starts fine. I'm using Byron airplane fuel 10% nitro, 16% oil synthetic / castor blend. Hand propping with a AA batt glow driver.
Old Mar 19, 2012, 02:54 PM
aspeed is offline
Canada, ON, Cottam
Joined Jan 2012
Likely a dead battery. Even the bigger sub C cells don't last long. You need a strong orange glow. I would add another 4% (castor) oil to the fuel. Usually needs a prime by choking from the carb or a couple of drops in the exhaust when cold. Set the idle fairly slow and make sure it is reliable, and have the trim shut it off because there is no landing gear and the motor shouldn't really be running when it lands.
Old Sep 16, 2012, 05:32 AM
brolley's Avatar
Joined Dec 2008
Aspeed, I found what the problem was. While the engine was running and I was tuning it , the idle mixture screw was turning from vibration. Pulled it out cleaned it and used a little locktight to reinstall it. All is good now!
Old Feb 16, 2013, 06:43 PM
Dennis Everett is offline
Find More Posts by Dennis Everett
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
is there a spring under the needle ?
Dennis Everett is offline Find More Posts by Dennis Everett
Swap Meet Levittown Aerobugs 1st Annual Tailgate Flea Market LCS Fuel Power Events 1 Apr 27, 2012 06:18 AM
Sold Planes For Sale @ Lebanon Flea Market 10 Mar 12 steve1814 Aircraft - Fuel - Airplanes (FS/W) 0 Mar 02, 2012 01:39 PM
Swap Meet Levittown Aerobugs 1st Annual Tailgate Flea Market LCS Electric Flight Events 2 Feb 24, 2012 09:57 PM
Off Site *RC Flea Market in Westminster MD Feb. 11th* futabafreak Non R/C Items (FS/W) 15 Feb 13, 2012 09:18 PM
