Old Mar 10, 2012, 08:09 AM
rct is offline
rct
Find More Posts by rct
rct
rct's Avatar
ohio
Joined Apr 2003
high altitude with dlg
any light weight ideas to "seeing" dlg at high alt ? Or do most not take them that high ? I have been flying electric and spec it out . the bright color wing helps,and has saved me a few times !
Hate to add weight, but at the price of a few grams / if thats possable / may be worth it . I like to fly up to were the thermals are stronger on those weak days .
thanks rt
rct is offline Find More Posts by rct
Old Mar 10, 2012, 08:26 AM
buzzfly is online now
Find More Posts by buzzfly
buzzfly's Avatar
Joined Apr 2003
rt,
I've done some spec out flights with my DLGs. This thread details some of my efforts: http://www.rcgroups.com/forums/showthread.php?t=1526411
As far as ideas of how to see it -- I live in the southwest, and our field elevation is 4200 feet. So with low humidity, that gives me very clear skies most of the time. Therefore, I don't have to fight haze as an obstacle to seeing my plane.
On the other hand, all of my planes tend to blend into the blue background of the sky at upper altitudes. For me to really get the plane up in high, I need some clouds for a backdrop. This provides me two advantages. 1.) contrast against which I can see the plane (usually just a silhouette). 2.) It gives me a physical sight reference in the sky for locating my plane when I do lose sight of it (I was flying against THAT cloud, in THAT particular puff). This is quite helpful on regaining visual contact and orientation.
I have had my Akcent up to 3106 feet, and absolutely needed the clouds to maintain contact. I also had to plan my descent so that I would continue to have a cloud backdrop until I was sufficiently low to see the plane against blue sky.
Finally, regarding colors -- Last summer I painted the bottom of the wings and stabs of my SailAire black (they were purple and orange), and the visibility increased tremendously. Against absolutely clear skies last June, I had it up to 4400 feet. I'm still trying to get to one mile -- perhaps this summer.
-- Mark
buzzfly is online now Find More Posts by buzzfly
Old Mar 10, 2012, 08:40 AM
rct is offline
rct
rct
rct's Avatar
ohio
Joined Apr 2003
re
thanks buzzfly , I too use clouds some times as a back drop for contrast !
I was thinking of maybe a bright color mylar on out board tips , Dye or something
maybe a bit of solite ,although I,m not sure of a light weight way to stick it ?. If low temp iron on ,,,ok .
Some buds at the field thought I had my ascent to 1500 -1700' and on a 60" wing.
my eyes hurt !
maybe a light coat of fluorescent paint of tips say 4 to 7" in ? How much weight
would that be ? best guess ?
Looking to buy a Topsky 1.0 this spring . can,t wait ! BTW anyone on where to buy and at best price ,,,nervous to by foreign so skipmiller best ?
rt
Old Mar 10, 2012, 08:44 AM
glidermang is online now
Find More Posts by glidermang
rct:
I was with Mark when he did it.
If your airplane is a typical DLG, then here is the lightest way to get a black under surface: flat black, misted on in a thin coat. I used water-based acrylics on my Taboos, and it worked a charm. With an airbrush, you can mist on a light coat, for a weight impact of just a few grams. The secret is a gentle, mist coat. It doesn't even have to completely cover to do the job.
Rattle-can paints from the hardware store could do it,too. I am told they sometimes attack the foam in the wing.
My Blasters are alternating white and black, and that works well against both cloud and clear sky. Mine have substitute tails, and I find that the white tails provide a useful flash when far away.
If you have an airplane with an open structure, use dark, transparent covering. Red, blue, orange and green have all worked for me, against both clear and cloud.
Good luck!
Yours, Greg
glidermang is online now Find More Posts by glidermang
Old Mar 10, 2012, 08:51 AM
rct:
I was involved in several projects as a flight test engineer. Color is pretty much meaningless when the airplane is far away and very small. The human eye does not have enough resolution under those conditions. The key is contrast (and nothing provides contrast like black) and non-reflective (hence, flat black).
It took two of us to see Mark's airplane, it was so far away. Even the Sailare.
Yours, Greg
Old Mar 10, 2012, 09:23 AM
buzzfly's Avatar
Joined Apr 2003
I have to agree with Greg on the flat black.
At the altitudes I've had my planes, colors just don't show up well. Greg's B3s with the black and white stripes are quite visible, although I don't know if they are better than solid black at higher ranges.
For my DLG attempts, I chose not to change the color schemes. My Akcent is cream on top, and orange on the bottom. My Gambler is translucent red and yellow.
If I were to change the colors for visibility, I would opt for solid flat black on the bottom of the wings (if going for altitude) or black and white stripes for high but not super high work.
-- Mark
Old Mar 10, 2012, 09:33 AM
rct is offline
rct
rct
rct's Avatar
ohio
Joined Apr 2003
re
thanks greg
My old ascent is a transparent red orange ,man it shows up well . I was thinking
fluorescent, although black may be the best ! I just tested some rust oleum spray flor- orange , I had on hand , on some old blue foam.It did not seem to attack it bad , and on topsky I assume its epoxy glass , so should be ok ,,but will test first .
