Yet Another Newbie 5.8GHz Setup - A Catalog of Statics
About this thread
Last update of this post: April 27, 2012 There are two types of thread which I find especially useful when looking for information: those which focus on a particular element of the setup (Video TX, OSD, Telemetry, RC link, antennas, ...) and those which discuss a complete setup, how the elements were selected and how it is put together. This thread is meant to be of the second kind. I am very new to FPV so I'll ask questions and report on progress here. I'll try to keep an index of important findings and discussion in this first post in order to try and make it useful for others. Note: Do not hesitate to post anything you like in the thread (remarks, questions, suggestions, comparison with your setup, ...), it is not meant to be a monologue! Current Status: Trying to make a light FPV POD My setup seems to work great in a 500m radius (I have not really tested beyond that). Still a lot of testing and tweaking to do but it starts to work. I am currently trying to see how light I can get the pod to be able to put it on small planes. Not really looking at long range for the moment. Video of my very first FPV Flight: http://www.rcgroups.com/forums/showt...5#post21227784 Have a look at the latest posts to see what we are discussing (I try to keep this first post up to date but there is a delay :-) Thread index and useful links Do not hesitate to suggest things I should put up here.
FPV Flights Videos
Cheers, Franck --------------------------------------------------------------------------------------- Original First Post: My newbie 5.8Mhz FPV setup needs help Hello! I have been planning to attempt flying FPV for a while, I have read quite a lot about different options, antennas, etc... Today I have put together my first setup which is composed of a cheap 5.8MHz 200mW transmitter, an small SD video recording system and the cheapest goggle I could find. Here is a picture: I flew the plane around and recorded the video, just to see how it would perform. The result is not a complete failure but I have a range problem. I thing I am not getting more that 100 to maybe 200 meters where at least 500m should be fairly easy to reach. Here is the video:
In the next few posts I will provide details about plane, antenna, receiver, recorder and goggles. The information might be helpful to someone and some of you experts might spot some mistakes I have made. Cheers, Franck |
Video TX/RX (5.8GHz 200mW) and Antennas
For the video transmission I have chosen this kit from HK:
http://www.hobbyking.com/hobbyking/s...Tx_Rx_Set.html My RC link is at 2.4GHz so I needed to choose between 900MHz and 5.8GHz. For the first attempt I chose 5.8GHz because I am not looking for long range, my flying area might have some obstacles and smaller antennas are required. I went for 200mW because it is supposed to give a range of 500m+ which is sufficient for me (and can be extended with the right antennas, for extreme range see http://www.rcgroups.com/forums/showthread.php?t=1441664). The camera I am using is this one: http://www.hobbyking.com/hobbyking/s...mera_PAL_.html When I got the TX and RX I made some experiments indoors and was really disappointed by the range and quality of the video link. After some hours browsing RCGroups I found that probably the stock wipe antenna are not the best option. After reading a bit more mainly from rcexplorer.se tutorial and IBCrazy wonderful tutorials, I built a Skew-Planar Wheel antenna (http://www.rcgroups.com/forums/showthread.php?t=1352583) for the receiver and a Cloverleaf antenna (http://www.rcgroups.com/forums/showthread.php?t=1388264) for the transmitter. Here are some pictures: I am not sure how good my antennas are but using them has improved a lot the range and quality of the video link indoors (so I assume this would also mean that it is improved outdoor but this is not sure). I cannot really test anymore because I have destroyed the wipe antennas to build the new ones. As shown by the video in the previous post using this setup I got only about 100m (maybe even less) of reliable range so there is probably something wrong. Maybe my antenna are not good enough, maybe they were not properly located, maybe there are interference in the area... What do you think ? On the plane the antenna was upright in front of the plane and the RC RX was about 10 cm away (as far as I could get it). On the ground the antenna was not very high and also in the upright position. Here is a picture, if that can help: ![]() Should I have placed the antennas differently? Maybe the receiver antenna should higher? Could that make such a huge difference in range? Opinions, advises and suggestions for experiments I should make are welcome! Next I will post a few findings on the RC305 receiver (I might have made some mistakes there as well :-). Cheers, Franck |
Setup of the RC305 5.8GHz Receiver
I got the RC305 receiver out of the RX/TX kit I bought but the receiver can also be purchased alone for $24 (I am thinking of buying a second one to set up diversity but that is another story):
