Old Nov 27, 2012, 07:16 PM
OnceAFly is offline
Find More Posts by OnceAFly
OnceAFly's Avatar
Singapore, Singapore
Joined Oct 2011
Ya have some good rest you need that!
OnceAFly is offline Find More Posts by OnceAFly
Old Nov 28, 2012, 01:33 PM
rcgchris is offline
Find More Posts by rcgchris
...muy bien...
rcgchris's Avatar
Germany, BW, Pforzheim
Joined Jul 2012
Originally Posted by PhracturedBlue View Post
Actually, that is the MCU that they ground off. The transceiver has the white goop and the silver cylinder at the bottom right.
Guess that'll be a Chip on Board as well then
rcgchris is offline Find More Posts by rcgchris
Old Nov 28, 2012, 01:46 PM
PhracturedBlue is offline
Find More Posts by PhracturedBlue
Joined Jan 2012
did you check it? I would be very surprised if they did that. I think it would cost more than using an smt part in this case, unless they have very high volume.
PhracturedBlue is offline Find More Posts by PhracturedBlue
Old Nov 28, 2012, 02:16 PM
victzh is offline
Find More Posts by victzh
Joined Oct 2012
Hi, great job with this software. I'd like to try to fit it on Devo 7 - I have a slightly defective one, does not turn off until you physically plug off the battery. Do you have a hint how to flash it there - apparently they have some kind of bootloader over trainer port, but I don't have UP02, and anyway it's proprietary. And will I be able to restore stock firmware in case something went wrong?
victzh is offline Find More Posts by victzh
Old Nov 28, 2012, 02:36 PM
Joined Jan 2012
It won't be possible until you rewrite the interface. you can use a CP2103 based UART bridge to connect to the trainer port and reprogram. It should be possible to put back the original firmware, though I haven't tried. If your read back a few pages, you'll see that I'm planning a conversion to replace the MCU and display in a Devo7. Just waiting for the development boards to arrive t get started.
Old Nov 28, 2012, 03:35 PM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
This hardware going to be used HERE and other hardware ? Guessing Devo RF upgrade module..
SadSack is offline Find More Posts by SadSack
Old Nov 28, 2012, 03:43 PM
Joined Jan 2012
No, it turns out that while I have that board, it isn't suitable for this task. I don't yet know what the final harware will be, but it is likely to be based on this:
though I have several different variations on the way so I can figure out which is the best solution
Old Nov 28, 2012, 03:50 PM
SadSack is offline
Joined Aug 2008
better specs smaller screen ;( still better for a replacement.
Me I'll put on top, got 2 very old Walkera TX's should get enough hardware to come up with something
Guess i'll have to wait see which way you jump.
Old Nov 28, 2012, 04:00 PM
Joined Jan 2012
Yes, If I could source the Devo10 screen, I would. That would be an ideal solution (even if it is only b&w). But I can't find anyone who sells them as single units.
This is the screen:
http://www.tinsharp.com/detail/&prod...189735664.html
Instead, the 2.4" screen should fit in the opening of the Devo10/WK2x0x.
Note: I don't recommend that anyone tries to guess what hardware I'll choose. I have a few different screens and MCU boards on the way, and do not yet know which will be the best choice.
Old Nov 28, 2012, 04:29 PM
victzh is offline
Joined Oct 2012
I've seen this encouraging info and it's great! Somehow they made Devo 7 stock firmware exceptionally crappy. And I plan to follow your development and buy the board, but don't you think that some intermediate version can be created - reduced functionality Deviation for Devo 7? I have not seen your code, I plan to but did not have a chance yet, but if the GUI is reasonably separate from the controlling code it could be done.
Is CP2103 a requirement? Or any USB-to-serial would work (I had one case when it was a requirement, so I have one, I'm just curious). And do you know any details on their bootload process - pinout, is firmware extractable from the updater in a reasonable form (hex which you can flash trough JTAG/SWD) etc. When you look at a new device it seems pretty intimidating to you, but you apparently accumulated some knowledge about their devices and can help me to overcome this initial barrier. Thanks again for your great effort!
Old Nov 28, 2012, 04:33 PM
Muskoka1 is offline
Find More Posts by Muskoka1
Canada, ON, Muskoka
Joined Jul 2011
Hi guys, just loaded ver. 2 firmware on my Devo 10, keep getting this warning when I turn on the radio, don't know how to get rid of it.
"Ch3 is 0%, safe value = -100%"
Thanks for any help.
Muskoka1 is offline Find More Posts by Muskoka1
Old Nov 28, 2012, 04:53 PM
Joined Jan 2012
The GUI is a lot of work. Ask suvsuv how much effort it took to get it working with the Devo10. The Devo7 would also be very hard. the Devo7 has a rally limited MCU that will make getting the code into the memory footprint extremely challenging. It just isn't worth the effort for me.
you need a USB->UART which is not the same thing as a USB->USART.
I haven't looked at the Devo7 too much, but I think you can use the ISP on the STM32 to upload/download the firmware, as I don't think they've locked the chip on the Devo7 (it is locked on other models, and you can't read the firmware out)
But you can definitely use SWD (not JTAG) to program the Devo7. Without the UP02, I think ISP can only be used by setting some jumpers on the board to enable it.
Old Nov 28, 2012, 04:55 PM
Joined Jan 2012
likely you are using an old model file which had the safe value hard-coded.
in your model.ini, replace the [Saftey] section with this:
Code:
[safety]
Auto=min
you can use a text editor to do that.
Old Nov 28, 2012, 05:02 PM
Muskoka1 is offline
Canada, ON, Muskoka
Joined Jul 2011
Code:
[safety]
Auto=min
That fixed it....thank you
Old Nov 28, 2012, 06:54 PM
Muskoka1 is offline
Canada, ON, Muskoka
Joined Jul 2011
Ok, had a look at the software, it's not for me. Downloaded the firmware and library for my Devo 10, Upgraded the firmware, Upgraded the library, now this is what I see when I try to access the menus. Any suggestions on how to get this back the way it was before flashing Deviation?
Glen
Description:
Edit: Deviation up and running again. Need to get back to stock radio, or am I stuck with this software?
Wanted Broken Walkera Devo and Spektrum tx itsmillertime Aircraft - General - Radio Equipment (FS/W) 1 Mar 20, 2012 04:37 AM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 12:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 11:38 AM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz Radios 2 May 08, 2011 11:38 PM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz XHeli 0 May 05, 2011 11:19 PM