Would prefer flor- red but what the hay ,,, The thing I have to get over is when spraying light it looks blotchy, rt
Old Mar 10, 2012, 10:11 AM
Nathan Schmoekel is offline
Find More Posts by Nathan Schmoekel
ground penetration specialist
Nathan Schmoekel's Avatar
USA, MI, Grand Rapids
Joined Apr 2007
I like holographic stickers. When the plane is way up you can at least catch a sparkle of light so you can find the plane....may not help with orientation much, but sometimes just keeping sight of (or re-finding) the plane is a challenge....
You can find 8x10 sheets of the stuff at most craft stores like hobby lobby or Michael's
You can also find it at sporting good stores in the fishing area... it is used for decorating fishing lures so they sparkle.
The fishing lure stuff is considerably heavier due to the thick waterproof adhesive it's backed with. The craft store stuff is half the weight and thickness.
Here is another link with a picture, but I think he's over priced and it is the heavier stuff. I prefer the craft store stuff. http://www.hilaunch.com/Wing_tape.htm SCROLL TO THE BOTTOM.
Nathan Schmoekel is offline Find More Posts by Nathan Schmoekel
Old Mar 10, 2012, 11:09 AM
mwh1503 is offline
Find More Posts by mwh1503
McKinney Texas
Joined Dec 2010
The lightest spray paint is from Michae'ls called Design Masters. They have lots of colors, but no flo-orange. Its their own brand. Lots of Free Flight DLG flyers use it, along with FA1 flyers.
mwh1503 is offline Find More Posts by mwh1503
Old Mar 10, 2012, 01:04 PM
rct is offline
rct
rct
rct's Avatar
ohio
Joined Apr 2003
sticers
Nathan
I found these rolls on bay cheap.Not sure it it will form well .They list as 3 mil
thick and have many colors and styles http://www.ebay.com/itm/1-Roll-24-X-...item79167fec32
Kind of like the diamond plate ,, bling it out--- and fake carbon fiber too !
thanks ron
Old Mar 10, 2012, 02:53 PM
Joined Apr 2007
That stuff is HEAVY.... My stuff is lighter than standard monocoat covering.
I found what I'm using in my shop and the info was on the back!! so here you go!!
http://www.darice.com/ecom/QuickSear...ia=holographic
****All the sheets with stock number 2511-XX are the light weight stuff.
The silver and gold are the best for reflective at distance. The red and blue are pretty and can aid orientation with sparkle AND by being a dark patch on the bottom of the wing. Some guys cut 1/2 - 1 inch strips and place them on the upper leading edge of the wings too. The silver and gold are the best for that.
Old Mar 10, 2012, 03:36 PM
rct is offline
rct
rct
rct's Avatar
ohio
Joined Apr 2003
Thanks for the heads up!
I'll look for at the craft store
,,, as
To Purchase from Darice:
You must possess a valid Vendors License OR Tax ID number.
Ron
Old Mar 10, 2012, 04:10 PM
Belem is online now
Find More Posts by Belem
Foam flogger
Roseville, CA
Joined Apr 2009
My Radian has a flourescent orange wing and a black wing. Over 2000 feet the orange wing is no longer visible. The black still is. I fly mostly cloudless skies.
Belem is online now Find More Posts by Belem
Old Mar 10, 2012, 06:29 PM
Joined Apr 2007
Yeah I know the link was useless for purchase, but that was the site on the backing paper. At least now you have the official stock number. It's easy to find holographic sticker, but finding the light stuff is a crap shoot when retailers don't list much information on what they stock.
Fly high
Nate
Old Mar 10, 2012, 08:53 PM
Marty B is offline
Find More Posts by Marty B
Marty B's Avatar
UK, Isle of Anglesey, Holyhead
Joined Jun 2010
Just tought I'd chime in here and say that usually any flouro paint is applied over a white base coat. That being the case, if you are being weight conscious, then you would be adding twice the weight.
I gotta say I like the idea of Holographic patches (or what ever) to give a glint in the sun! I'm continually taking my eye off "just for a second"
Marty B is offline Find More Posts by Marty B
Discussion 3.2km Stretch Exciting High and very low altitude FPV with Japanese Boosters LOL alishanmao Aerial Photography 2 Dec 21, 2011 10:18 AM
New Product New OSD - Black Stork - and High altitude record, with video eladiomf FPV Talk 235 May 09, 2011 01:39 AM
Discussion High altitude flying with conventional RC planes: Tips, Tricks, Visibility & Control BosTom Electric Plane Talk 150 Dec 28, 2009 01:01 AM
Gallery High Altitude in downtown Atlanta with Mini Ultra Stick jared_of_atlanta Aerial Photography 17 Nov 14, 2007 07:30 PM
The High Altitude Slug Project - A cheap high altitude UAV! phatmonkey UAV - Unmanned Aerial Vehicles 11 Nov 13, 2005 05:16 AM