http://www.hobbyking.com/hobbyking/s...dProduct=15415 For my setup I needed to power it up and get the A/V out and get the signal strength. For the power supply, it works from something like 7V to 12V but by opening it up it looks like everything runs from 5V (or less) and the rest of the power is dissipated by a linear regulator which basically just heats up the whole thing. To avoid wasting power and heat I am bypassing the linear regulator and powering it up from 5V directly. It seems to work ok. Another problem is that since the antenna is on the receiver, to be able to put the receiver+antenna somewhere up in the air I did not want to have too many wires going from the receiver to the rest of the ground station. So I have used single 4 connectors properly shielded cable. Here is a picture: Shield: GND Red: +5V Yellow: Video Green: Audio (the audio quality I get is crappy, so maybe I should have chosen the other channel) Blue: RSSI Here is how it look ready for action: BTW, on the ground station I get the 5V using a cheap switching mode EBEC which I power from a 2S lipo. This is much more efficient than the linear regulator integrated in the receiver and I also power the goggles from it :-) (The one I use cost only $4: http://www.hobbyking.com/hobbyking/s...dProduct=15212) I think that is it for the receiver. Just shout if you see something I might have overlooked or damaged by doing these mods! Cheers, Franck |
Goggles: Turnigy 320 x 240
I got them from HK but they do not seem to have them anymore. They only have the widescreen one now (http://hobbyking.com/hobbyking/store...dProduct=16072) but I guess it is pretty much the same hardware. Here is a picture: ![]() My main motivation for choosing this model is that they are among the cheapest goggle available and people still seemed able to fly with them :-) I was really not convinced by the glasses and because I actually have glasses I could not really use them as such so I went directly for the ski goggle mod. The glasses were easy to take apart and the build quality of the video unit seems quite good to me. To use the goggle you have to plug them to the gray box which contains the battery and the connections for the A/V signals. I did not really like the idea of having a separate battery for the goggles and the wires and connections were quite stiff so I decided to remove all of that and use a smaller shielded cable to both power the goggles and provide the video input (I did not bother with audio). This was very easy to do, I just opened the video unit and soldered 3 wires to Ground, VCC and Video IN. Normally VCC is directly provided as the voltage of the 1S lipo battery which is in the gray box so it varies between 4.2 and 3.3 volts or something like that. I tried with 5V but the backlight was heating up a bit so I now power it with about 4.4 or 4.5 volts. That makes the picture quite bright and nothing seems to be heating up. (To lower the voltage from the 5V provided by the EBEC of the "ground station" I just added a diode in series on the positive side of the goggle power supply). Anyway, with this setup I have a single wire from the "ground station" to the goggle which is quite convenient. NOTE: It is very important for the wire carrying the video signal to be properly shielded. I made some experiment with random wires and the loose on the video quality is very noticeable even with fairly short wires. For the casing, I went with the typical ski mask approach. On the first attempt I put the video unit too high so it was not really usable. It is now fixed but you can probably tell from the pictures that it was a initial attempt :-) Here are a couple of pictures: I had to paint it black to avoid too much light coming in. I have not yet flown with these goggle but I am really happy with them. I can use them with my glasses, they are quite comfortable and the picture quality seems quite good to me. They obviously do not have the best resolution but I have no problem navigating the menus of the video recorder or reading all the information from the OSD. Cheers! Franck |
Buy SMA-RP pigtails with semi rigid cable. Solder antennas at the end of those and you are home. Pigtails are usually 15cm long and the cable is rigid enough to keep it upright even in an airflow. If it bends, just cut it down to 10cm but not less then that. Keep those antennas away from other hardware.
Cheers, Franck |
Video of the Second Test
As I said in some of my previous post, the second test was made on a different RF channel (7 instead of 4) and with the RX antenna a bit higher.
Here is the edited video:
It was much better than the first test but range is still too short at only about 200m (This time I have the GPS OSD to actually estimate the actual distances). |
Joined Dec 2006
for DIY antenna, I buy this one on ebay:
(choosing SMA or RP-SMA cable depends on your Video Tx/Rx RF output connector) RP-SMA male to RP-SMA male jack center straight RG316 cable jumper pigtail 50cm SMA male to SMA male pigtail cable RG316 30cm It is free shipping, one piece cans DIY two antennas, extremely cheap. |
| Thread Tools | |
| Discussion FPV Beginner Needs Help. | rubenhak | Video Piloting (FPV/RPV) | 3 | Mar 10, 2012 02:01 AM |
| Discussion Help me pick my first FPV setup! | KC10Chief | Video Piloting (FPV/RPV) | 3 | Mar 02, 2012 03:57 PM |
| Help! FPV Newbie - Check my Setup before purchase? | rcbif | Video Piloting (FPV/RPV) | 3 | Dec 30, 2011 05:42 PM |
| Help! Newbie needs help wiring first FPV setup | shadow102 | Video Piloting (FPV/RPV) | 4 | Sep 30, 2011 11:33 AM |
| Sold Hobbyking 5.8mhz FPV tx/rx camera | j5cub | Aircraft - General - Radio Equipment (FS/W) | 0 | Mar 29, 2011 09:40 PM |
