Old Feb 13, 2013, 05:56 PM
Mullson is offline
Find More Posts by Mullson
Joined Jan 2013
May be like this?
May be like this?
Mullson is offline Find More Posts by Mullson
Old Feb 13, 2013, 06:00 PM
PhracturedBlue is offline
Find More Posts by PhracturedBlue
Joined Jan 2012
Originally Posted by victzh View Post
@PhracturedBlue BTW do you have schematics for power circuit for Devos? I recall that you mentioned it somewhere, and as I now have Devo 10 I can experiment freely with my defective Devo 7 which has power problem - it does not switch off. So if you already traced it it would help me.
This is the one I did way back when:
http://www.rcgroups.com/forums/attac...mentid=5092867
PhracturedBlue is offline Find More Posts by PhracturedBlue
Old Feb 13, 2013, 08:20 PM
gapi is offline
Find More Posts by gapi
gapi's Avatar
North Georgia
Joined Oct 2010
Originally Posted by Mullson View Post
May be like this?
HeH! Thanks guys.
gapi is offline Find More Posts by gapi
Old Feb 17, 2013, 03:04 PM
yoodog is offline
Find More Posts by yoodog
Joined Feb 2012
Hi guys!! I have been this thread for almost 3 hours now, it is very long! =D But it doesn't seem to answer my question anywhere... Sorry if it did..
My question is whether Walkera Devo series supports FatShark Dominators Head Tracker??
It uses Trainer port, but I don't get how do I connect and set it up to work...
PS: normal male 3.5mm to male 3.5mm cable, like the one in speakers ?....
Thank you, It is very important ...
yoodog is offline Find More Posts by yoodog
Old Feb 19, 2013, 12:51 PM
oazgasme is offline
Find More Posts by oazgasme
Joined Feb 2012
Originally Posted by gektor View Post
Here we go, the first Video of the GDevention Library hits YouTube:
http://www.youtube.com/watch?v=Kr8CbrOVjsg
Hi!!! Iīve just downloaded &put your interface!!!!! Itīs great!!!!
Is there any possibility to add an airplane image instead ladybird??
Thanks a lot
oazgasme is offline Find More Posts by oazgasme
Old Feb 20, 2013, 07:25 AM
djtrance is offline
Find More Posts by djtrance
Joined Feb 2007
HI, I'm looking to buy a new remote control, and I found the new DEVO F7 with video rx, I don't know if this control can support the special firmware.
some one can tell me if it is possible to port the firmware to this device?
djtrance is offline Find More Posts by djtrance
Old Feb 20, 2013, 07:36 AM
FDR_ is offline
Find More Posts by FDR_
Joined May 2011
The DEVO 7, F4 and F7 are not supported by deviation.
The 7 probably never will be.
The F4 and F7 has limited display capabilities (no graphs), which would make porting a bit pointless, but all depend on how much PhracturedBlue will be bored after porting it to the DEVO 12...
FDR_ is offline Find More Posts by FDR_
Old Feb 20, 2013, 08:06 AM
gapi is offline
gapi's Avatar
North Georgia
Joined Oct 2010
Get the DEVO 10. And usually the RX that comes with them has no Gyro. Just my 2cents.
Old Feb 21, 2013, 08:57 AM
djtrance is offline
Joined Feb 2007
do you know wich lcd has?
Old Feb 21, 2013, 09:01 AM
FDR_ is offline
Joined May 2011
I don't think it's the limitation of the LCD display, but rather of the OSD component, since it seems that they simply overlay the menu text onto the video display...
Old Feb 23, 2013, 07:39 PM
Steve C is offline
Find More Posts by Steve C
Carbon fiber is our friend
Steve C's Avatar
United States, CA, Lodi
Joined Feb 2001
Anybody else having problems with deviation v2.1.1 crashing (reboot) when you try to assign a switch to a complex mix? I'm having this problem with a devo10 and I've tried reflashing but it's still messed up. My devo8s did this once, but I reflashed it and it has worked perfectly since.
I'm trying to work up a program for sailplane thatt will require several complex mixes, so I really need to figure this out.
Steve C
Steve C is offline Find More Posts by Steve C
Old Feb 23, 2013, 07:54 PM
Joined Jan 2012
Steve C
It's a known bug in 2.1.xx It has been fixed in the codebase, and will be in the next release
Old Feb 23, 2013, 11:35 PM
lasakro is online now
Find More Posts by lasakro
Seeking Control
lasakro's Avatar
United States, NY, Amsterdam
Joined Dec 2012
How about the bug with the 2801 receiver where you only can bind during the last 2 seconds of the timer countdown. Anything before that causes the servo's to come up in a strange position. A subsequent re-power of the heli will then correct this.
lasakro is online now Find More Posts by lasakro
Old Feb 24, 2013, 10:10 AM
Steve C is offline
Steve C's Avatar
Joined Feb 2001
Ok thanks
I did find another firmware last night that works, but it sends the curser up to the top every time you change the complex mixer page. It takes 16 button presses to change a mixer to page 5, but it does seem to work fine otherwise.
Awesome stuff. I really like the idea of using one tx for multiple rx's. I'll be really excited if you get the frsky stuff working
Old Mar 06, 2013, 05:49 AM
GoElectric is offline
Find More Posts by GoElectric
Canada, AB, Edmonton
Joined Jun 2002
At the very beginning of deviation home page, it says:
"Includes support for DEVO 6/6S/8/8S/10"
but towards the end of the same page, it says:
"Support for multiple protocols without any modifications to the transmitter:
Walkera Devo 6/7/8/10/12"
So can I download the deviation firmware for my Devo7 transmitter?
Thank you.
GoElectric is offline Find More Posts by GoElectric
Wanted Broken Walkera Devo and Spektrum tx itsmillertime Aircraft - General - Radio Equipment (FS/W) 1 Mar 20, 2012 04:37 AM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 12:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 11:38 AM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz Radios 2 May 08, 2011 11:38 PM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz XHeli 0 May 05, 2011 11:19 PM
