Old Mar 19, 2012, 09:22 PM
OnceAFly's Avatar
Singapore, Singapore
Joined Oct 2011
[QUOTE=derek4610;21079679]
Originally Posted by OnceAFly View Post
Here is my screen shots
Can you send me your LIB file?
Thank you, Derek
Sure! Here you go!
http://www.mediafire.com/?s5mcdps20cz3hbj
OnceAFly is offline Find More Posts by OnceAFly
Old Mar 20, 2012, 04:27 AM
Joined Dec 2011
(double post)
Atomic Skull is offline Find More Posts by Atomic Skull
Old Mar 20, 2012, 04:32 AM
Joined Dec 2011
When the simulator port is connected the TX skips the binding process and turns off the transmitter. I was thinking that you could install a FrSky module sharing the same antenna by having a toggle switch that would hook up the FrSky module as if the simulator port was being used (it's just PPM). This way the radio would skip binding and turn off it's transmitter module allowing the FrSky module to use the same antenna. You'd just need to drill holes for a toggle switch and the FrSky bind button and LED.
What size allen wrench do I need to remove the screws in the Devo 8? I just got my 8D module but I didn't realize that it's not using phillips head screws.
Old Mar 20, 2012, 05:04 AM
OnceAFly's Avatar
Joined Oct 2011
Here are some more themes for Devo 12. Man! your tool rock!
Total black!
Xmas orange theme
Robot Spider theme
Old Mar 20, 2012, 05:24 AM
Joined May 2011
Nice!
Does it automatically change the foreground color to white if the background is too dark, or did you do something with the fonts in the black scheme?
FDR_ is offline Find More Posts by FDR_
Old Mar 20, 2012, 05:46 AM
OnceAFly's Avatar
Joined Oct 2011
On devo12 there are three themes to select and the 2nd theme its default text colour is white, so i just make use of that for darker theme
Old Mar 20, 2012, 06:10 AM
Joined May 2011
I see. Thanks!
Old Mar 20, 2012, 06:14 AM
i812's Avatar
Joined Aug 2009
Would black Display background give the longest TX battery discharge time?
i812 is offline Find More Posts by i812
Old Mar 20, 2012, 06:18 AM
Joined May 2011
I think no.
It depends on the back illumination, not the contents...
Old Mar 20, 2012, 06:27 AM
OnceAFly's Avatar
Joined Oct 2011
Just need to find the string for changing the font color..I'll let you know if i found it
Old Mar 20, 2012, 01:12 PM
Better then Sliced Bread!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Originally Posted by FDR_ View Post
I think no.
I second that, the pixel rendering is not very power intensive, it's the back lighting that draws most of the power for the screen.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Latest blog entry: New LC Filters by LetsFPV
Old Mar 20, 2012, 07:45 PM
Joined Dec 2011
I've noticed that the batteries seem to last much longer when the TX is hooked up to a simulator.
Old Mar 20, 2012, 07:48 PM
Joined Oct 2011
Because it's not transmitting
Old Mar 20, 2012, 07:49 PM
Joined Dec 2011
They should have made it a reflective color screen with an optional backlight.
Old Mar 21, 2012, 02:33 AM
Joined May 2010
Originally Posted by PhracturedBlue View Post
Likely all of the I/O will need to be reimplemented, including input from the switches, output to the screen, and output to the Tx. As the walkera seems to have a 'bare' transmitter chip, the protocols to that will be needed too, although it may be easier to start by getting the trainer port working. Looking at the ersky project may be helpful, as I believe they took the er9x source as the base, and now have it working on a replacement (ARM based) main-board.
So, how would you start a firmware. Base OS required?
As it will be built from the ground up, any UI suggestions?
At the moment it looks like the UI was built using the parts from an IDE.
This looks to be quite interesting, unfortunately nobody can do anything without the protocols.
Will the DSM2 stuff already done be enough?
Mike43110 is offline Find More Posts by Mike43110
Wanted Broken Walkera Devo and Spektrum tx itsmillertime Aircraft - General - Radio Equipment (FS/W) 1 Mar 20, 2012 04:37 AM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 12:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 11:38 AM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz Radios 2 May 08, 2011 11:38 PM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz XHeli 0 May 05, 2011 11:19 PM
