Joined Dec 2011
Ok. Thanks for all your help PhracturedBlue.
I can't believe I'm finally flying all of my dsm 2 stuff with the devo 8s now. I saw the devo 10 today also. I didn't really like it as much as the devo 8s. The devo 10 is heavy with the 8 batteries that is needed. The gimbals had a ticking thing on the collective stick, not sure if that could be fixed. I probably will never get the devo 10 because of the weight anyways. Hopefully walkera will come out with a color touch screen or even black and white touch screen that's readable in sunlight. Btw PhracturedBlue, I tried locking all of the trims in the system menu, it would not allow me to do it. I guess that UI isn't fully hooked up yet? I sometimes hit the trim switches by mistake when changing batteries, that's why I wanted to lock it. Quote:
Weight can be lowered by using a 3s LiPo and not 8 AA NiMH. Cheers |
Germany
Joined Jun 2012
Set to 34% and you get the normal Red LED Mode. Set to 66% and you get the Green LED Mode. By the way: both Modes utilize all 6 Axis, bit in the Green LED Mode you can flip the Ladybird whether in the Red LED Mode there is a Flip Protection. |
Germany
Joined Jun 2012
How to do this? It's explained in the maual or perhaps someone else can explain it here. |
![]() I've play with the setting and figure out you are right its on ch7, set src to gear and 3 point set -34 0 34 its working now! Best of all now i have found extra feature on ladybird which i can set the pot to trigger LEDs on and off on mix switch! ![]() ![]() Edit: One thing I don't understand is ladybird suppose to be 4ch receiver but why its gyro on ch7
Germany
Joined Jun 2012
Yes, you can plug DIY LEDs to your "Update Socket" on the Ladybird PCB and switch them using the Gear Switch on the Devo Tx. Could you please explain more about the Feature of turning the LEDs on and of? I don't quite understand how you managed it. And: please post your Deviation Ladybird Config to http://www.deviationtx.com/forum/model-configs BTW: nice Hamster
Apparently the gyro is at ch7 and the socket for leds connection is on ch5. You can set any value from low to negative and high to positive value for example: -1, 0 , 1 on ch5 can control that socket on and off, but take note that socket can only output at most 2 leds at the same time only. Walkera default setting for that socket and gyro together meaning ch7 and ch5 under gear switch.
Thanks the hamster i edit it to hold the devo6 tx
Spain, Asturias
Joined May 2012
Devo 7
I have readed the thread but there is one thing that I seen that is not provided on it. I don't understand why support for the Devo 7 transmitter is not provided on this development. Devo 7 has a very simple UI and could be a very good platform for the development and testing. You only need to invest the efforts in the functionality of the system because the UI doesn't need graphics or other type of work. It is very similar to a debug system with only a text interface, once the functionality is obtained you could invest your efforts in developing a UI and do it run in other systems like Devo 8 or similar.
| Thread Tools | |
| Wanted Broken Walkera Devo and Spektrum tx | itsmillertime | Aircraft - General - Radio Equipment (FS/W) | 1 | Mar 20, 2012 04:37 AM |
| For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale | Tom Z | Aircraft - General - Radio Equipment (FS/W) | 0 | Oct 06, 2011 12:33 PM |
| For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale | Tom Z | Aircraft - Electric - Helis (FS/W) | 0 | Oct 05, 2011 11:38 AM |
| Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen | hobbypartz | Radios | 2 | May 08, 2011 11:38 PM |
| Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen | hobbypartz | XHeli | 0 | May 05, 2011 11:19 PM |
