Malaysia, Penang, Bayan Lepas
Joined Apr 2010
Thanks for all the help PB, I'll try to work on the LCD driver, but you might be even faster to get it done than I do
Joined Aug 2012
Hi all,
I am newbie here and always follow all post, very interesting... I dont have any RC stuff and just got used Devo10 with RX1002 from ebay for 83EUR inncluding shipping. ... I think that's enough for intro For LCD stuff on Devo10, I just saw the pcb picture and did some retrace, here are my found: PD.4 !OE as E PD.5 !WE as RW PD.14 D0 PD.15 D1 PD.0 D2 PD.1 D3 PE.7 D4 PE.8 D5 PE.9 D6 PE.10 D7 PB.1 Backlight PD.11 A16 as A0 Since LCD just to be written and connected to Databus&co we can use SRAM controller for LCD, and command write need A16 low signal and data write need A16 high signal. I dont have my PC ready for programming yet and need quite more time since my son wont let me sit in front my PC for more than 5 minutes. I think thloh85 can do something since all connection already cleared. Happy coding! |
Joined Apr 2010
Means that I can FSMC write highest bit of address to 1 or 0 to set it to command or data write, and data bus remains data bus correct? Thanks btw for the info, I really appreciate it ![]() That aside, it seems that CYRF6936 only support up to +4dbm, does that mean the max output power is 2.5mW? I'm from CS background, so if anyone can enlighten me it'd be great
Joined Dec 2011
Anyone know where I can get a replacement for an RX802 antenna? One of the antennas on my RX802 has developed a crack in the insulation where it goes into the case. They are connected to the board by a U.FL connector so they should be replaceable.
Will a Futaba 2.4ghz antenna work? http://www.ebay.com/itm/Futaba-Repla...item23171b3c21 |
Joined Dec 2011
Any cable with U.FL connector will work. Remove outside insulation and shielding, leaving 31.25 mm (1.23 in) of unshielded wire at the end. Lenght of shielded part have to be multiple of N wavelength of 2.4 GHz (125 mm).
Any other 2.4 GHz Rx antenna also will work. http://www.hobbyking.com/hobbyking/s...Sky_ACCST.html |
Joined Dec 2011
Joined May 2011
Breaking News!
Here comes the PPM devention tx module from Walkera: http://www.walkera.com/en1/particular.jsp?pn=MTC-01 ![]() ![]() ![]()
United Kingdom
Joined Aug 2008
....but will wait ![]() Appears i was wrong again only new protocol or others too?? Wish Hammer22 had more time to add it to his, he's welcome to my money |
Germany
Joined Jun 2012
| Thread Tools | |
| Wanted Broken Walkera Devo and Spektrum tx | itsmillertime | Aircraft - General - Radio Equipment (FS/W) | 1 | Mar 20, 2012 04:37 AM |
| For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale | Tom Z | Aircraft - General - Radio Equipment (FS/W) | 0 | Oct 06, 2011 12:33 PM |
| For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale | Tom Z | Aircraft - Electric - Helis (FS/W) | 0 | Oct 05, 2011 11:38 AM |
| Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen | hobbypartz | Radios | 2 | May 08, 2011 11:38 PM |
| Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen | hobbypartz | XHeli | 0 | May 05, 2011 11:19 PM |
