Old Mar 10, 2012, 07:24 AM
JSS4 is online now
Find More Posts by JSS4
I'm BIG on micros
Canada, ON, Brampton
Joined Mar 2011
Help!
Should I or shouldn't I?
URGENT!!!
Should I put a vxl3s system in my Evader DT or should I not?
Truck is mostly stock except for steering and Rx box.
Also, can I use my Onyx 3000 stick pack with changed connectors?
HELP ME PLEASE
JSS4
JSS4 is online now Find More Posts by JSS4
Old Mar 10, 2012, 01:55 PM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
I have an Evader and honestly coming from 4wd vehicles, I don't know how you use all that power with a 2wd. It just spins out or turns the slipper clutch to wax. It just doesn't hook up in turns, any of my 2wd vehicles.
shahram72 is offline Find More Posts by shahram72
Old Mar 10, 2012, 06:48 PM
kistner is offline
Find More Posts by kistner
Registered Basher
kistner's Avatar
United States, PA, Beaver
Joined May 2008
They have some metal gears for the evader now, might be necessary with a vxl. The 3000 packs probably wouldn't last long, 15 minutes tops.
kistner is offline Find More Posts by kistner
Old Mar 10, 2012, 07:03 PM
JSS4 is online now
I'm BIG on micros
Joined Mar 2011
Great! Well, I didn't end up getting the system today, I'll prob. get it next week. I'll check at my LHS for the metal gears.
Old Apr 01, 2012, 07:06 AM
JSS4 is online now
I'm BIG on micros
Joined Mar 2011
Didn't get it at all. Got a SV2 instead. Much cheaper.
Old Apr 02, 2012, 03:07 PM
Firehawk989 is offline
Find More Posts by Firehawk989
Vancouver, BC
Joined Aug 2009
Definitely get the duratrax metal idler gear and the duratrax CVD's for the nitro evader to handle the brushless power. Should be good to go after that.
Firehawk989 is offline Find More Posts by Firehawk989
Old Apr 03, 2012, 07:53 AM
JSS4 is online now
I'm BIG on micros
Joined Mar 2011
What do you mean by CVD?
I also need a metal spur gear (or someone in the GTA to fabricate me one) because I have about 4 speed runs before it is grinds down to a circle with no teeth.
Old Apr 03, 2012, 08:01 AM
kistner is offline
Registered Basher
kistner's Avatar
Joined May 2008
That would be from setting your mesh either too tight or too loose. You should only need a regular plastic/nylon spur. Cvd is an axle more or less.
Old Apr 03, 2012, 08:09 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Agreed, sounds like the mesh wasn't right at all. There's no way you need a metal spur gear for that motor.
wparsons is offline Find More Posts by wparsons
Old Apr 03, 2012, 04:33 PM
Vancouver, BC
Joined Aug 2009
CVD's: http://www3.towerhobbies.com/cgi-bin...&I=LXVWC6&P=ML
Metal Idler: http://www3.towerhobbies.com/cgi-bin...?&I=LXAEJL&P=M
And as the others have said, you shouldn't need a metal spur. Either your mesh is wrong or the teeth on your pinion are a different size/pitch than the ones on your spur.
Old Apr 04, 2012, 08:21 AM
JSS4 is online now
I'm BIG on micros
Joined Mar 2011
Both are 48 pitch. Even before the stock config the spur was ground down by the pinion before I installed anything.
Maybe I'll just get my LHS to fix the mesh for me.
Old Apr 05, 2012, 07:29 PM
Vancouver, BC
Joined Aug 2009
Yea must be the mesh, I've had my Evader Bx set up with a Tekin Redline 8.5T motor for almost a year now and no problems with the pinion or spur. (Or any other driveline parts since the metal idler and CVD upgrade.)
You should have a tiny amount of play between the teeth when the gears are meshed together. An old trick is to put a piece of paper between the gears, shove them together, and tighten the motor screws. This should get your mesh about right.
Old Apr 05, 2012, 07:54 PM
kistner is offline
Registered Basher
kistner's Avatar
Joined May 2008
+1 I use that too.
Old Apr 06, 2012, 07:13 AM
JSS4 is online now
I'm BIG on micros
Joined Mar 2011
I did that yesterday, it seemed to work, but time will tell.
Old Apr 06, 2012, 10:42 PM
rustlererad3 is offline
Find More Posts by rustlererad3
Outdoor Extremist
rustlererad3's Avatar
Pennsylvania
Joined Jul 2010
it is a good truck, used that when I was first learning how to mesh gears
rustlererad3 is offline Find More Posts by rustlererad3
Question T-REX 500 RTF, should i or shouldn't i? D-Sci Electric Heli Talk 3 May 19, 2009 04:23 AM
Discussion Hillbilly Revenge (should I or shouldn't I) Wingnut31 Life, The Universe, and Politics 37 Mar 13, 2007 12:02 AM
Discussion Should I or shouldn't I? lrsudog Life, The Universe, and Politics 131 Aug 20, 2006 02:43 PM
Should I, or Shouldn't I? squidbait Beginner Training Area (Aircraft-Electric) 2 Jun 23, 2004 09:31 AM
Piccolo Deal, should I ... or shouldn't I johnbyrne Micro Helis 3 Jan 05, 2004 10:33 AM
