United States, TN, Memphis
Joined Dec 2011
Need advice building a plane.
I've wanted a Sbach ever since I fist saw one and am trying to decide between these two:
The 39" "BX" http://www.bestvaluerc.com/shop/shopexd.asp?id=325 http://www.rcgroups.com/forums/showthread.php?t=1484274 The 40" "SC" http://www.bestvaluerc.com/shop/shopexd.asp?id=345 http://www.rcgroups.com/forums/showthread.php?t=1586679 I originally wanted the "bx" because it looked a little more durable but I don't think that is the case any more and would rather have the more scale looking "SC". I already have my servos (http://www.ebay.com/itm/140374273434...#ht_2753wt_952) ordered. Those servos look comparable to the HS-65MG's but a lot cheaper and are digital so I should be able to get more than 90 degrees of travel out of them. I am probably going with a 4A esc (http://www.hobbypartz.com/07e-c-platinum-40a.html). The 40A is probably way more than needed but it seems to be the smallest size with a built in 6V BEC. Or are there any other smaller switching ESC's with a built in 6 volt BEC. The HobbyWing I linked is switchable between 5.25 and 6V but I think 4.8 and 6V would be better. Then I could run on 4.8V to conserve battery when faster throws and higher torque isn't needed. Or would a smaller more appropriate sized ESC and a seperate BEC be better? Batteries will be Gens Ace 25C in either 1000 or 1300mah. Choosing a motor has been the most difficult for me so far. Matching kv's to props, etc... The recommended motor is the Dualsky XM2834CA-9 980Kv which weighs 70g. So I'm looking for other motors in the 70g range which are the: Omega72 Hengli W2834-1100kv Twisted Hobbys 1250kv Telink motor I believe the same 1250kv motor but a lot cheaper. After doing some research and playing with WebOcalc I think I've determined a APC 11x5.5 E would be the most efficient prop for this plane. ![]() Is 1.4 to 1 about the best I can do with a 70g motor? I'd like around 2-2.5 to 1 I can't seem to get any slow fly props on WebOcalc but it's my understanding that you should only use them when you can't fit a larger prop. And that they'll make more thrust but at a higher amp draw.
Joined Nov 2008
miller,
I know I may catch it from electronics experts when I say this but I think given two motors, turning the same props, the lower Kv motor will give you the same torque with less amp draw. The difference in amps will be proportional to the difference in Kv...i.e. a 500 Kv motor vs a 1000Kv motor will have a higher amp difference than a 900 Kv motor and a 1000Kv motor, everything else being the same. If this is in fact true, I would go with the 980 because of efficiency. Regards, Hankg Post Script...Have you looked at www.Headsupr.com for motors? |
Thanks Major and Hank.
Here is a little more info to use when sizing an electric motor for a 3d plane: The weight of the motor should be about 1/10 the AUW of the plane. Calculation: AUW (oz) divided by 10 = Motor Weight (oz) Then: Multiply the motor weight (oz) by 28.2 = motor weight in grams Here is a link to a motor that I use and like in planes of this size: Super Tigre .10 (69g): http://www3.towerhobbies.com/cgi-bin...?I=LXXGY4#tech The motors that you have listed all look pretty good...just watch the specs and select based on your prop preference and what props are recommended for use with the motor. Enjoy your flying!
Joined Dec 2011
Here's the WebOcalc for the Super Tigre .10:
![]() I'm waiting on Twisted Hobbys to get back to me on how they managed to get 443 watts from a 70g motor without frying it. (http://www.twistedhobbys.com/Outrunn...nes-221714.htm) That's over 6 watts per gram, double what is considered a safe PEAK watts per pound. If it's indeed made by intergalactic aliens with superior technology then I'll get it. If not, that Tigre .10 is looking to be the best motor in the 70g range I can find. |
| Thread Tools | |
| Build Log new to quadcopters, need advice building | AntifaCam | Multirotor Talk | 18 | Nov 21, 2011 03:19 AM |
| Discussion Ground-only (ATV, not plane) based FPV. Building a robot, never done FPV, need advice | GatorEE | Video Piloting (FPV/RPV) | 5 | Jan 20, 2011 12:35 PM |
| Question i need some advice with building a plane | codenameJEFE | Beginner Training Area (Aircraft-Electric) | 9 | Jul 15, 2006 05:18 PM |
| Discussion i need so advice with building a plane | codenameJEFE | Electric Ducted Fan Jet Talk | 1 | Jul 13, 2006 04:13 PM |
| Building plane...need advice... | Gizzmo0411 | The Builders Workshop | 15 | May 19, 2004 10:17 PM |
