United States, FL, Apopka
Joined May 2012
Yes Marty, I read you origional post too. i am still stuck though. I can not get the walkera dfuse to run. It crashes immediately no matter which version I use. What do you mean by format it first then install deviation.
So far the usb screen is all I get. Steady lit with power on or blinking with power off. Fingers crossed dfuse will operate on another computer when i get home tonight. |
Joined May 2012
It may be possible to do this in an XP VM (virtual machine). |
Try a different PC or go to a friends PC. At a very last resort, reformat. Some people have had luck with 7. |
Joined May 2012
Well i am hearing on the deviation site that there are different dfuse tools for xp 32 and 64 bit systems. Also getting conflicting stories on drivers that either need or don't need to be installed seperately. Can anyone clarify where to get the dfuse I need for xp 32
Login or register Click the Software Update tab at top Download: Devention Dfuse USB Upgrade Tools(Devo12/S、Devo8/S、Devo10、Devo6) Version:V1.5 Date:2012-06-27 If the program is crashing before you can even see it or you are getting a pop-up error I doubt that it has anything to do with the driver for the TX. If you do happen to get the software to load and you see the main screen, plug in your TX and see if it is recognized. If it is not recognized in Dfuse, you can go to device manager and you should see something to the effect of "STM Microelectronics USB" (don't have exact wording right now). If you have a yellow yield sign with an exclamation mark then your drivers are not installed properly. THey are located in the folder where dfuse is installed and you would need to go to Device Manager and manually point the device to the correct drivers. The drivers were automatically installed for me but the program still crashed on my Win7 machine. If you happened to plug in your TX in while in "upgrade mode" (the mode you get while holding EXT, I believe - not USB mode which entered by holding ENT), it is possible that your drivers did not install. Upon installing dfuse, Windows may or may not have updated the driver for that device. I hope that helps and not confuses people more. |
| Thread Tools | |
| Wanted Broken Walkera Devo and Spektrum tx | itsmillertime | Aircraft - General - Radio Equipment (FS/W) | 1 | Mar 20, 2012 04:37 AM |
| For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale | Tom Z | Aircraft - General - Radio Equipment (FS/W) | 0 | Oct 06, 2011 12:33 PM |
| For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale | Tom Z | Aircraft - Electric - Helis (FS/W) | 0 | Oct 05, 2011 11:38 AM |
| Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen | hobbypartz | Radios | 2 | May 08, 2011 11:38 PM |
| Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen | hobbypartz | XHeli | 0 | May 05, 2011 11:19 PM |
