Old Mar 13, 2012, 01:45 PM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
so whats the ETA on Doom and what frame rate you getting so far?
SadSack is offline Find More Posts by SadSack
Old Mar 13, 2012, 01:51 PM
FDR_ is offline
Find More Posts by FDR_
Joined May 2011
Originally Posted by NorCalMatCat View Post
It would seem straight black is the transparency bit?
Yes it is, but I think it doesn't use transparency for all pictures...
I made a very simple DEVO 8 v0.0.5 library for increased visibility with the previous version of rcH4x0r's lib tool:
http://rc.fdr.hu/devo.php#cust_lib
I dismissed the fancy backgrounds too...
FDR_ is offline Find More Posts by FDR_
Old Mar 13, 2012, 02:01 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Well I discovered if you have straight black on a background (like the boot sequence) it will mess up rendering of transparent images ontop, I.E. it messes up rendering the bind animation ontop of black, seems like a basic bit antilogarithm being used to do alpha, reminds me of doing the old transparency trick back in the old VB days!
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Mar 13, 2012, 03:17 PM
rcH4x0r is offline
Find More Posts by rcH4x0r
Joined Jun 2010
Originally Posted by FDR_ View Post
Something went wrong with the strings!
The tool replaces the special characters like "!", "%" or "" with some mess...
Eh? Where? I know the Chinese chars are messed up in the String view....
The RTF files have to be decoded as UTF7 (Euro) and Big endian Unicode (Chinese)
I will be away for a couple of days, I can look at bugs over the weekend
Hopefully my Devo8S will arrive next week and I can spend some time figuring out the HW. Thanks for all the pics
rcH4x0r is offline Find More Posts by rcH4x0r
Old Mar 13, 2012, 03:36 PM
FDR_ is offline
Joined May 2011
Do you remember in my first version of hacked library I complained, that the exclamation at the end of the "Saving, please wait!" message went wrong?
I did't payed too much attention to it, because it was a single edit, but your tool seems to refresh all the strings, so it happens in more places.
Somehow the UTF-7 conversion goes wrong and from a single exclamation mark it makes "+ACE-"
I will be out from thursday to sunday too, so next week...
Old Mar 13, 2012, 03:43 PM
rcH4x0r is offline
Joined Jun 2010
Is this happening in the app itself or when you open the file in a text editor?
If you don't tell the text editor to use UTF-7 then you will get +ACE- (this happens if I open it in notepad / wordpad). I use Word and it prompts me to select the encoding
Old Mar 13, 2012, 03:58 PM
FDR_ is offline
Joined May 2011
After saving with the app, it will be wrong in the hex editor and in the tx too...
Old Mar 13, 2012, 04:09 PM
rcH4x0r is offline
Joined Jun 2010
Working fine here when edited using Word.
Which editor are you using to modify the strings? Have you told the editor the file is encoded using UTF-7?
Old Mar 13, 2012, 04:12 PM
FDR_ is offline
Joined May 2011
No, I haven't even touched the strings! I just replaced bitmaps...
But after the tool saves the DFU file these characters will be messed up.
Old Mar 13, 2012, 04:20 PM
rcH4x0r is offline
Joined Jun 2010
Ah, ok, I understand. Working on 0.2B :s
Edit: Meh, something horrible going on with the string encoding, I will look in more detail at the weekend. For now you can us ethe tool to change bitmaps and export strings for different languages
Old Mar 13, 2012, 04:46 PM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
I guess here is as good of a place as any to ask this question since most of you know the inner workings of this these things.
I have a Devo12, I was wondering if anyone has found a PPM out by chance on the compatible receivers? If not I'm going to be hacking with a FrSky module, anyone know the pinouts on where to hook up the +,-,and PPM?
Thanks!
Andy
Sid3ways is offline Find More Posts by Sid3ways
Old Mar 13, 2012, 04:50 PM
Joined Oct 2011
Thanks!
Andy
The RX's have no PPM method, the only PPM stream you can get is from the DST port.
Old Mar 13, 2012, 05:46 PM
derek4610 is offline
Find More Posts by derek4610
Joined Dec 2009
DEVO 6 TX Antenna COAX?
The original antenna on the DEVO 6 TX is coax stripped to 32mm. If you want to increase your transmission range to be compatible with the DEVO 8 and DEVO 12 you may want to replace it with a 2dBi antenna. See pics.
If anyone needs more pics or a parts list let me know.
Hack away.
derek4610 is offline Find More Posts by derek4610
Old Mar 13, 2012, 07:43 PM
Joined Dec 2009
My new background DEVO 6
Just one of my new backgrounds.
Old Mar 13, 2012, 07:45 PM
Joined Oct 2011
The perfect thing to have on your radio and look at while flying a heli
Wanted Broken Walkera Devo and Spektrum tx itsmillertime Aircraft - General - Radio Equipment (FS/W) 1 Mar 20, 2012 04:37 AM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 12:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 11:38 AM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz Radios 2 May 08, 2011 11:38 PM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz XHeli 0 May 05, 2011 11:19 PM
