Old Apr 20, 2012, 04:30 AM
rcH4x0r is offline
Find More Posts by rcH4x0r
Joined Jun 2010
Bootloader dumper:
http://dl.dropbox.com/u/59258955/bldump.zip
If you have a 10mW Devo8 (and would like a 100mW Devo8) then please try the following:
-BACKUP your model settings, this tool overwrites slots 1-4 (You can use the ST DFU tool to do this)
-Download & unpack the bldump.zip file
-Update your TX with the dumper
-Turn on the Tx, it will _briefly_ display "DUMPING" then "DONE"
-Go back to DFU update mode & use the ST DFU tool to read Target ID: 01 SPI Flash: Config
-Upload the file & send me a link (please)
Download ST Tool
rcH4x0r is offline Find More Posts by rcH4x0r
Old Apr 20, 2012, 07:41 AM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
Originally Posted by rcH4x0r View Post
Bootloader dumper:
Download ST Tool
Hopefully this has what you need.
http://dl.dropbox.com/u/74641395/Target01.7z
thwaitm is offline Find More Posts by thwaitm
Old Apr 20, 2012, 07:49 AM
rcH4x0r is offline
Joined Jun 2010
Yep, that will do nicely 1 byte diff at 0x1007, better fix my BL id code...
Thanks for doing that, I will brew up a patched DFU for you shortly (out of town Saturday-Tuesday)
Old Apr 20, 2012, 08:00 AM
thwaitm is offline
Team WarpSquad
Joined Jun 2011
I'm not near my Tx for about 20 days :-( so unless you can do it before about 15:00 JST (GMT +9) tomorrow... no rush!!
Old Apr 20, 2012, 09:06 AM
PhracturedBlue is offline
Find More Posts by PhracturedBlue
Joined Jan 2012
We're happy to announce a new project to develop an open-source firmware for Walkera Devention transmitters (and maybe others some day)
The project's name is 'Whippet' (thanks pmackenzie)..if you don't understand why, try googling 'DEVO'
The source repository can be found here:
https://bitbucket.org/PhracturedBlue/whippet
We're using Mercurial for source distribution (personal preference)
The current code has what has already been posted plus a few additional fixes.
I've also included an 'emulator' target. The purpose of the emulator is to allow easy GUI development. It will build natively on a PC (no cross compiler) and provides a 320x240 screen that behaves like the DEVO8 screen. keys 0-9 behave like buttons, q/a are throttle up/down, w/s are rudder up/down, e/d are elevator up/down, r/f are aileron up/down. Use 'x' to guit the emulator.
The gui is built with fltk which should be easy enough to run on all platforms. i do my development on Linux, so i can't give instructions for building on Windows, though it should be easy enough to do.
Things are still pretty crude, but use:
'make' to build a devo-8 DFU
and
'make -f Makefile.emu' to build the emulator
Since mercurial is a DVCS I won't be providing commit access immediately to anyone else. If someone wants to work on the code, you can just send me pull-requests, and I'll merge as appropriate. Once you've proven to be a trusted contributor, we'll open up commit access to the primary repository.
PhracturedBlue is offline Find More Posts by PhracturedBlue
Old Apr 20, 2012, 10:06 AM
rcH4x0r is offline
Joined Jun 2010
Hacked up DFUs sent to thwaitm, if he reports success I will share them with any one who wants "mo' power" (and who doesn't?)
Old Apr 20, 2012, 10:24 AM
thwaitm is offline
Team WarpSquad
Joined Jun 2011
Success!!!
And I can hear a slight hum which is stronger at 15 and then again at 20dB so I guess it really is increasing the power... and maybe shortening the life of my D8...
Old Apr 20, 2012, 10:45 AM
rcH4x0r is offline
Joined Jun 2010
Battery life maybe
Anyway, that's good news. Binaries here (8 & 8S):
http://dl.dropbox.com/u/59258955/Hacked-Devo8.zip
Old Apr 24, 2012, 05:41 PM
englanito is offline
Find More Posts by englanito
addicted to the sound ehhhhhhh
Joined Dec 2011
good work guys im just starting to get excited about changing my whole screen setup.
englanito is offline Find More Posts by englanito
Old Apr 24, 2012, 05:47 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
I know it's a bit early for it but I want to document a feature I plan to implement... switchable trims , not something I ever thought about until I got my AP, as once in any AP function any trim settings tend to get reversed (my AP requires trims be physically proper and neutral with no radio trim), so with switchable trim I could assign it to my AP switches so that I have a different trim setting for non-AP and with AP.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Apr 27, 2012, 08:39 PM
Joined Oct 2011
Been quiet in here for a few days... How is it coming along?
Old Apr 27, 2012, 09:00 PM
Joined Jan 2012
There's been good progress. We have firmware that can:
* communicate with the radio
* read all 4 sticks
* read all buttons
* draw on the LCD with a set of primitive graphics functions (circle, rectangle, line, text, etc)
* read the battery voltage
* communicate with the USART
* read/write to the SPI flash
* read from the touch screen
The firmware supports building on PC with a virtual LCD to enable GUI development.
The following tasks are underway:
* providing a software stack that can communicate with an Rx (it is likely this will be done with a hacked-in 'DSM module' initially so we don't need to understand the protocol to get things working
* setting up a filesystem such that you can treat your Transmiter like a USB drive to upload model and theme info
* understand the DEVO-8 model info
Development has moved to a new forum, and the project has a new name. I'll let FDR announce it when he's ready.
I've included the current test firmware if someone wants to see what it can do.
We're probably at the point where we could use help with the GUI development if there are any interested programmers out there, but be aware that we are still a ways away from being able to control any model, much less a Walkera model.
Old Apr 27, 2012, 09:04 PM
Joined Oct 2011
I don't mind working on GUI stuff if you can send PM link to where I can take a look at whats going on.
Old May 02, 2012, 01:52 PM
upside_down is offline
Find More Posts by upside_down
Germany
Joined Apr 2012
I would like to change the background colour of some input fields with my DEVO 6.
With LIBRARY version 0.2 it was possible with the Walkera Lib Tool V0.2A.
Unfortunately Walkera removed the appropriate bitmaps with the current LIBRARY (version 0.3).
Can someone help me?
Does someone have an hint for me?
upside_down is offline Find More Posts by upside_down
Old May 03, 2012, 02:56 AM
FDR_ is online now
Find More Posts by FDR_
Joined May 2011
It doesn't work for devo 6 v0.3 because Walkera messed up the resource table, so the tool doesn't see all the bitmaps. A future version will, perhaps...
FDR_ is online now Find More Posts by FDR_
Wanted Broken Walkera Devo and Spektrum tx itsmillertime Aircraft - General - Radio Equipment (FS/W) 1 Mar 20, 2012 04:37 AM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 12:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 11:38 AM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz Radios 2 May 08, 2011 11:38 PM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz XHeli 0 May 05, 2011 11:19 PM
