Old Oct 14, 2012, 07:38 PM
OnceAFly is offline
Find More Posts by OnceAFly
OnceAFly's Avatar
Singapore, Singapore
Joined Oct 2011
You can set the src to ch5 and fixed value should do it.
OnceAFly is offline Find More Posts by OnceAFly
Old Oct 14, 2012, 07:42 PM
flint723 is offline
Find More Posts by flint723
United States, ND, Bismarck
Joined Mar 2012
Yes that's correct. although you might have to reverse the curve by clicking on where it says "gear" changing it to "!gear". I like it reversed so that hh mode (positive value) is when the switch is up, not down.
It's not controlling the tail servo, its simply using the gear switch to change the value from negative(rate mode) to positive(hh mode)
flint723 is offline Find More Posts by flint723
Old Oct 14, 2012, 07:48 PM
magic_marty is offline
Find More Posts by magic_marty
<Marty>
United States, KY, Springfield
Joined Jul 2011
how i set mine is the on the mixer page select ch that the gyro is on..mine was 7
complex mixer
page 1 ...switch= mix0 (or gear if you want)
Src=ch5
curve=Fixed
Scale=90
Mux=replace
page 2
switch=mix1
Src=ch5
curve=fixed
scale=80
mux=replace
page 3
Switch=mix2
Src=ch5
Curve=fixed
scale= -95
mux=replace
with it set this way i have 3 selectable gyro values...1 is 90% , 2 is lower at 80% and 3 is set to a negative value to set the gyro in rate mode
just a example on how i did it..
magic_marty is offline Find More Posts by magic_marty
Old Oct 14, 2012, 07:55 PM
clearprop88 is online now
Find More Posts by clearprop88
Joined Apr 2011
OK. Reversing the GEAR switch makes it just right.
Now Scale sets my HH mode, but how do I set the rate mode?
Offset just moves the Min/Max curve up, and down.
My next project is to set up my 2702V Rx in the Devo 6.
All the settings for that RX/Gyro are done in the TX. Will the 6CH template be able to handle that?
clearprop88 is online now Find More Posts by clearprop88
Old Oct 14, 2012, 07:57 PM
Joined Apr 2011
Thanks guys.
I have several options to try now. I should be able to get it working.
Old Oct 14, 2012, 08:20 PM
<Marty>
Joined Jul 2011
rate mode is usually oppisite of the HH mode...on mine anything above 0 is HH mode with higher number making the gyro more sensitive...from 0 to -100 is rate mode with a higher -number making the gyro more sensitive...the rx is the one out of the 4f200 i think it has the built in 3 axis gyros...pretty sure its the 2618v like the one you are using...you can tell when its in rate mode cause the led on the rx blinks and in HH mode its steady..
Old Oct 14, 2012, 08:45 PM
Joined Apr 2011
In my 2801 TX I set HH to 80, and rate mode to 20, and switch between the 2 with the gear switch.
Old Oct 14, 2012, 08:48 PM
<Marty>
Joined Jul 2011
should be able to achieve the same thing using the deviation software...
Old Oct 14, 2012, 08:50 PM
flint723 is offline
Joined Mar 2012
This is a bit different because deviation uses a -100 to +100 scale instead of a 0 to 100 scale like stock tx. So setting scale to +/- 60 is the same as 20 and 80 in old firmware.
Old Oct 14, 2012, 11:07 PM
Joined Apr 2011
I'll try that because 20, and 80 is not working.
It seems to be locked into Rate mode.
Gear is being used as the TH switch. Maybe that's what is messing it up.
Also I'm simulating a 2801 TX, but I only selected 6 Channels. Should I select 8 channels?
Old Oct 14, 2012, 11:48 PM
flint723 is offline
Joined Mar 2012
From what i've read, you can set 8 channels on a devo 6 and it will work. But if you do you will have to move the gyro channel to ch 7. Don't take me at my word on this though... I do not own a devo 6, only a devo 8s. So for me gyro is always on ch 7. And I use rudd dr for my TH.
Old Oct 15, 2012, 12:23 AM
PhracturedBlue is offline
Find More Posts by PhracturedBlue
Joined Jan 2012
ya on 6ch it is on channel 5 and on 8ch it is on channel 7.
This is probably a bug in Deviation actually.
While I display the number of channels as '6', I'm actually usingthe 8-ch protocol (deviation uses either 4, 8, or 12ch protocols). When I decided to do that, I didn't know that Walkera changed the mapping based on how many channels were available.
So I should actually send the number of channels chosen rather than snapping to the nearest 4. It would prevent a lot of confusion I guess.
PhracturedBlue is offline Find More Posts by PhracturedBlue
Old Oct 15, 2012, 10:28 AM
Joined Apr 2011
I switched to 8 CH, and used CH 7 for the gyro, and now it works.
Thanks all for your help.
My next project is to use the 2801 protocol on a 2702 RX/Gyro.
The swash mixing is done in the TX on this one as opposed to the 2618, (the one I just got working), which does the mixing internally.
Do you see any problems I might have getting the 2702 to work?
Old Oct 15, 2012, 10:38 AM
FDR_ is offline
Find More Posts by FDR_
Joined May 2011
It should work.
Load the 6ch heli template, set the protocol to WK2801 and the channel count to 8, plus click on helicopter to set the swash type and some reversing if it needed...
FDR_ is offline Find More Posts by FDR_
Old Oct 15, 2012, 10:43 AM
Joined Apr 2011
OK. I'll try that, and see how it goes.
Wanted Broken Walkera Devo and Spektrum tx itsmillertime Aircraft - General - Radio Equipment (FS/W) 1 Mar 20, 2012 04:37 AM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - General - Radio Equipment (FS/W) 0 Oct 06, 2011 12:33 PM
For Sale Walkera Devo 7 TX/Devo RX2625H Combo for sale Tom Z Aircraft - Electric - Helis (FS/W) 0 Oct 05, 2011 11:38 AM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz Radios 2 May 08, 2011 11:38 PM
Discussion New Walkera Devention Devo 12 TX w/ Touch-Screen hobbypartz XHeli 0 May 05, 2011 11:19 PM
