Old Aug 27, 2012, 02:04 AM
rcgchris is offline
Find More Posts by rcgchris
...muy bien...
rcgchris's Avatar
Germany, BW, Pforzheim
Joined Jul 2012
Originally Posted by rcgchris View Post
Couldn't find an answer to this:
Would it be possible to program and store macros and reproduce with a button press?
BTW:
Is there any radio at all that can programmed like this?
Hi folks,
I guess I couldn't make myself clear:
Is it possible to replay a pre-programmed macro that I recorded/programmed myself (eg. to execute a flip in mid air) when pressing a button with any radio on the market today?
Any comments welcome
rcgchris is offline Find More Posts by rcgchris
Old Aug 27, 2012, 02:42 AM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
Hi folks,
Why? To take the fun out of crashing yourself?
Not possible with Walkera radios as far as I know.
thwaitm is offline Find More Posts by thwaitm
Old Aug 27, 2012, 05:21 AM
Xermalk is online now
Find More Posts by Xermalk
Sweden, Helsingborg
Joined Jun 2012
Macros would be near pointless, as there's no way to get info from the gyros and compensate for wind / Lower power because of drained battery's.
If it ever gets implemented I predicted massive increase in spare part sales.
Xermalk is online now Find More Posts by Xermalk
Old Aug 27, 2012, 06:34 AM
rcgchris is offline
...muy bien...
rcgchris's Avatar
Joined Jul 2012
Hehehe
Old Aug 27, 2012, 07:31 AM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
Hi folks,
Yes can be done i had Futaba Field Force 6 had that feature 'Snap Roll' and i was amazed how fast i could snap my wing! BTW Flat out in a dive flicked the switch!!
Devo can't do it today but in time once free mixers are there easy to do. So you need TX with free programmable mixers. Off top of my head at least 3.
SadSack is offline Find More Posts by SadSack
Old Aug 27, 2012, 07:53 AM
rcgchris is offline
...muy bien...
rcgchris's Avatar
Joined Jul 2012
Hey nice!
I had the hope a Spektrum or 9x could be able as well by now
Old Aug 27, 2012, 10:16 AM
PhracturedBlue is offline
Find More Posts by PhracturedBlue
Joined Jan 2012
I didn't answer this before because I have no idea what other radios can do, but it would certainly be possible to implement in Deviation. However I agree with others that it would be near pointless. Do you have a specific need in mind? Without feedback from the model, a macro is likely to not work properly, and I'm not aware of any models with telemetry capabilities that could achieve this. Now....with a custom Rx firmware (which has been discussed) things become more interesting...
PhracturedBlue is offline Find More Posts by PhracturedBlue
Old Aug 27, 2012, 10:30 AM
FDR_ is online now
Find More Posts by FDR_
Joined May 2011
Well, if I understand right he would like to record stick movements of some time, and play back them later.
However they shouldn't be absolute stick positions, but only differences, because that would cause a jump in che channels when played back at different stick positions.
Other problem: what if the recorded stick movements don't end at the the same stick positions, where they were at start, but I don't move the sticks while replaying? Again a jump of channel values at the end of the record.
Or vice versa: the record ends at the same stick positions with which it started, but I move the sticks while it playing. Same results...
And finally: what will happen if I play such macro with completely different DR/expo/mix settings? So should we record channel changes instead of sticks?
FDR_ is online now Find More Posts by FDR_
Old Aug 27, 2012, 10:36 AM
thloh85 is offline
Find More Posts by thloh85
Malaysia, Penang, Bayan Lepas
Joined Apr 2010
Think of it, if wind blew the tail or cyclic off by a little, the entire orientation is completely off, the maneuver would be disastrous IMHO. If it's a simple flip then its still okay, but why would you want to hit a button to do a flip?
thloh85 is offline Find More Posts by thloh85
Old Aug 27, 2012, 10:56 AM
rcgchris is offline
...muy bien...
rcgchris's Avatar
Joined Jul 2012
It would be a nice feature for multirotor like quads where it makes sense to initiate such a trigger to perform rolls, flips and so on. The flightcontrolers in this segment are able to stabilize the object by themselve after such maneuvers.
Old Aug 27, 2012, 11:04 AM
Skovoroda is offline
Find More Posts by Skovoroda
Joined May 2012
Originally Posted by Skovoroda View Post
Fudge will poke more with flashing, verification and stuff later. Will see what walkera has to say, worst case scenario is remote going to china for a fix up. Thanks phracturedBlue for quick response
Vell, it seems like the library verify fails.
First difference at adress 0x00010000
File byte is 0x57
Read byte is 0x00
Same with model upload,
First difference at adress 0x00005000
File byte is 0x44
Read byte is 0x00
Skovoroda is offline Find More Posts by Skovoroda
Old Aug 27, 2012, 11:06 AM
Joined Jan 2012
File byte is 0x57
Read byte is 0x00
do an 'upload' to dump the entire library. and attach the original and dumped version. I'm interested in if it is just a few bytes/pages that are corrupt, or the whole thing.
Old Aug 27, 2012, 11:42 AM
Joined May 2012
Original 0.5 lib
Dump
Old Aug 27, 2012, 11:55 AM
Joined Jan 2012
Your whole SPI Flash chip is empty. Either the SPI flash chip has failed or the routines to upload it are corrupt. Either way, I don't think there is much we're going to be able to do to help you.
EDIT: actually they all have '00' so they are 100% written, not empty (the flash initializes to 0xff). definitely not a good sign though
Old Aug 27, 2012, 11:59 AM
Joined May 2012
thanks
Wanted Broken Walkera Devo and Spektrum tx itsmillertime Aircraft - General - Radio Equipment (FS/W) 1 Mar 20, 2012 04:37 AM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 12:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 11:38 AM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz Radios 2 May 08, 2011 11:38 PM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz XHeli 0 May 05, 2011 11:19 PM
