Old Mar 16, 2012, 02:10 PM
itsmillertime is offline
Find More Posts by itsmillertime
United States, TN, Memphis
Joined Dec 2011
Any of you smart people figured out how I can use this with my Devo 8S yet?
itsmillertime is offline Find More Posts by itsmillertime
Old Mar 16, 2012, 11:20 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
You could hack in the regular DIY module but the one with telemetry would require firmware support.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Mar 16, 2012, 11:21 PM
Joined Dec 2011
You could hack in the regular DIY module because the connection between the radio and the module is one way but the one with telemetry would require firmware support.
Old Mar 17, 2012, 04:55 PM
derek4610 is offline
Find More Posts by derek4610
Joined Dec 2009
My latest DEVO 6 screen design
I know these are just bit maps but the sky is the limit on screen layouts. The timer values just pop with the yellow background (even in the sun). I brightened up the battery level indicator also. The telemetry screen is next. Post your modified screens. Just ordered a J-Tag, keep hacking.
Derek
derek4610 is offline Find More Posts by derek4610
Old Mar 17, 2012, 05:18 PM
Joined Dec 2009
DEVO 6 screen design,throttle %
Throttle % Mod.
Old Mar 17, 2012, 11:10 PM
i812 is offline
Find More Posts by i812
Mike for President
i812's Avatar
Joined Aug 2009
Looking good!
I'll probably copy your color scheme.
Thanks for sharing.
i812 is offline Find More Posts by i812
Old Mar 18, 2012, 04:32 AM
Joined Dec 2011
Devo TX transmits on three channels, doesn't frequency hop. Apparently scans the environment for unused channels first. Possible that it changes frequencies if too much interference pops up on the channels it's currently using (they didn't test for that)
http://fpvcentral.net/?p=240
Walkera apparently believes that their implementation of DSSS is more resistant to interference than FSSS, or at least that's what they say.
Old Mar 18, 2012, 06:17 AM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
I have seen the same in other places mentioned too.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Mar 18, 2012, 07:09 AM
Joined Dec 2009
DSSS or FHSS which is better?
I fly with FHSS and DSSS and never had any issues. Below is a brief explanation on the two types of SS we use in our hobby. It's really your choice, just make sure the TX power output is at least +15dBm for proper radio range. Oh and stay away from metal fences, multi-path is a enemy.
There are two SS techniques used in the RC industry. Direct-Sequence Spread Spectrum (DSSS) multiplies the data stream with a high-data rate sequence called chip sequence or Pseudo-Noise (PN) sequence, because due to its lenght is seems as a random signal, like the noise (but of course, it is a completely deterministic signal which means "it appears to be, but it is not"). DSSS creates time diversity (a "variety" in the time domain).
Frequency-Hopping Spread Spectrum (FHSS) uses a chip sequence to conrol the frequency hops of the carrier. The resulting signal is like a progressive-FM signal. FHSS creates frequency diversity.
Both SS techniques give a Spreading Gain to the transmitted signal, which is simillar to the Coding Gain of the error-control codes we add additional bits to correct errors; we use this redundancy for error control. That is, we increase the transmitted bandwidth but we can decrease the transmitted power required to have an acceptable S/N at the receiver). Moreover, SS techniques can be combined with multiple access techniques. With Code Division Multiple Access a code sequence is used to give an identity to each user, which than we will transmit a signal spread by a PN sequence. So, each user can use the whole available bandwidth for all the time, but users do not interfere because they are separated in the code domain. Finally, a RAKE receiver can be used to resolve the multiple paths and compensated the ISI caused due to the multipath propagation.
Keep Hacking.
Old Mar 18, 2012, 09:59 AM
i812 is offline
Mike for President
i812's Avatar
Joined Aug 2009
Made as much sense to me as the Lotto numbers do at predicting the weather.
Old Mar 18, 2012, 04:37 PM
FDR_ is offline
Find More Posts by FDR_
Joined May 2011
Derek
Lighten up the airplane a bit so it won't have any pure blacks, because that will be transparent...
Mine looks very similar: simple transitional blue background with white boxes...
http://rc.fdr.hu/devo.php#cust_lib
FDR_ is offline Find More Posts by FDR_
Old Mar 18, 2012, 07:26 PM
Joined Dec 2009
DEVO background
FDR, looks good.
http://rc.fdr.hu/DEVO-8%20Lib%20v0.0.5%20FDR%20v2.zip
Old Mar 18, 2012, 07:51 PM
rcH4x0r is offline
Find More Posts by rcH4x0r
Joined Jun 2010
Looking good Derek! Happy to see ppl using the tool
The older Walkera sets transmitted 4 packets on 3 different frequencies (pattern repeats every 12 packets). My Tx hasn't arrived yet but when it does I plan to check if it is doing the same frequency hopping as the older sets
rcH4x0r is offline Find More Posts by rcH4x0r
Old Mar 18, 2012, 11:16 PM
OnceAFly is offline
Find More Posts by OnceAFly
OnceAFly's Avatar
Singapore, Singapore
Joined Oct 2011
Well that's a very nice tool you made and i'm having fun with it thanks to you!
OnceAFly is offline Find More Posts by OnceAFly
Old Mar 19, 2012, 12:51 AM
OnceAFly is offline
OnceAFly's Avatar
Joined Oct 2011
Here is my screen shots
Wanted Broken Walkera Devo and Spektrum tx itsmillertime Aircraft - General - Radio Equipment (FS/W) 1 Mar 20, 2012 05:37 AM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 01:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 12:38 PM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz Radios 2 May 09, 2011 12:38 AM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz XHeli 0 May 06, 2011 12:19 AM
