Old Mar 13, 2012, 07:52 PM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
SadSack is offline Find More Posts by SadSack
Old Mar 14, 2012, 03:57 AM
FDR_ is offline
Find More Posts by FDR_
Joined May 2011
Originally Posted by rcH4x0r View Post
Ah, ok, I understand. Working on 0.2B :s
Edit: Meh, something horrible going on with the string encoding, I will look in more detail at the weekend. For now you can us ethe tool to change bitmaps and export strings for different languages
Solution: You have to create a new instance of the UTF7Encoding instead of using the UTF7 property of the Encoding class, with a true parameter in the constructor to allow optional characters!
In VB:
Dim e As New System.Text.UTF7Encoding(True)
e.GetBytes(...)
In C#:
System.Text.UTF7Encoding e = new System.Text.UTF7Encoding(true);
e.GetBytes(...);
FDR_ is offline Find More Posts by FDR_
Old Mar 14, 2012, 04:29 AM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Didn't see an answer to my previous question. If I want to add a FrSky system to the Devo12, where would I solder the +,-, and PPM wire on the circuit board? I noticed a positive, negative, and tx pinout on the middle of the back of the board, is it really that easy?
Sid3ways is offline Find More Posts by Sid3ways
Old Mar 14, 2012, 11:17 AM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
Added additional 5 or 6 close ups of 10mw Devo 8
https://picasaweb.google.com/1049870...85764560799298
While I was in again I figured I'd try swapping the RF module from 100mW 7 to 10mW 8 --- not the solution to more power it seems. Must be something in the board making it 'know' it's crippled.
thwaitm is offline Find More Posts by thwaitm
Old Mar 14, 2012, 11:46 AM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
I told you before the trainer port outputs PPM, you will have to do + and - yourself to the power source in whatever manner you want.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Mar 14, 2012, 12:02 PM
Sid3ways is offline
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Do you happen to know the pin-out on this picture? Is it TX pin?
Old Mar 14, 2012, 12:39 PM
Joined Oct 2011
Which wire set is going to the trainer port? (I am going to guess the black and white ones)
Old Mar 14, 2012, 02:24 PM
Sid3ways is offline
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Here are very detailed pictures posted by sglim.
I'm at work now so can't look for you but hopefully these may give you better clarification?
http://www.rcgroups.com/forums/showp...&postcount=104
Old Mar 14, 2012, 05:16 PM
derek4610 is offline
Find More Posts by derek4610
Joined Dec 2009
Serial Flash
Tx has 32 Mbit SPI Serial Flash. This can be increased if needed.
Keep Hacking
derek4610 is offline Find More Posts by derek4610
Old Mar 15, 2012, 08:00 AM
mescalinedream is offline
Find More Posts by mescalinedream
Joined Jul 2008
I had emailed Walkera about the update for the Devo 7. I asked how do we update our devo 7 without the ub02 usb to mini cable that the devo 7 update software says is needed. She replied to tell me that the ub02 will be available soon from hobbyone.hk.
You guys with your devo 6, 8, 12 are lucky compared to us devo 7 owners. We get a software update but cant even install it! Is anyone going to start their magic at the devo 7 software?
mescalinedream is offline Find More Posts by mescalinedream
Old Mar 15, 2012, 01:23 PM
achogg33 is offline
Find More Posts by achogg33
Joined Oct 2011
Do you think we will be able to hack it to use Dsm2 spektrum protocol?
achogg33 is offline Find More Posts by achogg33
Old Mar 15, 2012, 06:40 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
You could probably put together a DSM2 hack with a DSM2 module from a toy Spectrum radio and some soldering like they have done with the Turnigy 9x.
Note that the channel order might be incorrect but if all you want is to use it with cheap orange receivers as an alternative to the RX801 then this should not be a problem.
Atomic Skull is offline Find More Posts by Atomic Skull
Old Mar 15, 2012, 07:06 PM
achogg33 is offline
Joined Oct 2011
That would be awesome!
Old Mar 15, 2012, 07:22 PM
Joined Oct 2011
Hrm... I have a parkzone TX.... I might have to do some experimenting , question is can the module inside transmit all 8 channels or is it limited to the 4 it's designed for?
Old Mar 16, 2012, 05:11 AM
rcH4x0r is offline
Find More Posts by rcH4x0r
Joined Jun 2010
Thanks FDR_, I will get on that shortly.
In other news, my ST-Link arrived today, just waiting for the DEVO8 now...
I have a toy HobbyZone DSM2 TX here, gonna rip it to bits and take a look... Yep, its a CYRF6936 (with some additional micro interfacing the CYRF chip to the main MCU via a serial port). Maybe put the LA on that later
rcH4x0r is offline Find More Posts by rcH4x0r
Wanted Broken Walkera Devo and Spektrum tx itsmillertime Aircraft - General - Radio Equipment (FS/W) 1 Mar 20, 2012 04:37 AM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 12:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 11:38 AM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz Radios 2 May 08, 2011 11:38 PM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz XHeli 0 May 05, 2011 11:19 PM
