Old Mar 12, 2012, 09:32 PM
Hellraser is offline
Find More Posts by Hellraser
Hellraser's Avatar
UK
Joined Jul 2007
Originally Posted by rcH4x0r View Post
Edit: It looks like both DAC pins are in use for SPI (PA4 & PA5) and I can't see any refs to the DAC base address in the code. I wonder where the catchy tunes are coming from?
If you ever find where the tunes are coming from - I would be delighted with a mod to shut them all up
Regards David
Hellraser is offline Find More Posts by Hellraser
Old Mar 12, 2012, 09:36 PM
itsmillertime is offline
Find More Posts by itsmillertime
United States, TN, Memphis
Joined Dec 2011
The latest Walkera firmware update makes the tunes a much more bearable single beep as well as gives you two throttle activated switches. I'm still subscribed and interested in a Devo8S that I can fly anything with though.
itsmillertime is offline Find More Posts by itsmillertime
Old Mar 12, 2012, 09:48 PM
OnceAFly is offline
Find More Posts by OnceAFly
OnceAFly's Avatar
Singapore, Singapore
Joined Oct 2011
Hope to see some changes on devo12 theme and stupid tone!! By the way what library editor you guys using?
OnceAFly is offline Find More Posts by OnceAFly
Old Mar 12, 2012, 09:53 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
I am looking over the datasheet for the ARM chip to see if I can help figure out the hardware aspect... You can find it here: http://www.st.com/internet/com/TECHN...CD00191185.pdf
The chip is an xC class, this PDF has complete hardware specs.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Mar 12, 2012, 10:03 PM
Joined Oct 2011
CPU Pin Out
Old Mar 12, 2012, 10:07 PM
Atomic Skull is offline
Find More Posts by Atomic Skull
Atomic Skull's Avatar
Joined Dec 2011
New firmware removes the shutdown tune. Now it just goes "BEEP! (shutdown)"
Atomic Skull is offline Find More Posts by Atomic Skull
Old Mar 13, 2012, 06:51 AM
FDR_ is online now
Find More Posts by FDR_
Joined May 2011
@rcH4x0r:
Something is fishy with the resource tables! While in the devo8 v0.0.4 lib the addresses are continuous and the last one point to the end, the others (f.e. v0.0.5) have wrong closing address, or in case of the devo12 there a holes in the table.
Do you have an algorithm to detect them right, or you just eyeballed all for the right addresses?
FDR_ is online now Find More Posts by FDR_
Old Mar 13, 2012, 07:33 AM
rcH4x0r is offline
Find More Posts by rcH4x0r
Joined Jun 2010
I have updated my first post with a link to v0.2, it now handles strings & bitmaps.
@FDR_, the resources are a bit of a mess if you ask me, for strings I just eyeballed them. Devo6 V0.3 bmps also got broken, the DEVO-12 is a bit different again :s
rcH4x0r is offline Find More Posts by rcH4x0r
Old Mar 13, 2012, 08:04 AM
FDR_ is online now
Joined May 2011
I can handle the holes: I know where the first entry is (0x30 except for DEVO 10 and 12 where it is 0x40), then I read every 4 bytes which is not 0 into a table until the address of the first entry, then sort the table.
Worst are the wrong end addresses, because they split the last resource in two...
Old Mar 13, 2012, 08:31 AM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
Would it be an idea to inform people not to get newest firmware till you've got it sorted?
Just on the off chance Walkera do something with code that " stops " what your doing or least hinders it.
SadSack is offline Find More Posts by SadSack
Old Mar 13, 2012, 11:31 AM
derek4610 is offline
Find More Posts by derek4610
Joined Dec 2009
DEVO 6, 8, 12 RF module PIC
RF output module, DEVO 6, 8, 12.
derek4610 is offline Find More Posts by derek4610
Old Mar 13, 2012, 12:01 PM
Joined Oct 2011
Getting time out issues trying to get to your site.
Old Mar 13, 2012, 12:35 PM
Joined Dec 2011
I had hoped a solution would be found to use Walkera protocols with the 9x but now I like my Devo 8S so much that I'd like for it to be able to communicate with Frsky receivers/ telemetry. Since the Walkera receivers are so limited with no satellites or micros.
Old Mar 13, 2012, 01:27 PM
FDR_ is online now
Joined May 2011
I have updated my first post with a link to v0.2, it now handles strings & bitmaps....
Something went wrong with the strings!
The tool replaces the special characters like "!", "%" or "" with some mess...
Old Mar 13, 2012, 01:29 PM
Joined Oct 2011
It would seem straight black is the transparency bit?
Wanted Broken Walkera Devo and Spektrum tx itsmillertime Aircraft - General - Radio Equipment (FS/W) 1 Mar 20, 2012 04:37 AM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 12:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 11:38 AM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz Radios 2 May 08, 2011 11:38 PM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz XHeli 0 May 05, 2011 11:19 PM
