Old Apr 03, 2012, 06:05 PM
PhracturedBlue is offline
Find More Posts by PhracturedBlue
Joined Jan 2012
Originally Posted by rcH4x0r View Post
Eh? We already know you can mod the FW & it still runs, not sure how you can brick anything.
My only thought was whether any of the code after 08004000 was actually used by the bootloader. So wiping the 08004000 data COULD result in bricking. I didn't say it was likely, but I also have no backup should something happen.
Build a landing zone - lots of NOPs (or whatever in ARM world) and put the dump code at the end, CPU jumps into NOPs then runs into your payload, it doesn't matter where it jumps to
If you prefer you can always write to SPI flash and dump using DFU tool...
That is a good idea. Then anyone can dump their bootloader rather than needing some specialized hardware. I need to find a compiler tool-chain for working with the STM32. I haven't actually compiled anything for ARM for many years now.
PhracturedBlue is offline Find More Posts by PhracturedBlue
Old Apr 03, 2012, 06:11 PM
rcH4x0r is offline
Find More Posts by rcH4x0r
Joined Jun 2010
If it depends on code outside the bootloader then it's a _very_ poor bootloader. Of course, this is Walkera we are talking about so anything is possible
Codesourcery or YAGARTO are what you need
rcH4x0r is offline Find More Posts by rcH4x0r
Old Apr 03, 2012, 10:06 PM
OnceAFly is offline
Find More Posts by OnceAFly
OnceAFly's Avatar
Singapore, Singapore
Joined Oct 2011
Originally Posted by FDR_ View Post
I guess he meant the rx firmware should be new! So according to him there might be different versions of the rx801...
Oh! That's suck...think i got the old rx fw on both of them...
OnceAFly is offline Find More Posts by OnceAFly
Old Apr 04, 2012, 10:06 AM
Joined Jan 2012
I forgot how much programming these ARM uC sucks compared to the simler AVR or PIC I more often work with. The ST Standard Library is pretty non-intuitive to me.
Anyhow, I got Sourcery installed, figured out how to change the ROM address, and used this as a starting point (It makes programming feel a lot more like other microcontrollers):
http://wiki.seabright.co.nz/wiki/HelloSTM32.html
But ran out of time before I got a chance to install it to the tx after modifying it to use PA13. Hopefully I'll get to it tonight.
As for copying the bootloader into the SPI Flash, do you know if the bootloder screen is stored there? It would seem that it probably is, and I wouldn't want to break the bootloader by overwriting the image with code. I suppose the model-memory may be a safer place to start. We only need 0x4000 bytes.
Old Apr 04, 2012, 04:36 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
The bootloader screen is stored in the library I believe...
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old Apr 04, 2012, 09:19 PM
Joined Jan 2012
Well that was interesting.
I created a simple firmware which should have toggled the TMS/TCK pins based on the link above. I changed the address offset to 08004000, shortened the vector table to 5 entries, filled a couple thousand bytes with NOP followed by a jump to the reset_vector
I loaded it via dfuse-util (compiled with dfuse support). Everything seemed to load fine, but when I shut off the Tx, it wouldn't power down, instead going into an infite reboot loop back to the programming menu (reset->programming menu->reset). powering back on put it back at the programming menu. pulling the battery finally shut it off, and when I plugged it back in, it stayed off. but turning on the Tx immediately entered the programming mode (without me pressing the Ext key)
I tried to flash back the Devo 0.7 firmware using dfuse-util, but while it said successful, the tx behaved exactly the same (reboot loop on power off, and right to programming mode when powered on)
I then tried to program using the DFuse Demo on Windows (programming both the FW and Lib). Same thing.
I downloaded the DEVO programming software, and tried that (FW and Lib), and this time the Tx behaved properly on powerdown and powered up as normal.
I'm not sure if it was a timing issue, where reprogramming multiple times with the other software would have been sufficient, or if there was something special about the DEVO software, but it gave me a bit of a scare..
Next I may try hacking my code into the real DEVO firmware somewhere in the middle and see if i can get it to execute.
Old Apr 04, 2012, 09:26 PM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
Thanks for taking the risk.
Originally Posted by itsmillertime View Post
Where's the donate button?
Would it be good idea start thinking about doing this? Your taking the risk at your own $ Might be better to spread that risk with others .
I'm in and sure others would be too.
7000+ views there's interest in this.
