Old Mar 09, 2012, 07:52 PM
auxcoord is offline
Find More Posts by auxcoord
Joined Dec 2011
transmitter li-po battery charging
I have a Spectrum dx8 transmitter I just purchased a Turnigy li-po battery for the transmitter but can not figure out how to charge battery only has a lead to plug it into transmitter no balance leads or any other wires.
auxcoord is offline Find More Posts by auxcoord
Old Mar 09, 2012, 08:08 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
Charge in the transmitter using the supplied power supply or use your main lipo charger using a servo extension lead with the shroud remove from the tip exposing the pins. The servo side of the lead with the pins have the pin spacing needed for the DX8 Lipo connector.
Select lipo charging 2S and charge away at a low rate. The pictures shows the stock NiMh but the connector is the same.
freechip is offline Find More Posts by freechip
Discussion Li-Po or Li-Ion option for 18650 cells ? Karl6666 Batteries and Chargers 4 Mar 23, 2012 03:51 AM
Discussion Li-po and Li-Io charging with Turnigy Accucell 6 stormforce Beginner Training Area (Heli-Electric) 8 Feb 25, 2012 03:56 AM
Discussion Which Li Po battery is the best for the money? Ben_Ohio Beginner Training Area (Heli-Electric) 7 Feb 24, 2012 02:16 PM
Discussion New Blade 400 Li-Po Battery Charging ERROR kefou Batteries and Chargers 12 Aug 05, 2009 11:37 AM
Li Po Battery not charging nupe009 Batteries and Chargers 4 Sep 29, 2004 07:56 AM
