Old Mar 10, 2012, 08:35 AM
swimman is offline
Find More Posts by swimman
United States, NC, Holly Springs
Joined Dec 2010
Eflite Apprentice Battery Substitutes
Just received my PNP Eflite Apprentice yesterday and now need to order a few additional items which includes flight batteries.
The manual states the Eflite EFLB32003S (3S, 11.1v, 3200mah, 20c) can be used. Pricing is around $55 on-line. Are there any possible substitutes to this battery that fit the Apprentice battery compartment and what are some good sources for on-line battery purchases?
Thanks in advance.
swimman is offline Find More Posts by swimman
Old Mar 10, 2012, 09:37 AM
Dave H. is offline
Find More Posts by Dave H.
Joined Feb 2008
Any similar battery will work. In fact, that plane can fly for something like 15 minutes on those batteries. In a pinch, I've let people borrow some of my 3S 2200s for that and they worked fine as well. Those were just dirt cheap hobby king batteries. ($8.95.) It's a little floatier with a smaller battery but that's fine for a trainer.
Dave H. is offline Find More Posts by Dave H.
Old Mar 10, 2012, 11:54 AM
thinman is offline
Find More Posts by thinman
Joined Dec 2008
The original battery which came with my Apprentice that I got about 3 years ago was also a 3200mah. And to get the cg right it had to go as far forward as possible. It's dimensions were as follows:
Length: 140mm; Width: 51mm; Thickness (height): 16.5mm; Weight: 247g's
I would check these measurements against the size of the battery compartment to make sure this size will fit as they might have changed it's size since I bought mine. If this size works, then look for 3 cell batteries that are close to matching the above dimensions, or a little smaller should not be a problem.
Also, you will more than likely have to change the battery connector to match the Apprentice EC3 if you don't get an E-flight battery, or the esc connector to match the battery.
Hope this helps.
Bob
thinman is offline Find More Posts by thinman
For Sale Eflite Apprentice LPU Kansas City $115 OBO rcwarrior Aircraft - Electric - Airplanes (FS/W) 3 Jun 07, 2012 01:06 AM
Question Eflite Apprentice or Alpha sport 450 lawguy14 Electric Plane Talk 29 Jan 23, 2012 09:21 PM
Discussion Repair kit/glue advice for Eflite apprentice sgilbert Beginner Training Area (Aircraft-Electric) 2 Jan 23, 2012 03:38 AM
Sold Eflite Apprentice - Upgrades and Extras geekrawker Aircraft - Electric - Airplanes (FS/W) 0 Sep 19, 2011 10:05 PM
Help! Setup Eflite 40-AMP Pro brushless ESC on an Eflite Apprentice CarComp Electric Plane Talk 0 Sep 08, 2009 09:50 AM