SadSack is offline Find More Posts by SadSack
Old Apr 04, 2012, 09:34 PM
Joined Jan 2012
Personally, I have no interest in donations, this is just a hobby for me, and taking money would make me feel beholden to working on this, which would take all the fun out of it. The only thing I really risked was that I may have needed to do a full-wipe and either start work on a from-scratch firmware or wait until someone else downloaded the bootloader. I can't speak for anyone else of course, but for me, just playing around with this thing with the hope of making something really cool is enough
Old Apr 04, 2012, 09:37 PM
itsmillertime is offline
Find More Posts by itsmillertime
United States, TN, Memphis
Joined Dec 2011
Well I'm too dumb to do it and have no qualms about "tipping" (that better?) you guys that can. I'll be very happy when I can bind spektrum micro rx's with my Devo 10.
itsmillertime is offline Find More Posts by itsmillertime
Old Apr 04, 2012, 11:44 PM
Joined Jan 2012
Well, I think I was able to get my code to load without causing an infinite reboot. I did it by embedding it in a real firmware image and recalculating the CRC. I'm not sure if it was because I'm now using the DEVO programmer, if my dfu container wasn't quite right, or if it is because I left most of the firmware code intact. Of course the code didn't actually run as expected, but that is probably me not getting all the right incantations to enable the GPIO properly. I also had no issue swapping back to the default firmware, so I guess if I can figure out what is wrong with my code, I should be able to make more progress.
Old Apr 05, 2012, 01:20 AM
FDR_ is offline
Find More Posts by FDR_
Joined May 2011
Wow, congrats!
That is the most common sw "bug" in the DEVO land, that the tx restarts after turning off. It happens when a simple DEVO 8 gets the firmware of the 8S, or even happens when someone uses some lipos. After all the power switch is not a real one but only a software switch...
FDR_ is offline Find More Posts by FDR_
Old Apr 05, 2012, 05:41 AM
SadSack is offline
Joined Aug 2008
That's a fair comment and i have no wish to remove the FUN from this but i'm open to helping.
Old Apr 05, 2012, 06:53 AM
mescalinedream is offline
Find More Posts by mescalinedream
Joined Jul 2008
I dont know who else to ask. it seems if anyone would know the answer to this question then you guys would.
The UP-02 is now available at hobbyone.hk. If you have no idea what this is then I will tell you. Walkera made updates available for all radios. I have a Devo 7 and went to their website to download the new updates. In their update software there was a .pdf that had said "to update your Devo 7 you will need the UP-02 dongle" I loooked in my Minicp rtf box with Devo7 and there is no UP-02!
I contacted Walkera and there reply was " the dongle will be available soon". I could not believe they had a update available but no way to use it. 3-10-12 is when I emailed Walkera, they just responded today.
So here is the new dongle
Its going to cost 16.00 + 18.77 for for the cheapest shipping rate to Michigan according to hobbyone.hk site!. I would think the official updater dongle should be free or a little cheaper.
So instead of paying 34.77 to update my devo 7, can i use something other then the official UP-02 updater dongle? Also, it seems Walkera has a Sim dongle called UB-001, the stereo end/trs has only 1 black ring, The UP-01 has 2 black rings on the mini 3.5mm cable end.
mescalinedream is offline Find More Posts by mescalinedream
Old Apr 05, 2012, 07:53 AM
thwaitm is offline
Find More Posts by thwaitm
Team WarpSquad
United Kingdom, England, Royal Leamington Spa
Joined Jun 2011
The best idea would seem to be for us to buy one between 30 of us and then just pay a dollar and postage to the next person on the list...
or to all contribute a dollar to someone who can reverse engineer it and make a $5 dollar clone.
It also now seems like the one biggest reason *NOT* to buy a DEVO 7 and to get a 6,8,10 or 12 instead.
thwaitm is offline Find More Posts by thwaitm
Old Apr 05, 2012, 07:58 AM
FDR_ is offline
Joined May 2011
I would simply wait while others have it in stock. At least the shipping cost will be cheaper...
Wanted Broken Walkera Devo and Spektrum tx itsmillertime Aircraft - General - Radio Equipment (FS/W) 1 Mar 20, 2012 04:37 AM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 12:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 11:38 AM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz Radios 2 May 08, 2011 11:38 PM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz XHeli 0 May 05, 2011 11:19 PM
