Old Mar 30, 2012, 06:50 PM
Joined Dec 2009
Compatible DEVO 6 Receivers ?????????
Here are the compatible receivers for the DEVO 6 transmitter.
RX-701 receiver, 100% compatible.
RX-801 receiver, old firmware are not compatible.
RX-801 receiver, newer firmware 100% compatible.
RX-802 receiver, 100% compatible.
If you plan on buying more receivers for the DEVO 6, buy the RX-701 or the RX-802.
The RX-802 has the coax antenna's, these are great for carbon fiber models.
If you buy the RX-801 your playing the lottery on if it has old or new firmware.
Hope this helps DEVO 6 owners.
NOTE: all the above mentioned receivers work with the DEVO 8.
These DEVO's are too cool.
derek4610 is offline Find More Posts by derek4610
Old Mar 31, 2012, 04:21 AM
Joined Dec 2011
Other than the antennas how is the RX802 different than the RX801? What's the advantage of the antennas over the ones on the RX801?
Atomic Skull is offline Find More Posts by Atomic Skull
Old Mar 31, 2012, 04:27 AM
Joined May 2011
It has telemetry, ie it is transmitting too, that is the larger antennas for...
FDR_ is offline Find More Posts by FDR_
Old Mar 31, 2012, 05:53 AM
France, IdF, La Courneuve
Joined Nov 2011
Hi, the dx6i antenna mod is good on devo 6 thank you Derek.
Geehome is offline Find More Posts by Geehome
Old Mar 31, 2012, 07:26 AM
Joined Dec 2009
RX-802 frame rate selectable.
11 Millisecond and 22 Millisecond Frame Rate Selectable
Old Mar 31, 2012, 07:43 AM
Joined Nov 2011
I don't try change my frame rate on my 802 is fixed in 22ms How do you change ?
Old Mar 31, 2012, 10:46 AM
Heli Crash Survivor
Crash Survivor's Avatar
United States, AR, North Little Rock
Joined Feb 2011
Does any of the 3 version of the Walkera Lib 2.exe fix the +ACO- from not showing up in the throttle curve menu?
Crash Survivor is offline Find More Posts by Crash Survivor
Old Mar 31, 2012, 01:14 PM
Joined Jun 2010
No, but I can probably have another go at it (while waiting for my Devo8 <grrr>)
rcH4x0r is offline Find More Posts by rcH4x0r
Old Mar 31, 2012, 01:19 PM
Heli Crash Survivor
Joined Feb 2011
Thanks. Waiting for things you need is very aggravating. Hope it arrives soon.
Old Apr 01, 2012, 01:50 AM
addicted to the sound ehhhhhhh
Joined Dec 2011
Wow hobbies ships fast
englanito is offline Find More Posts by englanito
Old Apr 02, 2012, 08:37 PM
Joined Jan 2012
Well, I've got my Devo-8 and STLink/V2 now. I'll be playing with it tonight, and hopefully will have something to report out soon.
PhracturedBlue is offline Find More Posts by PhracturedBlue
Old Apr 02, 2012, 08:38 PM
Better then Sliced Bread!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
Fantastic!
NorCalMatCat is offline Find More Posts by NorCalMatCat
Latest blog entry: Flying in the Neighborhood
Old Apr 02, 2012, 09:14 PM
Joined Jan 2012
Unfortunately, I immediately hit a road-block...
The ST-Link software can see the STM32F103VCT6, but I immediately get this:
Code:
19:06:59 : Cannot read memory!
                  Disable Read Out Protection and retry.
19:09:28 : Connected via SWD.
19:09:28 : Device ID:0x414
19:09:28 : Device family :STM32F10xxx High-density device
19:09:28 : Cannot read memory!
19:09:29 : Connection to device is lost!
19:09:30 : No target connected
It doesn't stay connected long enough for me to be able to be able to do anything else
I don't really know much about the STLink or the memory-protection available in these processors, so I'll likely do some reading on that and see what options we may have.
Old Apr 02, 2012, 10:06 PM
Joined Jan 2012
Here is a bit more info:
The relevant section about protection is section 2.4 of the Programming manual (PM0042)
This discussion contains some interesting info regarding read-protection.
If we want to start from scratch, it should be trivial to mass-erase the Flash memory and reset the read-protect bit, but since we don't have many of the pages, it wouldn't be possible to flash back, so this isn't a good idea until we've dumped the original ROM.
Since we CAN write to the ROM at 0x08004000 via SFU, and even with the read-protect-bit set, code can access ROM when not in DEBUG mode, it will likely be pretty easy to write a function to dump the ROM (probably out the SWD pins since they are easily accessible) and load that code via SFU. We need to find an entry point where we can put the code, and it'll definitely slow things down, but I don't see the RDP as a show-stopper (though it may make my stlink less useful (and my logic-analyzer more useful).
It does however mean I won't have time to work on this much for the next several days.
Old Apr 03, 2012, 02:02 AM
OnceAFly's Avatar
Singapore, Singapore
Joined Oct 2011
Hum...May i ask how you get the 801 to bind on devo6? I have the latest firmware 0.5 and it only bind on 802 not 801...
OnceAFly is offline Find More Posts by OnceAFly
Wanted Broken Walkera Devo and Spektrum tx itsmillertime Aircraft - General - Radio Equipment (FS/W) 1 Mar 20, 2012 04:37 AM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 12:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 11:38 AM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz Radios 2 May 08, 2011 11:38 PM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz XHeli 0 May 05, 2011 11:19 PM
