United States, ND, Bismarck
Joined Mar 2012
Now that I think about it, I may be confused as well because in the simplified version of deviation (which i have never used or seen) they may have used a 0 to 100 throttle to match other tx's. Which would mean you don't have to convert anything. I probably should have kept my mouth shut, sorry.
I think you just want to enter -15 to 65. You should see the same numbers in the model file. You can always disconnect the motor and double check the actual pitch before you fly.
United Kingdom
Joined Aug 2008
Joined Oct 2012
@PhracturedBlue, @FDR_, @suvsuv and everybody who worked on Deviation firmware - thank you very much to all of you. I finally gave in and bought Devo 10. Yesterday I mounted A7105 transmitter from V929 on it (same as V911). Now I can control all my helis - mCPX, Mini CP, V911, V939 (my V929 stuck in a tree ;-) from a single transmitter, and a very fine one.
Keep up good work! If I'd have transmitter for unknown protocol, I gladly help you in cracking it. I initially planned to buy Skyartec Nano CP, but Devo 10 bundle with Mini CP won. |
Joined Oct 2012
@PhracturedBlue BTW do you have schematics for power circuit for Devos? I recall that you mentioned it somewhere, and as I now have Devo 10 I can experiment freely with my defective Devo 7 which has power problem - it does not switch off. So if you already traced it it would help me.
Joined Mar 2012
Either way works. (0 to 100) to (-100 to +100): [(0 to 100 value)-50] x 2 or [(0 to 100 value) x 2) -100 To to back to 0 to 100: [(-100 to +100 value) ÷ 2] + 50 or [(-100 to +100 value) +100] ÷ 2 |
Thanks Guys,
Sorry for being so thick sculled. Once I click on it I'll be outa your hair. And maybe this will help others in a search. So....... which brings me to ask....... do I have to use this in all things Deviation? Or... in the nightlies Standard Mode can I just use the numbers I normally would in Walkera Devention? |
Joined Mar 2012
The formulas only apply to "advanced" deviation, and even then, only to throttle and sometimes gyro gain. |
| Thread Tools | |
| Wanted Broken Walkera Devo and Spektrum tx | itsmillertime | Aircraft - General - Radio Equipment (FS/W) | 1 | Mar 20, 2012 04:37 AM |
| For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale | Tom Z | Aircraft - General - Radio Equipment (FS/W) | 0 | Oct 06, 2011 12:33 PM |
| For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale | Tom Z | Aircraft - Electric - Helis (FS/W) | 0 | Oct 05, 2011 11:38 AM |
| Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen | hobbypartz | Radios | 2 | May 08, 2011 11:38 PM |
| Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen | hobbypartz | XHeli | 0 | May 05, 2011 11:19 PM |
